Decoding the Gameboy LCD output.
Re: Decoding the Gameboy LCD output.
Post by stevestrong » Thu Nov 16, 2017 1:20 pm
Usb should work when overclocking to 96Mhz.
ZeroWalker
Post by ZeroWalker » Thu Nov 16, 2017 1:33 pm
It should?
Thought it was limited to 48mhz, and the divider was either 1 or 1.5.
Post by stevestrong » Thu Nov 16, 2017 1:42 pm
Sorry, i was wrong, of course you're right. I was thinking on F4....
ZeroWalker
Post by ZeroWalker » Thu Nov 16, 2017 4:56 pm
Ah, damn xd
ZeroWalker
Post by ZeroWalker » Thu Nov 16, 2017 5:05 pm
What about ESP32?
Post by RogerClark » Thu Nov 16, 2017 8:11 pm
I didnt think ESP32 has hardware USB.
GD32F103 can run at 96Mhz with USB or overclock to 120MHz and still runs USB.
However I found compatibility issues with the STM32 so we no longer actively suppport them.
If RPi etc dont have a bare metal version that has USB, I think perhaps BeagleBone does.
However the F4 seems a more cost effective option.
and like steve says, I am surprised that its not possible to do this on the F103, as we can get 11fps @ 320 x 240 from the OV7670 and out to a LCD display on a F103.
BTW. The ILI9341 LCD works as a good frame buffer, as we can read the frame buffer back out if that display and upload to PC via serial, albeit take around 1 sec to upload
ZeroWalker
Post by ZeroWalker » Thu Nov 16, 2017 9:07 pm
But it does have bluetooth and wireless i think, which might be good enough, but perhaps it's difficult to setup.
And well the STM32 can get the data kinda fine, but it's the transfer part in real time that's problematic cause of the slow USB Serial.
I got 16ms to send 5760 bytes basically, which is far from fast, but as a PC doesn't have any real options to transfer except via USB, that breaks it;p
Post by RogerClark » Thu Nov 16, 2017 9:20 pm
Re: ESP32
You'd have to use WiFi. BLE is far too slow, its not designed for streaming data, and BLE support on Windows is very weak, and only available in a basic form since Windows 8 (or possibly 8.1)
Actually ESP32 also supports "Classic Bluetooth" but thats an even more complicated can of worms, and I think getting the PC end of things to work would be a nightmare (I wouldnt even know where to start)
You can potentially just read a whole frame from the Gameboy into RAM on the ESP32 and then render a web page of that data.
dave j
Post by dave j » Thu Nov 16, 2017 10:16 pm
It's worth keeping in mind that the arduino libraries add layers on top of the hardware. In the case of USB, STM32F1s have a 512 byte buffer that they have to use when sending/receiving data. The arduino libraries have to copy the buffer you pass them to this 512 byte buffer in order to transfer it - which obviously takes time. You may need to write to that buffer directly in order to get it to run fast enough - which implies avoiding the arduino libraries for USB. Look at the STM32F1 reference manual for details.
ZeroWalker
Post by ZeroWalker » Thu Feb 01, 2018 3:37 pm
Hmm, is there some library to set up STM32 into "USB Mode" so it can appear as some kind of device so i can start from there.
Cause one would think that if i transfer via USB directly as have been thought of before, it should work way faster than using USB via some Serial emulation.
