shujaat: [SOLVED] Volatile Qualifier
Re: Volatile Qualifier
Post by mrburnette » Thu Jan 18, 2018 8:22 pm
stevestrong wrote:
Thu Jan 18, 2018 7:24 pm
EDIT
There are 548 hits in 47 files for "__io" of Arduino_STM32 core, STM32F1 directory.
The cleanest solution would be to replace all those occurrences by "__IO" (make it uppercase) like in Teensy core, or by "volatile".
Steve,
I really hate myself (as I fight core changes usually) but in this instance I agree with you. Appears that Paul has been down this road already.
shujaat
Post by shujaat » Fri Jan 19, 2018 5:44 am
Well, guys, I've found the issue.
Very simple.
Two files from the gcc pakage uses "__io" as input parameter for some functions.
This is just an unfortunate coincidence that the Arduino_STM32 core uses the same term to define volatile...
The Teensy core is not sensitive to this because it uses the same term in uppercase.
As soon as I renamed all occurences of this term to "__ios" in the two files
local_facets.h
local_facets.tcc
in directory
Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1\arm-none-eabi\include\c++\4.8.3\bits
the sketch compiled fine.
Sketch uses 43968 bytes (67%) of program storage space. Maximum is 65536 bytes.
Global variables use 4376 bytes (21%) of dynamic memory, leaving 16104 bytes for local variables. Maximum is 20480 bytes.
EDIT
Congratulations! I tested this too and it works flawlessly!
Moreover thanks for finding the bug, hopefully the core will improve with time and become more useful.
Thank you so much!
shujaat
Post by shujaat » Fri Jan 19, 2018 5:55 am
EDIT
Steve,
Blindly advocating core will not make it great. We should welcome not only this but all those changes which will make it more cleaner and powerful.
Thanks for being patient and cooperating.
Re: [SOLVED] Volatile Qualifier
Post by stevestrong » Fri Jan 19, 2018 9:58 am
Just as a small note, making these replacements will not make the core better, nor cleaner or powerful.
Again: this issue is not a "core" issue, but an unfortunate coincidence between core, gcc and library.
We could blame gcc for using this term. Me, I would not come to the idea to use such a term as input parameter. Maybe with one underscore (_io) but definitely not with two underscores.
And we also could blame those who "misuse" this lib with this core because it was clearly mentioned that was not tested with it.
The question is: do we really need to do those replacements? It is really a huge effort.
Or it would suffice to leave a note (in Arduino_STM32 wiki or library readme file) to warn those who intend to use this lib what they have to do?
I would opt for the later.
shujaat
Post by shujaat » Fri Jan 19, 2018 1:04 pm
Folks at the teensy have used __IO for a better reason and I would suggest we should do the same. By the way if you name it coincidence or whatever else, it WILL affect the users and it WILL be called an issue by the users!
Post by stevestrong » Fri Jan 19, 2018 1:24 pm
@shujaat, you are welcome to submit a pull request on Github which solves this issue.
I am offering as volunteer for a review.
And I think Roger would be more than happy to have that PR.
Post by zmemw16 » Fri Jan 19, 2018 2:26 pm
there's a lot of grass to hide more snakes in ?
i.e. as in are there any others similar that might bite us ?
Post by Pito » Fri Jan 19, 2018 3:01 pm
fyi - replacing 1288x __io with __IO in my older local Arduino_STM32 repo took 14secs (Notepad++, Find and Replace in Files).
Post by mrburnette » Fri Jan 19, 2018 3:15 pm
I am on Android at the moment and away from my home lab, do we know what the Neucleo core code has done? That is, will it behave similar? If so, I believe Roger and fpiSTM should probably discuss privately and make a collective recommendation.
aster
Post by aster » Fri Jan 19, 2018 3:41 pm
it is great to know that steve tracked the problem down and found a wordaround for it! :D
IMHO since i am a lover of the clean code, i would do as pito did, if it is easy, it works, why don't change it?
i always think that this is work we are cut off from the future
