Getting started on OSX?
Apple Mac OSX
anthonyjclarke
Re: Getting started on OSX?
Post by anthonyjclarke » Sun Jun 21, 2015 8:40 am
Umm.... @Roger.... this may be quirky to explain....
Basically I think its a combination of things and I suspect my problem may not be representative...
1) I do have issues on the iMac with USB drivers / Arduino connections, one chipset (and I cant recall which) just doesnt work... so I head over to my MacBook Pro that it does work on.
2) my Arduino install has all my files stored in Documents (default)... and I have a Cloud Sync (www.sugarsync.com) sync across all my devices....
I could compile originally on my iMac, but not on the Macbook so, I suspect the cloud sync may have been the issue... will never know..
3) Did installing the Maple IDE (as you mentioned) fix it up!?
Sorry, not sure if this helps... but I did want to say a big thank you... you and Ray got me sorted.... onward and upward....
Oh, do you have a "Tip Jar?" :)
Post by RogerClark » Sun Jun 21, 2015 10:52 am
Thanks Anthony
It looks like cloud sync is not retaining file permissions, but I guess they only expect people to sync documents.
However, I presume it is working for you on at least one machine now?
anthonyjclarke
Post by anthonyjclarke » Sun Jun 21, 2015 11:09 am
Roger, yes, working on the Laptop... had a brief "play" to get working on iMac, but time ran out... will come back to that another time...
Thanks for all your help!
Post by RogerClark » Sun Jun 21, 2015 11:25 am
OK.
No worries.
BTW. If you start to feel adventurous, there is a better bootloader for the Maple mini which upload much much faster on OSX, but I'd get settled in with things for a while until you feel a bit more comfortable with the whole ecosystem before trying to reflash it.
Kenjutsu
Post by Kenjutsu » Mon Jun 22, 2015 9:44 am
Where are the instructions for flashing the new bootloader on the maple mini clone? ;)
Pieter
OSX: 10.12.6
Arduino IDE: 1.6.12
Blue pill STM32F103C8T6 Dev Board
Maple Mini Clones
Post by RogerClark » Mon Jun 22, 2015 9:54 am
I think the information about updating the Maple mini clone is scattered around a bit.
I know Victor did an update sketch, which you can run which updates the existing bootloader, but I can't find where it is at the moment
I'll look for it and post and update
@Kenjutsu
Sorry. I can't find the bootloader updater sketch. I'm not sure if Victor_pv removed the git repo with it in. I'm sure he will have a copy that he can repost.
Apart from using the updater sketch, you'd need to flash using a USB to Serial adapter - if you have one of those, you can use stm32flash to upload the new binary.
https://github.com/rogerclarkmelbourne/ ... boot20.bin
Note there is a design flaw on the Maple mini which prevents it reliably going into serial bootloader mode, you need to pull the pin Boot1 LOW, and the hold the Button down, while pressing and releasing the reset button.
Once you do that sequence and attach a USB to Serial adpator to RX and TX (Serial 1), you can upload.
However its much easier to wait for Victor to repost his sketch. I will PM him
Post by mrburnette » Mon Jun 22, 2015 12:37 pm
UPDATED: My archive copy attached. Somewhat dated but used on Maple Mini.
RogerClark wrote:I think the information about updating the Maple mini clone is scattered around a bit.
The reference is here: http://www.stm32duino.com/viewtopic.php?t=55#p358
But Victor's site seems to be down at this time...
maple_mini_bootloader.zip
(27.91 KiB) Downloaded 39 times
Kenjutsu
Post by Kenjutsu » Mon Jun 22, 2015 6:21 pm
Thanks Ray! Wow, the new bootloader is fast! :shock: 8-)
Pieter
OSX: 10.12.6
Arduino IDE: 1.6.12
Maple Mini Clones
Post by RogerClark » Mon Jun 22, 2015 9:26 pm
Thanks Ray.
I PMed Victor but he's not got back to me. i know its a busy time of year for everyone.
I will add the updater sketch to the bootloader repo, as its by far the easiest way for Maple mini users to update.
Generic board users would have already needed to initially upload via usb to serial, so I don't think its worth me building a version for the Red or Blue pill etc.
However i wish there was documentation on how the Burn Bootloader thing works in the IDE, as it would be useful for the generic boards.
i think it needs a file called Programmers.txt, but AFIK, they third part hardware docs doesn't show how to write this file
Post by RogerClark » Tue Jun 23, 2015 10:16 am
Ray and Victor
I've taken Ray's version and combined it into one file and included the bootloader data inside the sketch so that its self contained.
I've cleaned up the messages and the comments etc
I've tested on an original a Maple mini running the original maple bootloader (downloaded from leaflabs site), and also with updating its self !
 * Maple Mini bootloader updater sketch.
 * Based on sketch from Gregwar for Robotis OpenCM9.04, which is based on Maple bootloader code.
 * WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING
 * WARNING        WARNING
 * WARNING  This comes with NO WARRANTY, you use it at your own risk       WARNING
 * WARNING        WARNING
 * WARNING  Please read this warning text and the instructions below       WARNING
 * WARNING        WARNING
 * WARNING  Running this sketch will erase your bootloader replace it      WARNING
 * WARNING  with the new STM32duino bootloader                             WARNING
 * WARNING        WARNING
 * WARNING  Only use this sketch with Maple mini boards.                   WARNING
 * WARNING        WARNING
 * WARNING  Note. If your bootloader does get messed up, it is possible    WARNING
 * WARNING  to reflash using an external USB to Serial adaptor or another  WARNING
 * WARNING  Arduino board (to act as a USB to Serial device)               WARNING
 * WARNING        WARNING
 * WARNING  For more information see www.stm32duino.com                    WARNING
 * WARNING        WARNING
 * Instructions.
 * Upload this sketch onto your Maple mini.
 * After upload the LED on the board should start to flash slowly (on for 1 sec off for 1 sec)
 * Open the Serial Monitor and follow the on screen instructions
 * If the version of the bootloader that is contained in this sketch is already installed,
 * a message is displayed and you will not be prompted to update.
 * If prompted to update, press Y to agree and reflash the bootloader
 * After the update has finished, the sketch will wait for you to manually reset the board
 * or to upload a new sketch
 * If you just reset the board. This sketch will run again, as it will not be touched by the bootloader update
 * However it will display the message to indicate that this bootloader has already been installed
 * For support please register to www.stm32duino.com
 * Credit goes to Victor PV, Matthis, Ray.
