[SOLVED] OLED_I2C example - compile problems
be80be
Post by be80be » Wed Sep 27, 2017 7:59 am
Install problems on Linux I.m Burt I had this working before Now it shows im misssing something to use the oled with i2c
  WARNING: Spurious .github folder in 'Adafruit NeoPixel' library
In file included from /home/burt/Arduino/hardware/Arduino_STM32-master/STM32F1/libraries/OLED_I2C/OLED_I2C.cpp:37:0:
/home/burt/Arduino/hardware/Arduino_STM32-master/STM32F1/libraries/OLED_I2C/hardware/arm/HW_STM32.h:1:22: fatal error: HardWire.h: No such file or directory
 #include "HardWire.h"
Re: OLED_I2C example - compile problems
Post by RogerClark » Wed Sep 27, 2017 11:25 am
Wire now defaults to HardWire, but it looks like that example has not been updated
Please edit /home/burt/Arduino/hardware/Arduino_STM32-master/STM32F1/libraries/OLED_I2C/hardware/arm/HW_STM32.h and change Hardwire.h to Wire.h
And let me know if that fixes is
Then I'll need to update github
Post by RogerClark » Wed Sep 27, 2017 11:47 am
BTW.
If you could also let everyone know a bit about yourself and what project you are working on, that would be great, as thats what this section is all about.
be80be
Post by be80be » Wed Sep 27, 2017 3:13 pm
Not much to say I just like to program. I use picchips more but the stm32 looked fun I had it working till I updated arduino to the new ide
Project is lighting . I'm a electrician
I'm more of a hardware guy. And a hacker lol
I can read code better then write it lol .
be80be
Post by be80be » Wed Sep 27, 2017 6:29 pm
No hardwire problem now a new one If Im posting the wrong place sorry I worked on this for a day and I'm getting no where LOL
Arduino: 1.8.4 (Linux), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STM32duino bootloader, 72Mhz (Normal), Smallest (default)"
In file included from sketch/Wire.h:43:0,
                 from sketch/HardWire.h:42,
                 from sketch/HardWire.cpp:39:
sketch/WireBase.h:45:17: fatal error: i2c.h: No such file or directory
 #include "i2c.h"
compilation terminated.
exit status 1
Error compiling for board Generic STM32F103C series.
be80be
Post by be80be » Wed Sep 27, 2017 6:34 pm
Well I figured that problem out I had added the files last night I removed them now i got this I think I can fix it
/home/burt/Arduino/hardware/Arduino_STM32-master/STM32F1/libraries/OLED_I2C/OLED_I2C.cpp:36:57: note: #pragma message: Compiling for STM32F1 Architecture...
  #pragma message("Compiling for STM32F1 Architecture...")
/home/burt/Arduino/hardware/Arduino_STM32-master/STM32F1/libraries/OLED_I2C/OLED_I2C.cpp: In member function 'void OLED::begin()':
/home/burt/Arduino/hardware/Arduino_STM32-master/STM32F1/libraries/OLED_I2C/OLED_I2C.cpp:73:46: note: #pragma message: I2C HW mode enabled
         #pragma message("I2C HW mode enabled")
/home/burt/Arduino/hardware/Arduino_STM32-master/STM32F1/libraries/OLED_I2C/OLED_I2C.cpp:80:45: note: #pragma message: SCL pinmode OUTPUT
         #pragma message("SCL pinmode OUTPUT")
Archiving built core (caching) in: /tmp/arduino_cache_713881/core/core_Arduino_STM32-master_STM32F1_genericSTM32F103C_device_variant_STM32F103C8,upload_method_DFUUploadMethod,cpu_speed_speed_72mhz,opt_osstd_2d83c63dff8fd59519291120a2799b6c.a
Sketch uses 79792 bytes (121%) of program storage space. Maximum is 65536 bytes.
Global variables use 7368 bytes (35%) of dynamic memory, leaving 13112 bytes for local variables. Maximum is 20480 bytes.
Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
thanks Roger
Post by RogerClark » Wed Sep 27, 2017 9:21 pm
OK.
There is still a bug in the code in my repo, because I removed HardWire.h as it is now the same as Wire.h
I will check the other libraries and examples and confirm nothing else needs to be updated.
be80be
Post by be80be » Wed Sep 27, 2017 9:31 pm
One was to big I made some changes to the Adafruit_SSD1306 one and it complied.
going to see if it works got hook up the oled
#include <avr/pgmspace.h>
#ifndef __SAM3X8E__ || __STM32F1__
//#include <util/delay.h>
#include "Wire.h"
#define WIRE_WRITE HWIRE.write
#include <stdlib.h>
//#include <HWIRE.h>
//#include <HardWire.h>
//HardWire HWIRE(1,I2C_FAST_MODE); // I2c1
HardWire HWIRE(2,I2C_FAST_MODE); // I2c2
#include "Adafruit_GFX.h"
#include "Adafruit_SSD1306_STM32.h"
Post by RogerClark » Wed Sep 27, 2017 9:45 pm
BTW. i noticed, that the library seems to use I2C device 2.
I am not sure why it does this. So you may want to change the code if you dont already have something connected to device 1
Post by zmemw16 » Wed Sep 27, 2017 10:44 pm
i2c1 has 24c02 on 0x50 & 0x51 already known
shouldn't conflict, pretty sure ssd1306 is elsewhere
more likely is how to use both i2c[1/2] at same time and declaration thereof - similar to spi[2] ?
srp
