Serial monitor hangs as well as entire IDE soon after starting
Windows XP,Vista,7,8 and 8.1 etc
Phono
Post by Phono » Mon Sep 12, 2016 7:44 pm
The Arduino 1.6.9 IDE is installed on windows 10.
I have inserted in a sketch a few serial.print statements to monitor the progress of the processing in the setup function.
here is an excerpt of the code :
#define SERIAL Serial
// pin mode and such....
#ifdef SERIAL
SERIAL.begin(115200);
delay(2000);
SERIAL.println("Impression debug activee") ;
#else
CANSetup() ;
Ethernet.begin(mac,ip);
#ifdef SERIAL
SERIAL.println("Initialisation Client Ethernet") ;
// Initialisation de l'I2C
MaitreI2C.begin() ;
#ifdef SERIAL
delay(100);
SERIAL.print("Initialisation I2C ") ;
if ( MPU6050_Init() ) // Initialisation du gyroscope
SERIAL.println("reussie") ;
else
SERIAL.println("echouee") ;
#else
MPU6050_Init() ; // Initialisation du gyroscope
// etc.
When the sketch starts, only the first two prints show on the monitor window, then the IDE hangs. If I try to close the monitor window, it does not and the IDE does not respond any more, until I press the Reset button on the Olimexion STM32 board.
Any idea?
This does not occur if I use a physical serial port on the Olimexino board.
martinayotte
Re: Serial monitor hangs as well as entire IDE soon after starting
Post by martinayotte » Mon Sep 12, 2016 8:05 pm
Do you mean that the first Serial prints before the I2C.begin() are working but not the one after ?
Your MaitreI2C is probably not working and hanging. Is it a nick name for the STM32 Wire library ?
Do you have PullUps on your I2C bus ?
Phono
Post by Phono » Mon Sep 12, 2016 9:09 pm
Actually I am attempting to use the hardwire library, with :
#include <HardWire.h>
HardWire MaitreI2C ( 1, I2C_FAST_MODE ) ;
but so far with no success.
I understand what you suggest : the I2C initialisation would cause the system hang. To check for this, I have changed the code :
SERIAL.println("Initialisation I2C ") ;
MaitreI2C.begin() ;
else
So whatever the result of the initialisation of the I2C, the first print would normally work. But it does not.
Phono
Post by Phono » Mon Sep 12, 2016 9:14 pm
In addition, if I change the code above like this :
#ifdef SERIAL
SERIAL.begin(9600);
delay(2000);
#else
CANSetup() ;
#ifdef SERIAL
SERIAL.print("Initialisation Client Ethernet, ") ;
SERIAL.print("Initialisation Client Ethernet 2, ") ;
SERIAL.println("Initialisation Client Ethernet 3") ;
only the first println and the first print show on the serial monitor, and it hangs after the comma :
martinayotte
Post by martinayotte » Mon Sep 12, 2016 9:24 pm
I could barely believe it ...
Several consecutive Serial.print() and it hangs after the second ?
I've never seen that ...
Your installation is kind of weird !
Did you tried other serial communication software ?
Post by RogerClark » Mon Sep 12, 2016 9:56 pm
I wonder if this is a biproduct of the nee Tx Buffering ?
martinayotte
Post by martinayotte » Mon Sep 12, 2016 10:03 pm
It is a possibility,I didn't merged it yet in my environment.
But according to the code above, it would hang with 58 characters ...
@Phono, could you try to print a single very long print such as the following to see if hang at specific position ?
Serial.println("012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789")
edogaldo
Post by edogaldo » Tue Sep 13, 2016 6:45 am
Hi Phono, a couple of questions:
  • are you using Serial over USART1 (using a usb2serial stick) or SerialUSB (direct connection with the board's usb)
  • which board are you using?
Phono
Post by Phono » Tue Sep 13, 2016 6:51 am
Following your advice, I have changed the code as follows :
#ifdef SERIAL
SERIAL.begin(9600);
delay(2000);
Serial.println("012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789");
#else
CANSetup() ;
#ifdef SERIAL
I get the following printout :
note : there is a space after the last comma.
It does the same thing if I change
to a println.
I checked wether it was related to the serial monitor. For so, I launched Teraterm and configured it for the port the maple board is on (COM4). I get exactly the same printout as above.
So I suppose that the problem stands in the usb part of the STM32 core.
edogaldo
Post by edogaldo » Tue Sep 13, 2016 7:12 am
Hi Phono, few questions:
  • are you using Serial over USART1 (using a usb2serial stick) or SerialUSB (direct connection with the board's usb)?
  • if you make a very simple sketch like:
    begin() {
    delay(2000);
    Serial.println("Impression debug activee") ;
    Serial.print("Initialisation Client Ethernet, ") ;
    Serial.print("Initialisation Client Ethernet 2, ") ;
    Serial.println("Initialisation Client Ethernet 3") ;
    does it hang as well?