 * For source code and binaries for the bootloader see
 * www.github.com/rogerclarkmelbourne/stm32duino-bootloader
 * See also www.rogerclark.net
// Data of bootloader
const char  maple_mini_boot20[7100] = {
  0x00, 0x50, 0x00, 0x20, 0x6D, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08,
  0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB5, 0x01, 0x00, 0x08,
  0xB5, 0x01, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08,
  0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08,
  0x39, 0x05, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08,
  0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0xB5, 0x01, 0x00, 0x08, 0x5F, 0xF8, 0x08, 0xF1,
  0x30, 0xBF, 0x70, 0x47, 0x20, 0xBF, 0x70, 0x47, 0x40, 0xBF, 0x70, 0x47, 0xBF, 0xF3, 0x6F, 0x8F,
  0x70, 0x47, 0xBF, 0xF3, 0x4F, 0x8F, 0x70, 0x47, 0xBF, 0xF3, 0x5F, 0x8F, 0x70, 0x47, 0x01, 0xDF,
  0x70, 0x47, 0xEF, 0xF3, 0x14, 0x80, 0x70, 0x47, 0x80, 0xF3, 0x14, 0x88, 0xBF, 0xF3, 0x6F, 0x8F,
  0x70, 0x47, 0xEF, 0xF3, 0x09, 0x80, 0x70, 0x47, 0x80, 0xF3, 0x09, 0x88, 0x70, 0x47, 0xEF, 0xF3,
  0x08, 0x80, 0x70, 0x47, 0x80, 0xF3, 0x08, 0x88, 0x70, 0x47, 0x62, 0xB6, 0x70, 0x47, 0x72, 0xB6,
  0x70, 0x47, 0xEF, 0xF3, 0x10, 0x80, 0x70, 0x47, 0x61, 0xB6, 0x70, 0x47, 0x71, 0xB6, 0x70, 0x47,
  0xEF, 0xF3, 0x13, 0x80, 0x70, 0x47, 0x80, 0xF3, 0x11, 0x88, 0x70, 0x47, 0xEF, 0xF3, 0x12, 0x80,
  0x70, 0x47, 0x40, 0xBA, 0x70, 0x47, 0x00, 0xBA, 0x70, 0x47, 0x00, 0x00, 0x00, 0x21, 0x00, 0xF0,
  0x04, 0xB8, 0x0B, 0x4B, 0x5B, 0x58, 0x43, 0x50, 0x04, 0x31, 0x0A, 0x48, 0x0A, 0x4B, 0x42, 0x18,
  0x9A, 0x42, 0xFF, 0xF4, 0xF6, 0xAF, 0x09, 0x4A, 0x00, 0xF0, 0x03, 0xB8, 0x00, 0x23, 0x42, 0xF8,
  0x04, 0x3B, 0x07, 0x4B, 0x9A, 0x42, 0xFF, 0xF4, 0xF9, 0xAF, 0x00, 0xF0, 0x27, 0xFA, 0x70, 0x47,
  0xB4, 0x18, 0x00, 0x08, 0x00, 0x00, 0x00, 0x20, 0x08, 0x03, 0x00, 0x20, 0x08, 0x03, 0x00, 0x20,
  0x4C, 0x03, 0x00, 0x20, 0xFF, 0xF7, 0xFE, 0xBF, 0x70, 0x47, 0x70, 0x47, 0x70, 0x47, 0x03, 0x28,
  0x8C, 0xBF, 0x02, 0x20, 0x00, 0x20, 0x70, 0x47, 0x70, 0x47, 0x00, 0x00, 0x03, 0x4B, 0x1B, 0x68,
  0x9B, 0x7A, 0x13, 0xB1, 0x02, 0x4B, 0x05, 0x22, 0x1A, 0x60, 0x70, 0x47, 0x44, 0x03, 0x00, 0x20,
  0x50, 0x03, 0x00, 0x20, 0x70, 0x47, 0x70, 0x47, 0x70, 0x47, 0x70, 0x47, 0x70, 0x47, 0x70, 0x47,
  0x01, 0x4B, 0x04, 0x22, 0x1A, 0x60, 0x70, 0x47, 0x50, 0x03, 0x00, 0x20, 0x10, 0xB5, 0x00, 0xF0,
  0x0F, 0xFC, 0x21, 0x4B, 0x21, 0x4A, 0x1B, 0x68, 0x00, 0x24, 0x12, 0x68, 0x9C, 0x72, 0xD2, 0x79,
  0x20, 0x46, 0x5A, 0x72, 0x1E, 0x4A, 0x1F, 0x4B, 0x14, 0x60, 0x19, 0x68, 0x21, 0xF4, 0xEC, 0x41,
  0x21, 0xF0, 0x70, 0x01, 0x41, 0xF4, 0x00, 0x71, 0x89, 0xB2, 0x19, 0x60, 0x19, 0x68, 0x21, 0xF4,
  0xE0, 0x41, 0x21, 0xF0, 0x40, 0x01, 0x89, 0xB2, 0x81, 0xF0, 0x10, 0x01, 0x19, 0x60, 0x11, 0x68,
  0x15, 0x4B, 0x89, 0xB2, 0x0B, 0x44, 0x5B, 0x00, 0x40, 0x21, 0x19, 0x60, 0x13, 0x68, 0x80, 0x22,
  0x9B, 0xB2, 0x03, 0xF1, 0x00, 0x53, 0x03, 0xF5, 0x40, 0x53, 0x5B, 0x00, 0x1A, 0x60, 0x00, 0xF0,
  0xBB, 0xFD, 0x0E, 0x4B, 0x20, 0x46, 0x1B, 0x68, 0x93, 0xF8, 0x30, 0x10, 0x00, 0xF0, 0x0C, 0xFE,
  0x20, 0x46, 0x00, 0xF0, 0xA2, 0xFD, 0x0A, 0x4B, 0x01, 0x22, 0x20, 0x46, 0xBD, 0xE8, 0x10, 0x40,
  0x1A, 0x60, 0x01, 0xF0, 0xA3, 0xBA, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20, 0xF8, 0x02, 0x00, 0x20,
  0x50, 0x5C, 0x00, 0x40, 0x00, 0x5C, 0x00, 0x40, 0x04, 0x30, 0x00, 0x20, 0x1C, 0x03, 0x00, 0x20,
  0x50, 0x03, 0x00, 0x20, 0x38, 0xB5, 0x12, 0x4B, 0x05, 0x46, 0x1A, 0x68, 0x1C, 0x46, 0x12, 0x78,
  0x02, 0xF0, 0x7F, 0x02, 0x21, 0x2A, 0x19, 0xD1, 0x00, 0xF0, 0x48, 0xFC, 0xB0, 0xB1, 0x68, 0x1E,
  0x04, 0x28, 0x13, 0xD8, 0xDF, 0xE8, 0x00, 0xF0, 0x03, 0x05, 0x07, 0x12, 0x09, 0x00, 0x09, 0x4B,
  0x04, 0xE0, 0x09, 0x4B, 0x02, 0xE0, 0x09, 0x4B, 0x00, 0xE0, 0x09, 0x4B, 0x22, 0x68, 0x00, 0x24,
  0x20, 0x46, 0x93, 0x61, 0x54, 0x82, 0x98, 0x47, 0x20, 0x46, 0x38, 0xBD, 0x02, 0x20, 0x38, 0xBD,
  0x44, 0x03, 0x00, 0x20, 0x95, 0x0A, 0x00, 0x08, 0xBD, 0x0A, 0x00, 0x08, 0x7D, 0x0A, 0x00, 0x08,
  0x65, 0x0A, 0x00, 0x08, 0x01, 0x49, 0x01, 0xF0, 0x61, 0xB8, 0x00, 0xBF, 0x44, 0x01, 0x00, 0x20,
  0x01, 0x49, 0x01, 0xF0, 0x5B, 0xB8, 0x00, 0xBF, 0xF8, 0x02, 0x00, 0x20, 0x05, 0x4B, 0x1B, 0x68,
