Decoding the Gameboy LCD output.
Re: Decoding the Gameboy LCD output.
Post by stevestrong » Tue Nov 14, 2017 10:21 am
My problem here is that I don't have a clear scope plot to see the correct timings.
I tried to google it, and I have found this: (from here: http://www.mindspring.com/~mickeym/gameboy.htm)
Applies this in your case, too?
If yes, then you have indeed 20µs time till the first clk pulse.
But the clock seems very weird to me, it is low, then goes to high and then starts to toggle, but not continuously?
Can you eventually take a cleaner plot?
ZeroWalker
Post by ZeroWalker » Tue Nov 14, 2017 3:53 pm
Well tbh i find the Clock Pulse really weird as well.
First it's Off, then it goes on/off, then it waits for awhile, then it goes in a decent interval.
It seems to be 1 first pulse, them a "timeout" then 159 pulses afterwards.
For me the first pixel is messed up, but i am not sure if this is why (i am decoding it wrong) or if it's my gameboy as it's HSYNC is broken so i can't see the original screen.
I can give you my Salae file with all the data, except HSYNC, you need the Logic software to look at it,
but it's very good as you can zoom in and out and measure etc, not sure where to upload it though, it's about 3mb compressed.
dave j
Post by dave j » Tue Nov 14, 2017 5:43 pm
There's an article Sniff your Game Boy's LCD using a logic analyzer where someone describes capturing GameBoy screen output using a Saleae logic analyzer. It might help you make sure you're capturing things correctly.
ZeroWalker
Post by ZeroWalker » Tue Nov 14, 2017 6:37 pm
Yeah that's what i used as a source for this.
Post by stevestrong » Tue Nov 14, 2017 6:51 pm
But those signals are different from those I pasted.
Here the Vsync is one short pulse, on my picure the Vsync is along pulse.
Also, the clock signal in my pic is only generated for the active lines, here is continuous.
ZeroWalker
Post by ZeroWalker » Tue Nov 14, 2017 6:55 pm
not sure which pictures you are comparing with, those i see look similar to mine.
EDIT:
Even when using Salae though i get a corrupt first pixel column.
EDIT2:
Here's a similar screenshot to the one from the git project.
EDIT3:
Might be game dependent as this looks fine.
Post by RogerClark » Tue Nov 14, 2017 7:16 pm
@zerowalker
Images in your last post dont display
ZeroWalker
Post by ZeroWalker » Tue Nov 14, 2017 7:18 pm
They don't?
They show fine for me O.o?
Is this site blocked or something for you guys: http://abload.de/
EDIT:
Replaced them using attachments now.
Post by RogerClark » Tue Nov 14, 2017 7:29 pm
Perhaps that site is blocked by the Australian government.. more and more of the internet is getting blocked for me
ZeroWalker
Post by ZeroWalker » Tue Nov 14, 2017 7:42 pm
Oh, that's scary :(
