Failed to reconnect serial monitor after uploading on macOS
Apple Mac OSX
hanyazou
Re: Failed to reconnect serial monitor after uploading on macOS
Post by hanyazou » Wed May 24, 2017 11:00 pm
RogerClark wrote:Have you tried a variation of @danieleff's suggestion, as posted to the PR by @ag123 ( on github ) ?
I didn't try that on Windows, if you mean this @danieleff's post.
http://www.stm32duino.com/viewtopic.php ... =10#p28452
I made the patch for mac and I tested with my BP.
http://www.stm32duino.com/viewtopic.php ... 107#p28441
Post by RogerClark » Thu May 25, 2017 10:42 am
I've updated all the Maple upload scripts with @danieleff's suggested fix
I'm not sure if it will cause problems for Rick if he is not using the Arduino Serial Terminal, but the worst case should just be a short delay (timeout)
hanyazou
Post by hanyazou » Thu May 25, 2017 12:18 pm
Sorry for late reply. I get back home now.
But my mac and blue-pill requires this change.
  echo -n Waiting for ${dummy_port_fullpath} serial...
  COUNTER=0
  while [ ! -c ${dummy_port_fullpath} ] && ((COUNTER++ < 40)); do
      sleep 0.1
  done
+ sleep 0.3
  echo Done
It makes this error if you delete the 'sleep 0.3'.
processing.app.SerialException: Error opening serial port '/dev/cu.usbmodem14321'.
	at processing.app.Serial.<init>(Serial.java:141)
	at processing.app.Serial.<init>(Serial.java:78)
	at processing.app.SerialMonitor$3.<init>(SerialMonitor.java:95)
	at processing.app.SerialMonitor.open(SerialMonitor.java:95)
	at processing.app.AbstractMonitor.resume(AbstractMonitor.java:110)
	at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2207)
	at processing.app.Editor.access$2200(Editor.java:78)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2173)
	at java.lang.Thread.run(Thread.java:745)
Caused by: jssc.SerialPortException: Port name - /dev/cu.usbmodem14321; Method name - openPort(); Exception type - Port busy.
	at jssc.SerialPort.openPort(SerialPort.java:164)
	at processing.app.Serial.<init>(Serial.java:130)
	... 8 more
danieleff
Post by danieleff » Thu May 25, 2017 1:52 pm
Can you check changing -c to -r?
hanyazou
Post by hanyazou » Thu May 25, 2017 2:09 pm
No. It fails also if it lacks 'sleep 0.3'
COUNTER=0
while [ ! -r ${dummy_port_fullpath} ] && ((COUNTER++ < 40)); do
  sleep 0.1
done
#sleep 0.3
Post by RogerClark » Thu May 25, 2017 9:28 pm
I wonder if this is all Macs or just one specific model.
If its all Macs the additional sleep could be added to the Mac script, but 0.3 may not be enough for slow machines.
What CPU speed etc is your Mac, and what version of OSX are you using.
I have an old machine running Yosemite that I can test with, but I dont have time at the moment
hanyazou
Post by hanyazou » Fri May 26, 2017 12:14 pm
My mac is iMac late 2012 3.4GHz Intel Core i7 and OS version is Mac OSX 10.12.4.
This works well on my Mac.
echo -n wait for ${dummy_port_fullpath}...
COUNTER=0
while ! dd if=${dummy_port_fullpath} of=/dev/null count=0 > /dev/null 2>&1 && ((COUNTER++ < 40)); do
  sleep 0.1
done
echo done.
Post by ag123 » Fri May 26, 2017 8:20 pm
i'm not too sure if /usr/bin/test or /bin/test exists on macos, but i'd guess
is basically
test ! -r ${dummy_port_fullpath}
using dd seem to be checking if you are able to copy from the file, which probably works but looks a little unorthodox :)
and it would seem a little unusual "[ ! -r ${dummy_port_fullpath} ]" didn't seem to work on macos, i.e. check that the file exists and is readable
Post by RogerClark » Fri May 26, 2017 9:35 pm
hanyazou wrote:My mac is iMac late 2012 3.4GHz Intel Core i7 and OS version is Mac OSX 10.12.4.
COUNTER=0
  sleep 0.1
done
echo done.
Excellent
My machines running MacOS are much much slower.one machine is 2Ghz dual core, and core i5 and one core i3