  0x9B, 0x78, 0x07, 0x2B, 0x04, 0xD8, 0x04, 0x49, 0x01, 0xEB, 0xC3, 0x01, 0x01, 0xF0, 0x4E, 0xB8,
  0x00, 0x20, 0x70, 0x47, 0x44, 0x03, 0x00, 0x20, 0x94, 0x00, 0x00, 0x20, 0x01, 0x49, 0x01, 0xF0,
  0x45, 0xB8, 0x00, 0xBF, 0xE0, 0x00, 0x00, 0x20, 0x08, 0xB5, 0x08, 0x4B, 0x1B, 0x68, 0x1B, 0x78,
  0x03, 0xF0, 0x7F, 0x03, 0x21, 0x2B, 0x06, 0xD1, 0x00, 0xF0, 0xF8, 0xFB, 0x00, 0x28, 0x0C, 0xBF,
  0x02, 0x20, 0x00, 0x20, 0x08, 0xBD, 0x02, 0x20, 0x08, 0xBD, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20,
  0x38, 0xB5, 0x13, 0x4C, 0x09, 0x20, 0x25, 0x68, 0x00, 0xF0, 0x06, 0xFB, 0x28, 0x40, 0x40, 0xF0,
  0x50, 0x05, 0x25, 0x60, 0x04, 0x3C, 0x20, 0x46, 0x09, 0x21, 0x01, 0x22, 0x00, 0xF0, 0x88, 0xF9,
  0x20, 0x46, 0x00, 0x22, 0x09, 0x21, 0x00, 0xF0, 0x83, 0xF9, 0x00, 0xF0, 0x07, 0xFB, 0x09, 0x4B,
  0xC2, 0xB2, 0x18, 0x60, 0x08, 0x4B, 0xC0, 0xF3, 0x07, 0x20, 0x83, 0xF8, 0x29, 0x20, 0x83, 0xF8,
  0x2A, 0x00, 0x06, 0x4B, 0x5A, 0x71, 0x98, 0x71, 0xBD, 0xE8, 0x38, 0x40, 0x00, 0xF0, 0x2E, 0xBE,
  0x04, 0x0C, 0x01, 0x40, 0x08, 0x03, 0x00, 0x20, 0xEC, 0x00, 0x00, 0x20, 0x29, 0x01, 0x00, 0x20,
  0x04, 0x4B, 0x1A, 0x68, 0x92, 0xB2, 0x42, 0xF0, 0x0C, 0x02, 0x1A, 0x60, 0x02, 0x4B, 0x03, 0x22,
  0x1A, 0x60, 0x70, 0x47, 0x40, 0x5C, 0x00, 0x40, 0x50, 0x03, 0x00, 0x20, 0x04, 0x4B, 0x4F, 0xF6,
  0xFB, 0x72, 0x19, 0x68, 0x0A, 0x40, 0x1A, 0x60, 0x4F, 0xF4, 0x3F, 0x42, 0x1A, 0x60, 0x70, 0x47,
  0x40, 0x5C, 0x00, 0x40, 0x10, 0xB5, 0x1E, 0x4C, 0x07, 0x28, 0x18, 0xBF, 0x20, 0x70, 0x23, 0x78,
  0x05, 0x2B, 0x32, 0xD8, 0xDF, 0xE8, 0x03, 0xF0, 0x03, 0x06, 0x0A, 0x0E, 0x16, 0x21, 0xFF, 0xF7,
  0xE5, 0xFF, 0x2A, 0xE0, 0xFF, 0xF7, 0xE2, 0xFF, 0x04, 0x23, 0x27, 0xE0, 0x02, 0x23, 0x63, 0x70,
  0x03, 0x23, 0x23, 0xE0, 0x63, 0x78, 0x01, 0x3B, 0xDB, 0xB2, 0x63, 0x70, 0x63, 0x78, 0xF3, 0xB9,
  0x04, 0x22, 0x17, 0xE0, 0x0F, 0x4B, 0x1A, 0x68, 0x92, 0xB2, 0x42, 0xF0, 0x10, 0x02, 0x1A, 0x60,
  0x05, 0x23, 0x23, 0x70, 0x0A, 0x23, 0x63, 0x70, 0x10, 0xBD, 0x63, 0x78, 0x01, 0x3B, 0xDB, 0xB2,
  0x63, 0x70, 0x63, 0x78, 0x5B, 0xB9, 0x07, 0x4A, 0x4F, 0xF6, 0xEF, 0x73, 0x11, 0x68, 0x0B, 0x40,
  0x13, 0x60, 0x06, 0x22, 0x02, 0x4B, 0x1A, 0x70, 0x10, 0xBD, 0x06, 0x23, 0x23, 0x70, 0x10, 0xBD,
  0x0E, 0x03, 0x00, 0x20, 0x40, 0x5C, 0x00, 0x40, 0x06, 0x4B, 0x01, 0x22, 0x1A, 0x60, 0x06, 0x4A,
  0x00, 0x20, 0x06, 0x49, 0x18, 0x60, 0x10, 0x60, 0x4F, 0xF4, 0xE0, 0x52, 0x0A, 0x80, 0x1A, 0x60,
  0x70, 0x47, 0x00, 0xBF, 0x40, 0x5C, 0x00, 0x40, 0x44, 0x5C, 0x00, 0x40, 0x48, 0x03, 0x00, 0x20,
  0x07, 0xB5, 0x14, 0x23, 0x8D, 0xF8, 0x04, 0x30, 0x00, 0x23, 0x8D, 0xF8, 0x05, 0x30, 0x8D, 0xF8,
  0x06, 0x30, 0x01, 0xA8, 0x01, 0x23, 0x8D, 0xF8, 0x07, 0x30, 0x00, 0xF0, 0xA5, 0xF9, 0x03, 0xB0,
  0x5D, 0xF8, 0x04, 0xFB, 0x10, 0xB5, 0x00, 0xF0, 0x75, 0xFA, 0x09, 0x4B, 0x00, 0x24, 0x1B, 0x68,
  0x9C, 0x72, 0xFF, 0xF7, 0xD1, 0xFF, 0x07, 0x4B, 0x07, 0x4A, 0x1C, 0x60, 0x4F, 0xF4, 0x3F, 0x43,
  0x13, 0x80, 0x06, 0x4A, 0x13, 0x60, 0xFF, 0xF7, 0xDB, 0xFF, 0x05, 0x4B, 0x1C, 0x60, 0x10, 0xBD,
  0x44, 0x03, 0x00, 0x20, 0x44, 0x5C, 0x00, 0x40, 0x48, 0x03, 0x00, 0x20, 0x40, 0x5C, 0x00, 0x40,
  0x50, 0x03, 0x00, 0x20, 0x07, 0xB5, 0x14, 0x23, 0x8D, 0xF8, 0x04, 0x30, 0x01, 0xA8, 0x00, 0x23,
  0x8D, 0xF8, 0x05, 0x30, 0x8D, 0xF8, 0x06, 0x30, 0x8D, 0xF8, 0x07, 0x30, 0x00, 0xF0, 0x74, 0xF9,
  0x03, 0xB0, 0x5D, 0xF8, 0x04, 0xFB, 0x00, 0x00, 0x70, 0xB5, 0x27, 0x4D, 0x27, 0x4C, 0x2B, 0x68,
  0x27, 0x4E, 0x9B, 0xB2, 0x23, 0x80, 0x22, 0x88, 0x33, 0x88, 0x13, 0x40, 0x59, 0x05, 0x05, 0xD5,
  0x4F, 0xF6, 0xFF, 0x33, 0x2B, 0x60, 0x23, 0x4B, 0x5B, 0x68, 0x98, 0x47, 0x22, 0x88, 0x33, 0x88,
  0x1A, 0x40, 0x92, 0x04, 0x44, 0xBF, 0x4D, 0xF6, 0xFF, 0x72, 0x2A, 0x60, 0x22, 0x88, 0x13, 0x40,
  0xDB, 0x04, 0x05, 0xD5, 0x4E, 0xF6, 0xFF, 0x73, 0x2B, 0x60, 0x00, 0x20, 0xFF, 0xF7, 0x42, 0xFF,
  0x22, 0x88, 0x33, 0x88, 0x13, 0x40, 0x18, 0x05, 0x04, 0xD5, 0xFF, 0xF7, 0x21, 0xFF, 0x4F, 0xF2,
  0xFF, 0x73, 0x2B, 0x60, 0x22, 0x88, 0x33, 0x88, 0x1A, 0x40, 0x91, 0x05, 0x07, 0xD5, 0x4F, 0xF6,
  0xFF, 0x52, 0x2A, 0x60, 0x10, 0x4A, 0x11, 0x78, 0x01, 0x31, 0xC9, 0xB2, 0x11, 0x70, 0x22, 0x88,
  0x13, 0x40, 0xDA, 0x05, 0x05, 0xD5, 0x4F, 0xF6, 0xFF, 0x63, 0x2B, 0x60, 0x07, 0x20, 0xFF, 0xF7,
  0x21, 0xFF, 0x22, 0x88, 0x33, 0x88, 0x13, 0x40, 0x1B, 0x04, 0x03, 0xD5, 0xBD, 0xE8, 0x70, 0x40,
