Porting Libraries from Arduino to STM32
porellan63
Post by porellan63 » Wed Jun 10, 2015 1:33 pm
Hello Roger
I am an electronic and I am learning to program the STM32F103RBT6 board from ebay. Olimexino from Maple have the stm32f103rbt6 also
Could you give us some tips or hints about how to port the arduino´s libraries to STM32F1 or STM32F4?
or Could you explain which the changes are in the header files.
I am using Arduino 1.6.4 and Arduino_STM32 hardware files
In this moment I would like to port the RGB16x32 libraries but i don't know how
Any help it would be very appreciated
Thanks, Regards
Pablo
Re: Porting Libraries from Arduino to STM32
Post by mrburnette » Wed Jun 10, 2015 3:43 pm
porellan63 wrote:Hello Roger
Thanks, Regards
Pablo
Pablo:
Welcome!
Your question is not easily answered. However, most of the issues that I have seen are hardware-centric such as the SPI and the I2C which have already been handled (are are being handled) in the core. For user libraries, the issue is that the old AVR are 8-bit devices and the STM32 is a 32-bit ARM, so the simple answer is "variable typing" and casts in functions and obviously return values.
Here are the libraries already ported: viewtopic.php?f=13&t=274
I would recommend pulling one or two and comparing (with some OS tool you like) and then making a few notes between the original and the ported ones. Most of the libraries that have been converted, have comments that will help. It is not always the headers, but sometimes the cpp files, too. Just depends on structures. Fortunately, we have a few graphic libs already ported, so that code would be what I would recommend as a started to the learning experience.
WE all appreciate your enthusiasm and willingness to jump in and help! Roger will likely add some insight as well, but he is in Australia and has strange hours (for us in the Northern Hemisphere!)
Post by ahull » Wed Jun 10, 2015 3:51 pm
The only additional question would be which library/libraries are you trying to port. If the library uses digitalWrite() to switch on and off a bunch of pins then it will probably work out of the box. Anything more complicated will require a bit of rework.
madias
Post by madias » Wed Jun 10, 2015 4:09 pm
Welcome Pablo,
I would just try the library out - if there are compile errors you can't fix it - post it! (Please with a reference to the used library).
One nasty problem (will fixed soon) is with pinMode's in the constructor, so take care of it (for the moment)!
Matthias
mbruck
Post by mbruck » Mon Jun 15, 2015 7:50 am
Possible to port Ethernet library for wiznet W5100. As I see from other forum, F1 series have hardware SPI bug ?
(Very cheap ethernet boards with hardware tcip/ip stack.)
Post by mrburnette » Mon Jun 15, 2015 12:15 pm
mbruck wrote:Possible to port Ethernet library for wiznet W5100. As I see from other forum, F1 series have hardware SPI bug ?
viewtopic.php?f=13&t=240&hilit=ethernet
viewtopic.php?f=15&t=319&p=2787&hilit=ethernet#p2787
mausi_mick
Post by mausi_mick » Tue Nov 15, 2016 2:03 am
for the UTOUCH / URTOUCH lib , which originally works together with the UTFT-lib , I have modified the four examples sketches:
- URTouch_Calibration
- URTouch_ButtonTest
- URTouch_QuickDraw
- URTouch_QuickPaint
to work together with Adafruit SPI-Graphic libraries for ILI9341 displays :
Adafruit_GFX_AS
Adafruit_ILI9341_STM
It's possible to integrate these programs there ?
labude
Post by labude » Fri Nov 18, 2016 9:41 pm
Hi mausi-mick,
i am very curious to see your sketches as i am failing to merge the Adafruit_ILI9341_STM lib with URTouch. Could you post the modified examples somewhere?
Thanks a lot!
