Hi from austria
Re: Hi from austria
Post by RogerClark » Sat Dec 09, 2017 9:26 pm
Re: RPi Zero W.
Yes. I know, but I don't think they make a zero without wifi and you could attach a USB Enternet adaptor
Re: adding web server and SSL
We server is probably possible, but SSL is where things start to get hard.
Hence why ESP32 and Zero would be a lot less work, because its already written for Zero and possibly already for ESP32
Kaffeereibm
Re: Hi from austria
Post by Kaffeereibm » Sun Dec 10, 2017 7:51 am
thanks roger,
SSL would just be the icing on the cake...
it's more important to stay small and wired, since, as I mentioned, they go into tiny spaces in the walls in my house :)
so power consumption (and therefore heat dissipation) is an issue too...
Re: Hi from austria
Post by RogerClark » Sun Dec 10, 2017 8:41 am
OK.
If you can get all the rest of the functionality working on an Arduino Nano, I think its very likely you will be able to get a simple web server working ;-)
BTW.
I'm actually in agreement with you about the RPi Zero etc.
I have 4 RPi boards (an original Model B, a RPi 3, a Zero and a Zero W) and I do not use any of them.
I seem to be able to build most projects using STM32, ESP8266, nRF52/nRF52 or ESP32.