  0x00, 0xF0, 0x7A, 0xBC, 0x70, 0xBD, 0x00, 0xBF, 0x44, 0x5C, 0x00, 0x40, 0x0C, 0x03, 0x00, 0x20,
  0x48, 0x03, 0x00, 0x20, 0x00, 0x00, 0x00, 0x20, 0x4C, 0x03, 0x00, 0x20, 0x37, 0xB5, 0x01, 0x24,
  0x00, 0xF0, 0x92, 0xF8, 0x00, 0xF0, 0xB4, 0xF8, 0x00, 0xF0, 0xE2, 0xF8, 0xFF, 0xF7, 0xB8, 0xFE,
  0x00, 0xF0, 0xF2, 0xF8, 0x23, 0x48, 0x00, 0x94, 0x21, 0x46, 0x05, 0x22, 0x4F, 0xF4, 0xA0, 0x23,
  0x00, 0xF0, 0x5A, 0xF8, 0x20, 0x48, 0x00, 0xF0, 0xF5, 0xF8, 0x28, 0xB1, 0x00, 0xF0, 0x4C, 0xF8,
  0x00, 0x30, 0x18, 0xBF, 0x01, 0x20, 0x05, 0xE0, 0x1C, 0x48, 0x00, 0xF0, 0xEB, 0xF8, 0x00, 0x28,
  0xF4, 0xD1, 0x20, 0x46, 0xC4, 0xB2, 0x00, 0x25, 0x05, 0x2D, 0x0E, 0xDC, 0x01, 0x21, 0x00, 0x91,
  0x14, 0x48, 0x0A, 0x46, 0x4F, 0xF4, 0x80, 0x13, 0x00, 0xF0, 0x3E, 0xF8, 0x00, 0xF0, 0x98, 0xFB,
  0x08, 0xB1, 0x00, 0xF0, 0x9B, 0xFB, 0x01, 0x35, 0xEE, 0xE7, 0x00, 0x2C, 0xEE, 0xD1, 0x0F, 0x48,
  0x00, 0xF0, 0xD0, 0xF8, 0x08, 0xB1, 0x0D, 0x48, 0x04, 0xE0, 0x0B, 0x48, 0x00, 0xF0, 0xCA, 0xF8,
  0x18, 0xB1, 0x09, 0x48, 0x00, 0xF0, 0x18, 0xF9, 0x09, 0xE0, 0x01, 0x21, 0x00, 0x91, 0x05, 0x48,
  0x05, 0x22, 0x4F, 0xF4, 0xA0, 0x23, 0x00, 0xF0, 0x1F, 0xF8, 0x00, 0xF0, 0x21, 0xF9, 0x00, 0x20,
  0x03, 0xB0, 0x30, 0xBD, 0x00, 0x0C, 0x01, 0x40, 0x00, 0x50, 0x00, 0x08, 0x00, 0x20, 0x00, 0x08,
  0x01, 0x23, 0x03, 0xFA, 0x01, 0xF1, 0xD2, 0xF1, 0x01, 0x02, 0x38, 0xBF, 0x00, 0x22, 0x13, 0x01,
  0x99, 0x40, 0x01, 0x61, 0x70, 0x47, 0x00, 0x00, 0x02, 0x4B, 0x18, 0x68, 0xC0, 0xF3, 0x00, 0x20,
  0x70, 0x47, 0x00, 0xBF, 0x08, 0x0C, 0x01, 0x40, 0x2D, 0xE9, 0xF0, 0x47, 0x9D, 0xF8, 0x20, 0xA0,
  0x14, 0x46, 0xCA, 0xF1, 0x01, 0x07, 0xFF, 0xB2, 0x3A, 0x46, 0x80, 0x46, 0x89, 0x46, 0x1E, 0x46,
  0xFF, 0xF7, 0xDE, 0xFF, 0xB4, 0xB1, 0x35, 0x46, 0x15, 0xB1, 0x00, 0xBF, 0x01, 0x3D, 0xFB, 0xE7,
  0x40, 0x46, 0x49, 0x46, 0x52, 0x46, 0xFF, 0xF7, 0xD3, 0xFF, 0x35, 0x46, 0x15, 0xB1, 0x00, 0xBF,
  0x01, 0x3D, 0xFB, 0xE7, 0x40, 0x46, 0x49, 0x46, 0x3A, 0x46, 0x01, 0x3C, 0xFF, 0xF7, 0xC8, 0xFF,
  0xE4, 0xB2, 0xE7, 0xE7, 0xBD, 0xE8, 0xF0, 0x87, 0x0D, 0x4B, 0x0E, 0x49, 0x1A, 0x68, 0x42, 0xF0,
  0x01, 0x02, 0x1A, 0x60, 0x0C, 0x4A, 0x10, 0x68, 0x01, 0x40, 0x11, 0x60, 0x19, 0x68, 0x21, 0xF0,
  0x84, 0x71, 0x21, 0xF4, 0x80, 0x31, 0x19, 0x60, 0x19, 0x68, 0x21, 0xF4, 0x80, 0x21, 0x19, 0x60,
  0x13, 0x68, 0x23, 0xF4, 0xFE, 0x03, 0x13, 0x60, 0x04, 0x4B, 0x00, 0x22, 0x1A, 0x60, 0x70, 0x47,
  0x00, 0x10, 0x02, 0x40, 0x00, 0x00, 0xFF, 0xF8, 0x04, 0x10, 0x02, 0x40, 0x08, 0x10, 0x02, 0x40,
  0x15, 0x4B, 0x1A, 0x68, 0x42, 0xF0, 0x01, 0x12, 0x1A, 0x60, 0x1A, 0x68, 0x12, 0x48, 0x92, 0x03,
  0xFB, 0xD5, 0x12, 0x4A, 0x12, 0x21, 0x11, 0x60, 0xA2, 0xF6, 0xFC, 0x72, 0x11, 0x68, 0x41, 0xF4,
  0xE8, 0x11, 0x41, 0xF4, 0x80, 0x61, 0x11, 0x60, 0x01, 0x68, 0x41, 0xF0, 0x80, 0x71, 0x01, 0x60,
  0x19, 0x68, 0x11, 0xF0, 0x40, 0x7F, 0xFB, 0xD0, 0x11, 0x68, 0x41, 0xF0, 0x02, 0x01, 0x11, 0x60,
  0x11, 0x68, 0x09, 0x07, 0xFC, 0xD5, 0x9A, 0x69, 0x42, 0xF4, 0xFE, 0x72, 0x9A, 0x61, 0xDA, 0x69,
  0x42, 0xF4, 0x00, 0x02, 0xDA, 0x61, 0x70, 0x47, 0x00, 0x10, 0x02, 0x40, 0x00, 0x20, 0x02, 0x40,
  0x07, 0x4B, 0x08, 0x4A, 0x1A, 0x60, 0x4F, 0xF0, 0x80, 0x72, 0xDA, 0x60, 0x53, 0xF8, 0x04, 0x2C,
  0x22, 0xF0, 0xF0, 0x02, 0x42, 0xF0, 0x10, 0x02, 0x43, 0xF8, 0x04, 0x2C, 0x70, 0x47, 0x00, 0xBF,
  0x04, 0x0C, 0x01, 0x40, 0x08, 0x0C, 0x01, 0x40, 0x05, 0x4B, 0x1A, 0x68, 0xD1, 0x07, 0x03, 0xD4,
  0x1A, 0x68, 0x42, 0xF0, 0x01, 0x02, 0x1A, 0x60, 0x1A, 0x68, 0x92, 0x07, 0xFC, 0xD5, 0x70, 0x47,
  0x00, 0x10, 0x02, 0x40, 0x03, 0x68, 0x03, 0x48, 0x18, 0x40, 0xB0, 0xF1, 0x00, 0x53, 0x58, 0x42,
  0x58, 0x41, 0x70, 0x47, 0x00, 0x00, 0xFE, 0x2F, 0x18, 0x4B, 0x30, 0xB5, 0xDB, 0x68, 0x44, 0x78,
  0xDB, 0x43, 0xC3, 0xF3, 0x02, 0x23, 0xC3, 0xF1, 0x04, 0x02, 0x04, 0xFA, 0x02, 0xF2, 0x0F, 0x24,
  0xDC, 0x40, 0x81, 0x78, 0x03, 0x78, 0x0C, 0x40, 0x14, 0x43, 0x03, 0xF0, 0x03, 0x01, 0xC9, 0x00,
  0x24, 0x01, 0xFF, 0x22, 0x8C, 0x40, 0x8A, 0x40, 0x03, 0xF0, 0xFC, 0x03, 0x03, 0xF1, 0x60, 0x43,
  0x03, 0xF5, 0x61, 0x43, 0xD3, 0xF8, 0x00, 0x53, 0x25, 0xEA, 0x02, 0x01, 0x22, 0x40, 0x0A, 0x43,
  0xC3, 0xF8, 0x00, 0x23, 0x03, 0x78, 0x01, 0x22, 0x59, 0x09, 0x03, 0xF0, 0x1F, 0x03, 0x02, 0xFA,
  0x03, 0xF3, 0x03, 0x4A, 0x42, 0xF8, 0x21, 0x30, 0x30, 0xBD, 0x00, 0xBF, 0x00, 0xED, 0x00, 0xE0,
