Error while compiling (El Capitan, STM32f103c8t6, FTDI RS232)
Apple Mac OSX
Ragnarok
Post by Ragnarok » Mon Aug 29, 2016 1:23 pm
Hey guys.
I'm relatively new to this field. I got my hands on an STM43f103c8t6 mini development board, and I wanted to try using it in my work. I followed this video : https://www.youtube.com/watch?v=Ze6q6NidS5w
I've followed all these steps, but I keep getting this error every time I try compiling anything -
Cannot run program "{runtime.tools.arm-none-eabi-gcc.path}/bin/arm-none-eabi-g++" (in directory "."): error=2, No such file or directory
Also, my Port shows "Bluetooth_incoming_port" which I know is wrong, because I faced the same error with an Arduino Uno board, and I figured that the port wasn't getting detected.
Any help is appreciated, thanks! :D
Better yet, if anyone has a step-by-step instruction on how to use the STM with Arduino IDE, please do tell.
Cheers!
martinayotte
Re: Error while compiling (El Capitan, STM32f103c8t6, FTDI RS232)
Post by martinayotte » Mon Aug 29, 2016 2:50 pm
You need to install the GCC for ARM using BoardManager and choosing Arduino SAM installer.
Ragnarok
Post by Ragnarok » Sat Sep 03, 2016 10:13 am
Hey, thanks for the reply. I did this and now I'm getting a new error:
cannot init device
Is there something wrong with the hardware?
Thanks again! :)
martinayotte
Post by martinayotte » Sat Sep 03, 2016 12:19 pm
Do you mean that everything now compile, but the UpLoad failed ?
Please, provide more details such the output log.
Ragnarok
Post by Ragnarok » Tue Sep 06, 2016 12:20 pm
Yes, when I click on Verify, it says Done Compiling. But I try to upload, it shows me this:
Sketch uses 7,060 bytes (10%) of program storage space. Maximum is 65,536 bytes.
Global variables use 1,968 bytes of dynamic memory.
Failed to init device.
stm32flash Arduino_STM32_0.9
http://github.com/rogerclarkmelbourne/arduino_stm32
Using Parser : Raw BINARY
Interface serial_posix: 230400 8E1
Post by RogerClark » Tue Sep 06, 2016 9:28 pm
Did you unlock / deprotect the board first ?
It may come preflashed with some code that just blinks the LED and which is locked.
Ragnarok
Post by Ragnarok » Wed Sep 07, 2016 12:24 pm
This is new information for me. I didn't know we had to unlock boards.
Will Google this, and try unlocking if it is locked first. :) Thanks!
Ragnarok
Post by Ragnarok » Wed Sep 07, 2016 2:38 pm
I did some research. Found out that my board didn't have anything pre flashed into it. Also, I have no errors related to the locked/protected status of the board.
I did not notice before but the LED doesn't blink when I plug in the FTDI. Back to square one!
Post by RogerClark » Wed Sep 07, 2016 10:01 pm
If you are uploading via USB to Serial, and the upload succeeds and code does not run, there is a possibility that the 8mhz crystal oscillator is not running.
One other forum member had this problem.
I also have one STM32 board which will run directly after upload but not run if you power cycle it. again it had a faulty oscillator.
Also. Can you confirm which version of gcc your IDE is using, I think it should be 4.8
madias
Post by madias » Wed Sep 07, 2016 10:46 pm
Can you post a link to your board? (sounds like the faulty "ugly board") or if it's the "blue pill" -> bad 10k USB resistor.