  0x00, 0xE1, 0x00, 0xE0, 0x07, 0x4B, 0x4F, 0xF0, 0xFF, 0x32, 0xC3, 0xF8, 0x80, 0x20, 0xC3, 0xF8,
  0x84, 0x20, 0xC3, 0xF8, 0x80, 0x21, 0xC3, 0xF8, 0x84, 0x21, 0x04, 0x22, 0x43, 0xF8, 0xF0, 0x2C,
  0x70, 0x47, 0x00, 0xBF, 0x00, 0xE1, 0x00, 0xE0, 0x38, 0xB5, 0x08, 0x4B, 0x80, 0x22, 0x45, 0x68,
  0x04, 0x46, 0x1A, 0x60, 0xFF, 0xF7, 0x2E, 0xFE, 0xFF, 0xF7, 0xE4, 0xFF, 0xFF, 0xF7, 0x2C, 0xFF,
  0x20, 0x68, 0xFF, 0xF7, 0x37, 0xFC, 0xA8, 0x47, 0x38, 0xBD, 0x00, 0xBF, 0x10, 0x20, 0x02, 0x40,
  0x02, 0x4A, 0x03, 0x4B, 0xDA, 0x60, 0x00, 0xBF, 0xFD, 0xE7, 0x00, 0xBF, 0x04, 0x00, 0xFA, 0x05,
  0x00, 0xED, 0x00, 0xE0, 0x0A, 0x4B, 0x10, 0xB5, 0x1A, 0x68, 0x02, 0x22, 0x1A, 0x60, 0x09, 0x4A,
  0x11, 0x68, 0x14, 0x46, 0x11, 0xF0, 0x01, 0x0F, 0xF9, 0xD1, 0x90, 0x60, 0x42, 0x22, 0x1A, 0x60,
  0x22, 0x68, 0x12, 0xF0, 0x01, 0x01, 0xFB, 0xD1, 0x19, 0x60, 0x01, 0x20, 0x10, 0xBD, 0x00, 0xBF,
  0x10, 0x20, 0x02, 0x40, 0x0C, 0x20, 0x02, 0x40, 0x37, 0xB5, 0x8B, 0xB2, 0x00, 0x93, 0x0B, 0x0C,
  0x01, 0x93, 0x0E, 0x4B, 0x01, 0x22, 0x1C, 0x68, 0x1A, 0x60, 0x0D, 0x4A, 0x15, 0x68, 0xED, 0x07,
  0xFB, 0xD4, 0x01, 0x9D, 0xAD, 0xB2, 0x45, 0x80, 0x15, 0x68, 0xED, 0x07, 0xFC, 0xD4, 0x00, 0x9D,
  0xAD, 0xB2, 0x05, 0x80, 0x15, 0x68, 0xED, 0x07, 0xFC, 0xD4, 0x24, 0xF0, 0x01, 0x02, 0x1A, 0x60,
  0x00, 0x68, 0x43, 0x1A, 0x58, 0x42, 0x58, 0x41, 0x03, 0xB0, 0x30, 0xBD, 0x10, 0x20, 0x02, 0x40,
  0x0C, 0x20, 0x02, 0x40, 0x01, 0x4B, 0x80, 0x22, 0x1A, 0x60, 0x70, 0x47, 0x10, 0x20, 0x02, 0x40,
  0x03, 0x4B, 0x04, 0x4A, 0x1A, 0x60, 0x02, 0xF1, 0x88, 0x32, 0x1A, 0x60, 0x70, 0x47, 0x00, 0xBF,
  0x04, 0x20, 0x02, 0x40, 0x23, 0x01, 0x67, 0x45, 0x07, 0x28, 0xC8, 0xBF, 0x08, 0x38, 0x0F, 0x23,
  0x80, 0x00, 0x03, 0xFA, 0x00, 0xF0, 0xC0, 0x43, 0x70, 0x47, 0x00, 0x00, 0x02, 0x4B, 0x18, 0x88,
  0x00, 0xF5, 0x00, 0x30, 0x80, 0x02, 0x70, 0x47, 0xE0, 0xF7, 0xFF, 0x1F, 0x04, 0x4B, 0x1B, 0x88,
  0x81, 0x2B, 0x34, 0xBF, 0x4F, 0xF4, 0x80, 0x60, 0x4F, 0xF4, 0x00, 0x60, 0x70, 0x47, 0x00, 0xBF,
  0xE0, 0xF7, 0xFF, 0x1F, 0x0D, 0x4A, 0x00, 0x23, 0x02, 0x21, 0x13, 0x70, 0x53, 0x70, 0x93, 0x70,
  0xD3, 0x70, 0x11, 0x71, 0x53, 0x71, 0x0A, 0x4A, 0x0A, 0x49, 0x13, 0x60, 0x0A, 0x4A, 0x13, 0x80,
  0x0A, 0x4A, 0x11, 0x60, 0x0A, 0x4A, 0x01, 0xF5, 0x88, 0x41, 0x11, 0x60, 0x09, 0x4A, 0x03, 0x21,
  0x13, 0x70, 0x09, 0x4A, 0x11, 0x70, 0x09, 0x4A, 0x13, 0x70, 0x70, 0x47, 0x5D, 0x0B, 0x00, 0x20,
  0x58, 0x0B, 0x00, 0x20, 0x00, 0x0C, 0x00, 0x20, 0x56, 0x0B, 0x00, 0x20, 0x04, 0x03, 0x00, 0x20,
  0x00, 0x03, 0x00, 0x20, 0x5C, 0x0B, 0x00, 0x20, 0x10, 0x03, 0x00, 0x20, 0x63, 0x0B, 0x00, 0x20,
  0x08, 0xB5, 0x0E, 0x4B, 0x0E, 0x48, 0x19, 0x79, 0x00, 0x22, 0xC9, 0xB2, 0x01, 0x29, 0x02, 0x60,
  0x08, 0xD1, 0x02, 0x21, 0x19, 0x71, 0x1A, 0x70, 0xFF, 0xF7, 0x24, 0xFF, 0xBD, 0xE8, 0x08, 0x40,
  0xFF, 0xF7, 0x36, 0xBD, 0x11, 0xF0, 0xFD, 0x0F, 0x06, 0xD0, 0x02, 0x21, 0x19, 0x71, 0x1A, 0x70,
  0xBD, 0xE8, 0x08, 0x40, 0xFF, 0xF7, 0x3C, 0xBF, 0x08, 0xBD, 0x00, 0xBF, 0x5D, 0x0B, 0x00, 0x20,
  0x58, 0x0B, 0x00, 0x20, 0x20, 0xB9, 0x03, 0x4B, 0x01, 0x22, 0x1B, 0x68, 0x1A, 0x82, 0x70, 0x47,
  0x01, 0x48, 0x70, 0x47, 0x44, 0x03, 0x00, 0x20, 0x61, 0x0B, 0x00, 0x20, 0x20, 0xB9, 0x03, 0x4B,
  0x06, 0x22, 0x1B, 0x68, 0x1A, 0x82, 0x70, 0x47, 0x01, 0x48, 0x70, 0x47, 0x44, 0x03, 0x00, 0x20,
  0x5D, 0x0B, 0x00, 0x20, 0x06, 0x4B, 0x1B, 0x68, 0x30, 0xB9, 0xDA, 0x88, 0x59, 0x8A, 0x51, 0x1A,
  0x19, 0x82, 0x04, 0x4B, 0x1A, 0x80, 0x70, 0x47, 0x5B, 0x8A, 0x03, 0x48, 0x18, 0x44, 0x70, 0x47,
  0x44, 0x03, 0x00, 0x20, 0x56, 0x0B, 0x00, 0x20, 0x54, 0x03, 0x00, 0x20, 0x08, 0x4B, 0x30, 0xB9,
  0x1B, 0x68, 0x08, 0x4A, 0x11, 0x88, 0x5A, 0x8A, 0x8A, 0x1A, 0x1A, 0x82, 0x70, 0x47, 0x06, 0x49,
  0x06, 0x4A, 0x1B, 0x68, 0x12, 0x68, 0x08, 0x68, 0x5B, 0x8A, 0x10, 0x44, 0x18, 0x44, 0x70, 0x47,
  0x44, 0x03, 0x00, 0x20, 0x56, 0x0B, 0x00, 0x20, 0x04, 0x03, 0x00, 0x20, 0x58, 0x0B, 0x00, 0x20,
  0x70, 0xB5, 0x12, 0x4B, 0x12, 0x4E, 0x1B, 0x78, 0x34, 0x68, 0x02, 0x2B, 0x04, 0xF1, 0x00, 0x64,
  0x0C, 0xBF, 0x04, 0xF5, 0xA0, 0x44, 0x04, 0xF5, 0x00, 0x54, 0x20, 0x46, 0xFF, 0xF7, 0xEA, 0xFE,
  0x00, 0x25, 0x0C, 0x4B, 0x1A, 0x88, 0x92, 0xB2, 0x95, 0x42, 0x06, 0xDA, 0x0A, 0x4B, 0x60, 0x19,
  0xE9, 0x58, 0xFF, 0xF7, 0xF9, 0xFE, 0x04, 0x35, 0xF3, 0xE7, 0x31, 0x68, 0x1A, 0x88, 0x92, 0xB2,
  0x0A, 0x44, 0x32, 0x60, 0x00, 0x22, 0x1A, 0x80, 0x70, 0xBD, 0x00, 0xBF, 0x5C, 0x0B, 0x00, 0x20,
  0x58, 0x0B, 0x00, 0x20, 0x56, 0x0B, 0x00, 0x20, 0x54, 0x03, 0x00, 0x20, 0x2D, 0xE9, 0xF0, 0x41,
  0x7F, 0x49, 0x80, 0x4C, 0x01, 0x20, 0x08, 0x70, 0x23, 0x79, 0x00, 0x22, 0xDB, 0xB2, 0x02, 0x2B,
  0x22, 0x70, 0x56, 0xD1, 0x08, 0x70, 0x7C, 0x49, 0x09, 0x68, 0x48, 0x78, 0x01, 0x28, 0x26, 0xD1,
  0xC8, 0x88, 0x00, 0x28, 0x00, 0xF0, 0xC1, 0x80, 0x78, 0x48, 0x09, 0x7B, 0x02, 0x60, 0x01, 0x29,
  0x4F, 0xF0, 0x03, 0x02, 0x22, 0x71, 0x0B, 0xD0, 0x02, 0x29, 0x16, 0xD1, 0x74, 0x4B, 0x1A, 0x70,
  0x74, 0x4A, 0x75, 0x4B, 0x1A, 0x60, 0xFF, 0xF7, 0x27, 0xFE, 0xFF, 0xF7, 0xE9, 0xFE, 0xCF, 0xE0,
  0x72, 0x49, 0x71, 0x4A, 0x11, 0x60, 0x6E, 0x4A, 0x13, 0x70, 0xFF, 0xF7, 0x1D, 0xFE, 0xFF, 0xF7,
  0xDF, 0xFE, 0x6C, 0x48, 0xFF, 0xF7, 0x96, 0xFE, 0xC2, 0xE0, 0x0A, 0x23, 0x62, 0xE0, 0x02, 0x28,
  0x21, 0xD1, 0x09, 0x23, 0x23, 0x71, 0xCA, 0x88, 0x69, 0x4B, 0x1A, 0x80, 0x18, 0x88, 0x69, 0x4A,
  0x80, 0xB2, 0x10, 0x80, 0x1A, 0x88, 0x4B, 0x88, 0x92, 0xB2, 0x5A, 0x43, 0x5F, 0x4B, 0x1A, 0x60,
  0x0B, 0x7B, 0x01, 0x2B, 0x03, 0xD0, 0x02, 0x2B, 0x09, 0xD1, 0x5E, 0x4A, 0x00, 0xE0, 0x5F, 0x4A,
  0x5D, 0x4B, 0x1A, 0x60, 0xFF, 0xF7, 0xD2, 0xFE, 0x5F, 0x4B, 0x18, 0x60, 0xA0, 0xE0, 0x0A, 0x23,
  0x23, 0x71, 0x03, 0x23, 0x9B, 0xE0, 0x06, 0x28, 0x3C, 0xD0, 0x03, 0x28, 0x19, 0xD0, 0x05, 0x28,
  0x3C, 0xE0, 0x03, 0x2B, 0x0B, 0xD1, 0x50, 0x4A, 0x12, 0x68, 0x52, 0x78, 0x03, 0x2A, 0x04, 0xD1,
  0x05, 0x23, 0x23, 0x71, 0xFF, 0xF7, 0x64, 0xFF, 0x8A, 0xE0, 0x05, 0x2A, 0x2E, 0xE0, 0x04, 0x2B,
  0x09, 0xD1, 0x52, 0x49, 0x08, 0x78, 0x02, 0x28, 0x03, 0xD1, 0x03, 0x23, 0x62, 0x70, 0x0B, 0x70,
  0x05, 0x23, 0x23, 0x71, 0x7C, 0xE0, 0x05, 0x2B, 0x14, 0xD1, 0x43, 0x4B, 0x1A, 0x68, 0x53, 0x78,
  0x01, 0x2B, 0x08, 0xD1, 0xD3, 0x88, 0x0B, 0xB1, 0x03, 0x23, 0xF2, 0xE7, 0x06, 0x23, 0x23, 0x71,
  0xFF, 0xF7, 0x80, 0xFE, 0x6C, 0xE0, 0x06, 0x2B, 0x4D, 0xD0, 0x03, 0x2B, 0x4B, 0xD0, 0x05, 0x2B,
  0x62, 0xD1, 0x48, 0xE0, 0x06, 0x2B, 0x0B, 0xD1, 0x37, 0x49, 0x09, 0x68, 0x49, 0x78, 0x03, 0x29,
  0x03, 0xD1, 0x08, 0x23, 0x23, 0x71, 0x22, 0x70, 0x5A, 0xE0, 0x05, 0x29, 0x54, 0xD1, 0xD8, 0xE7,
  0x07, 0x2B, 0xF6, 0xD0, 0x08, 0x2B, 0xD4, 0xD0, 0x09, 0x2B, 0x3C, 0xD1, 0x2E, 0x4B, 0x1A, 0x68,
  0x53, 0x78, 0x02, 0x2B, 0x2D, 0xD1, 0xD0, 0x88, 0x38, 0xB3, 0x31, 0x49, 0x52, 0x88, 0x0B, 0x88,
  0x2D, 0x4D, 0x9B, 0xB2, 0x53, 0x43, 0x29, 0x4A, 0x2F, 0x4E, 0x13, 0x60, 0x2F, 0x68, 0xD2, 0xF8,
  0x00, 0x80, 0xB1, 0xF8, 0x00, 0xC0, 0x47, 0x44, 0x33, 0x68, 0x1F, 0xFA, 0x8C, 0xFC, 0x67, 0x44,
  0x9F, 0x42, 0x28, 0x4B, 0x03, 0xD8, 0x0A, 0x88, 0x92, 0xB2, 0x1A, 0x80, 0x19, 0xE0, 0x36, 0x68,
  0x2D, 0x68, 0x11, 0x68, 0x72, 0x1B, 0x52, 0x1A, 0x92, 0xB2, 0x1A, 0x80, 0x1A, 0x88, 0x92, 0xB2,
  0x82, 0x42, 0x08, 0xD3, 0x00, 0x22, 0x1A, 0x80, 0x05, 0xE0, 0x0A, 0x23, 0x23, 0x71, 0x09, 0x23,
  0x1D, 0xE0, 0x06, 0x2B, 0x01, 0xD1, 0x02, 0x23, 0x9B, 0xE7, 0x03, 0x2B, 0x01, 0xD0, 0x05, 0x2B,
  0x12, 0xD1, 0x09, 0x23, 0x95, 0xE7, 0x0A, 0x2B, 0x0E, 0xD1, 0x0F, 0x4B, 0x1B, 0x68, 0x5B, 0x78,
  0x03, 0x2B, 0x01, 0xD1, 0x0A, 0x23, 0x8C, 0xE7, 0x05, 0x2B, 0xFB, 0xD0, 0x04, 0x2B, 0x03, 0xD1,
  0x02, 0x23, 0x23, 0x71, 0x00, 0x23, 0x02, 0xE0, 0x0A, 0x23, 0x23, 0x71, 0x0F, 0x23, 0x23, 0x70,
  0x20, 0x78, 0xD0, 0xF1, 0x01, 0x00, 0x38, 0xBF, 0x00, 0x20, 0xBD, 0xE8, 0xF0, 0x81, 0x00, 0xBF,
  0x63, 0x0B, 0x00, 0x20, 0x5D, 0x0B, 0x00, 0x20, 0x44, 0x03, 0x00, 0x20, 0x58, 0x0B, 0x00, 0x20,
  0x5C, 0x0B, 0x00, 0x20, 0x00, 0x20, 0x00, 0x08, 0x04, 0x03, 0x00, 0x20, 0x00, 0x50, 0x00, 0x08,
  0x54, 0x0B, 0x00, 0x20, 0x56, 0x0B, 0x00, 0x20, 0x00, 0x03, 0x00, 0x20, 0x10, 0x03, 0x00, 0x20,
  0x01, 0x4B, 0x18, 0x78, 0x70, 0x47, 0x00, 0xBF, 0x63, 0x0B, 0x00, 0x20, 0x00, 0xBF, 0xFD, 0xE7,
  0x80, 0x00, 0x00, 0xF1, 0x80, 0x40, 0x00, 0xF5, 0xB8, 0x40, 0x03, 0x68, 0xCA, 0x06, 0x23, 0xF4,
  0xE0, 0x43, 0x23, 0xF0, 0x40, 0x03, 0x9B, 0xB2, 0x48, 0xBF, 0x83, 0xF0, 0x10, 0x03, 0x8A, 0x06,
  0x48, 0xBF, 0x83, 0xF0, 0x20, 0x03, 0x03, 0x60, 0x70, 0x47, 0x80, 0x00, 0x00, 0xF1, 0x80, 0x40,
  0x00, 0xF5, 0xB8, 0x40, 0x03, 0x68, 0x23, 0xF4, 0x80, 0x43, 0x23, 0xF0, 0x70, 0x03, 0x9B, 0xB2,
  0x83, 0xF4, 0x40, 0x53, 0x03, 0x60, 0x70, 0x47, 0x80, 0x00, 0x00, 0xF1, 0x80, 0x40, 0x00, 0xF5,
  0xB8, 0x40, 0x03, 0x68, 0x23, 0xF4, 0xE2, 0x43, 0x23, 0xF0, 0x70, 0x03, 0x1B, 0x04, 0x1B, 0x0C,
  0x03, 0x60, 0x70, 0x47, 0x80, 0x00, 0x00, 0xF1, 0x80, 0x40, 0x00, 0xF5, 0xB8, 0x40, 0x03, 0x68,
  0x5B, 0x04, 0x06, 0xD5, 0x02, 0x68, 0x48, 0xF6, 0x8F, 0x73, 0x13, 0x40, 0x43, 0xF4, 0x80, 0x43,
  0x5B, 0x06, 0x06, 0xD5, 0x02, 0x68, 0x48, 0xF6, 0x8F, 0x73, 0x13, 0x40, 0x43, 0xF0, 0x40, 0x03,
  0x03, 0x60, 0x70, 0x47, 0x05, 0x4B, 0x1B, 0x68, 0x9B, 0xB2, 0x03, 0xEB, 0xC0, 0x00, 0x00, 0xF1,
  0x00, 0x50, 0x00, 0xF5, 0x40, 0x50, 0x40, 0x00, 0x00, 0x88, 0x70, 0x47, 0x50, 0x5C, 0x00, 0x40,
  0x04, 0x4B, 0x1B, 0x68, 0x9B, 0xB2, 0x03, 0xEB, 0xC0, 0x00, 0x03, 0x4B, 0x03, 0x44, 0x5B, 0x00,
  0x18, 0x88, 0x70, 0x47, 0x50, 0x5C, 0x00, 0x40, 0x04, 0x30, 0x00, 0x20, 0x04, 0x4B, 0x1B, 0x68,
  0x9B, 0xB2, 0x03, 0xEB, 0xC0, 0x00, 0x03, 0x4B, 0x03, 0x44, 0x5B, 0x00, 0x19, 0x60, 0x70, 0x47,
  0x50, 0x5C, 0x00, 0x40, 0x02, 0x30, 0x00, 0x20, 0x0D, 0x4B, 0x3E, 0x29, 0x1B, 0x68, 0x9B, 0xB2,
  0x03, 0xEB, 0xC0, 0x00, 0x0B, 0x4B, 0x03, 0x44, 0x4F, 0xEA, 0x43, 0x02, 0x09, 0xD9, 0x4B, 0x09,
  0xC8, 0x06, 0x04, 0xBF, 0x03, 0xF1, 0xFF, 0x33, 0x9B, 0xB2, 0x9B, 0x02, 0x43, 0xF4, 0x00, 0x43,
  0x04, 0xE0, 0x4B, 0x08, 0xC9, 0x07, 0x48, 0xBF, 0x01, 0x33, 0x9B, 0x02, 0x13, 0x60, 0x70, 0x47,
  0x50, 0x5C, 0x00, 0x40, 0x06, 0x30, 0x00, 0x20, 0x70, 0xB5, 0x4C, 0x4A, 0x4C, 0x4B, 0x11, 0x68,
  0x88, 0xB2, 0x0C, 0x04, 0x18, 0x80, 0x40, 0xF1, 0x90, 0x80, 0x47, 0xF6, 0xFF, 0x71, 0x11, 0x60,
  0x1A, 0x88, 0x48, 0x4C, 0x02, 0xF0, 0x0F, 0x02, 0x22, 0x70, 0x00, 0x2A, 0x5F, 0xD1, 0x46, 0x4C,
  0x46, 0x4D, 0x22, 0x68, 0x46, 0x4E, 0x02, 0xF4, 0x40, 0x52, 0x2A, 0x80, 0x22, 0x68, 0x02, 0xF0,
  0x30, 0x02, 0x32, 0x80, 0x22, 0x68, 0x22, 0xF4, 0x80, 0x42, 0x22, 0xF0, 0x70, 0x02, 0x92, 0xB2,
  0x82, 0xF4, 0x00, 0x52, 0x22, 0x60, 0x22, 0x68, 0x22, 0xF4, 0xE0, 0x42, 0x22, 0xF0, 0x40, 0x02,
  0x92, 0xB2, 0x82, 0xF0, 0x20, 0x02, 0x22, 0x60, 0x1B, 0x88, 0xD8, 0x06, 0x02, 0xD5, 0x23, 0x68,
  0x19, 0x06, 0x07, 0xD5, 0x22, 0x68, 0x48, 0xF6, 0x0F, 0x73, 0x13, 0x40, 0x23, 0x60, 0x00, 0xF0,
  0x61, 0xFC, 0x12, 0xE0, 0x1A, 0x05, 0x07, 0xD5, 0x22, 0x68, 0x40, 0xF6, 0x8F, 0x73, 0x13, 0x40,
  0x23, 0x60, 0x00, 0xF0, 0x69, 0xFA, 0x08, 0xE0, 0x18, 0x04, 0xB6, 0xD5, 0x22, 0x68, 0x40, 0xF6,
  0x8F, 0x73, 0x13, 0x40, 0x23, 0x60, 0x00, 0xF0, 0xCD, 0xFB, 0x23, 0x68, 0x2A, 0x88, 0x23, 0xF4,
  0x80, 0x43, 0x23, 0xF0, 0x70, 0x03, 0x9B, 0xB2, 0xD1, 0x04, 0x48, 0xBF, 0x83, 0xF4, 0x80, 0x53,
  0x95, 0x04, 0x21, 0x4A, 0x48, 0xBF, 0x83, 0xF4, 0x00, 0x53, 0x13, 0x60, 0x13, 0x68, 0x31, 0x88,
  0x23, 0xF4, 0xE0, 0x43, 0x23, 0xF0, 0x40, 0x03, 0x9B, 0xB2, 0xCC, 0x06, 0x48, 0xBF, 0x83, 0xF0,
  0x10, 0x03, 0x88, 0x06, 0x48, 0xBF, 0x83, 0xF0, 0x20, 0x03, 0x13, 0x60, 0x70, 0xBD, 0x93, 0x00,
  0x03, 0xF1, 0x80, 0x43, 0x03, 0xF5, 0xB8, 0x43, 0x1D, 0x68, 0x29, 0x04, 0x09, 0xD5, 0x18, 0x68,
  0x40, 0xF6, 0x8F, 0x71, 0x01, 0x40, 0x19, 0x60, 0x12, 0x4B, 0x01, 0x3A, 0x53, 0xF8, 0x22, 0x30,
  0x98, 0x47, 0x2B, 0x06, 0x7F, 0xF5, 0x79, 0xAF, 0x21, 0x78, 0x48, 0xF6, 0x0F, 0x72, 0x8B, 0x00,
  0x03, 0xF1, 0x80, 0x43, 0x03, 0xF5, 0xB8, 0x43, 0x18, 0x68, 0x01, 0x39, 0x02, 0x40, 0x1A, 0x60,
  0x09, 0x4B, 0x53, 0xF8, 0x21, 0x30, 0x98, 0x47, 0x67, 0xE7, 0x70, 0xBD, 0x44, 0x5C, 0x00, 0x40,
  0x0C, 0x03, 0x00, 0x20, 0x20, 0x03, 0x00, 0x20, 0x00, 0x5C, 0x00, 0x40, 0x12, 0x03, 0x00, 0x20,
  0x14, 0x03, 0x00, 0x20, 0x50, 0x00, 0x00, 0x20, 0x34, 0x00, 0x00, 0x20, 0x08, 0xB5, 0x07, 0x4A,
  0x07, 0x4B, 0x08, 0x49, 0x13, 0x60, 0x02, 0x22, 0x1A, 0x72, 0x07, 0x4B, 0x07, 0x4A, 0x13, 0x60,
  0x07, 0x4A, 0x1B, 0x68, 0x11, 0x60, 0x98, 0x47, 0x08, 0xBD, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20,
  0x24, 0x03, 0x00, 0x20, 0x6C, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x20, 0x1C, 0x03, 0x00, 0x20,
  0x40, 0x03, 0x00, 0x20, 0x10, 0xB5, 0x06, 0x4C, 0x18, 0xB9, 0x23, 0x68, 0x01, 0x22, 0x1A, 0x82,
  0x10, 0xBD, 0x04, 0x4B, 0x1B, 0x68, 0x1B, 0x68, 0x98, 0x47, 0x20, 0x68, 0x0A, 0x30, 0x10, 0xBD,
  0x44, 0x03, 0x00, 0x20, 0x40, 0x03, 0x00, 0x20, 0x10, 0xB5, 0x06, 0x4C, 0x18, 0xB9, 0x23, 0x68,
  0x01, 0x22, 0x1A, 0x82, 0x10, 0xBD, 0x04, 0x4B, 0x1B, 0x68, 0x9B, 0x68, 0x98, 0x47, 0x20, 0x68,
  0x0C, 0x30, 0x10, 0xBD, 0x44, 0x03, 0x00, 0x20, 0x40, 0x03, 0x00, 0x20, 0x10, 0xB5, 0x20, 0x4B,
  0x18, 0xB9, 0x1B, 0x68, 0x02, 0x22, 0x1A, 0x82, 0x10, 0xBD, 0x1E, 0x4A, 0x19, 0x68, 0x00, 0x20,
  0x10, 0x80, 0x0C, 0x78, 0x13, 0x46, 0x14, 0xF0, 0x7F, 0x04, 0x0D, 0xD1, 0x4A, 0x7A, 0x91, 0x06,
  0x44, 0xBF, 0x02, 0x21, 0x19, 0x70, 0x12, 0xF0, 0x40, 0x0F, 0x1A, 0x78, 0x14, 0xBF, 0x22, 0xF0,
  0x01, 0x02, 0x42, 0xF0, 0x01, 0x02, 0x14, 0xE0, 0x01, 0x2C, 0x1F, 0xD0, 0x02, 0x2C, 0x1E, 0xD1,
  0x09, 0x79, 0x01, 0xF0, 0x0F, 0x02, 0x92, 0x00, 0x02, 0xF1, 0x80, 0x42, 0x02, 0xF5, 0xB8, 0x42,
  0x11, 0xF0, 0x80, 0x0F, 0x12, 0x68, 0x06, 0xD0, 0x02, 0xF0, 0x30, 0x02, 0x10, 0x2A, 0x07, 0xD1,
  0x01, 0x22, 0x1A, 0x70, 0x04, 0xE0, 0x02, 0xF4, 0x40, 0x52, 0xB2, 0xF5, 0x80, 0x5F, 0xF6, 0xE7,
  0x05, 0x4B, 0x1B, 0x68, 0x1B, 0x69, 0x98, 0x47, 0x02, 0x48, 0x10, 0xBD, 0x10, 0x46, 0x10, 0xBD,
  0x44, 0x03, 0x00, 0x20, 0x4A, 0x03, 0x00, 0x20, 0x40, 0x03, 0x00, 0x20, 0x23, 0x4A, 0x2D, 0xE9,
  0xF8, 0x43, 0x14, 0x68, 0x90, 0x46, 0x23, 0x8A, 0x26, 0x7A, 0x21, 0x4F, 0xA3, 0xB9, 0x04, 0x2E,
  0x12, 0xD1, 0x20, 0x49, 0x0A, 0x78, 0x01, 0x2A, 0x0A, 0xD1, 0x1F, 0x4A, 0x10, 0x68, 0x1F, 0x4A,
  0x80, 0xB2, 0x02, 0x44, 0x52, 0x00, 0x13, 0x60, 0x30, 0x22, 0x3A, 0x80, 0x0B, 0x70, 0x27, 0xE0,
  0x10, 0x23, 0x3B, 0x80, 0x07, 0x26, 0x23, 0xE0, 0xA5, 0x8A, 0xAB, 0x42, 0x8C, 0xBF, 0x02, 0x26,
  0x04, 0x26, 0x9D, 0x42, 0x28, 0xBF, 0x1D, 0x46, 0x28, 0x46, 0xA3, 0x69, 0x98, 0x47, 0x81, 0x46,
  0x00, 0x20, 0xFF, 0xF7, 0x57, 0xFE, 0x2A, 0x46, 0x01, 0x46, 0x48, 0x46, 0x00, 0xF0, 0x68, 0xFB,
  0x29, 0x46, 0x00, 0x20, 0xFF, 0xF7, 0x6A, 0xFE, 0x23, 0x8A, 0x4F, 0xF4, 0x40, 0x52, 0x5B, 0x1B,
  0x23, 0x82, 0x63, 0x8A, 0x1D, 0x44, 0x30, 0x23, 0x3B, 0x80, 0x09, 0x4B, 0x65, 0x82, 0x1A, 0x80,
  0xD8, 0xF8, 0x00, 0x30, 0x1E, 0x72, 0xBD, 0xE8, 0xF8, 0x83, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20,
  0x14, 0x03, 0x00, 0x20, 0x64, 0x0B, 0x00, 0x20, 0x50, 0x5C, 0x00, 0x40, 0x02, 0x30, 0x00, 0x20,
  0x12, 0x03, 0x00, 0x20, 0x10, 0xB5, 0x0A, 0x4B, 0x0A, 0x49, 0x1B, 0x68, 0x49, 0x78, 0x9A, 0x78,
  0x91, 0x42, 0x0A, 0xD3, 0xD9, 0x78, 0x41, 0xB9, 0x9C, 0x88, 0x34, 0xB9, 0x9A, 0x72, 0x06, 0x4B,
  0x1B, 0x68, 0x5B, 0x68, 0x98, 0x47, 0x20, 0x46, 0x10, 0xBD, 0x02, 0x20, 0x10, 0xBD, 0x00, 0xBF,
  0x44, 0x03, 0x00, 0x20, 0x90, 0x00, 0x00, 0x20, 0x40, 0x03, 0x00, 0x20, 0x38, 0xB5, 0x0E, 0x4A,
  0x0E, 0x4C, 0x12, 0x68, 0x23, 0x68, 0x92, 0x69, 0x18, 0x79, 0x99, 0x78, 0x90, 0x47, 0x23, 0x68,
  0x9A, 0x7A, 0x7A, 0xB1, 0x70, 0xB9, 0x5A, 0x79, 0x62, 0xB9, 0xDD, 0x78, 0x55, 0xB9, 0x08, 0x4B,
  0x1B, 0x68, 0xDB, 0x68, 0x98, 0x47, 0x23, 0x68, 0x28, 0x46, 0x1A, 0x79, 0xDA, 0x72, 0x9A, 0x78,
  0x1A, 0x73, 0x38, 0xBD, 0x02, 0x20, 0x38, 0xBD, 0x1C, 0x03, 0x00, 0x20, 0x44, 0x03, 0x00, 0x20,
  0x40, 0x03, 0x00, 0x20, 0x38, 0xB5, 0x2F, 0x4B, 0x1B, 0x68, 0x18, 0x78, 0x10, 0xF0, 0x7F, 0x00,
  0x04, 0xD1, 0x5A, 0x7A, 0x22, 0xF0, 0x20, 0x02, 0x5A, 0x72, 0x38, 0xBD, 0x02, 0x28, 0x4E, 0xD1,
  0x5A, 0x88, 0x00, 0x2A, 0x4C, 0xD1, 0x5A, 0x79, 0x00, 0x2A, 0x49, 0xD1, 0x1A, 0x79, 0x26, 0x4D,
  0x22, 0xF0, 0x80, 0x00, 0x84, 0x00, 0x04, 0xF1, 0x80, 0x41, 0x01, 0xF5, 0xB8, 0x41, 0x09, 0x68,
  0x2D, 0x78, 0x12, 0xF0, 0x80, 0x0F, 0x14, 0xBF, 0x01, 0xF0, 0x30, 0x01, 0x01, 0xF4, 0x40, 0x51,
  0xA8, 0x42, 0x34, 0xD2, 0x00, 0x29, 0x32, 0xD0, 0x9B, 0x7A, 0x83, 0xB3, 0x04, 0xF1, 0x80, 0x44,
  0x04, 0xF5, 0xB8, 0x44, 0x12, 0x06, 0x23, 0x68, 0x0C, 0xD5, 0x03, 0xF0, 0x30, 0x03, 0x10, 0x2B,
  0x1F, 0xD1, 0xC4, 0xB2, 0x20, 0x46, 0xFF, 0xF7, 0xA5, 0xFD, 0x20, 0x46, 0x30, 0x21, 0xFF, 0xF7,
  0x5F, 0xFD, 0x16, 0xE0, 0x03, 0xF4, 0x40, 0x53, 0xB3, 0xF5, 0x80, 0x5F, 0x11, 0xD1, 0x28, 0xB9,
  0x0E, 0x4B, 0x93, 0xF8, 0x30, 0x10, 0xFF, 0xF7, 0xCF, 0xFD, 0x01, 0xE0, 0xFF, 0xF7, 0x82, 0xFD,
  0x23, 0x68, 0x23, 0xF4, 0x80, 0x43, 0x23, 0xF0, 0x70, 0x03, 0x9B, 0xB2, 0x83, 0xF4, 0x40, 0x53,
  0x23, 0x60, 0x07, 0x4B, 0x1B, 0x68, 0x5B, 0x69, 0x98, 0x47, 0x00, 0x20, 0x38, 0xBD, 0x02, 0x20,
  0x38, 0xBD, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20, 0x90, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x20,
  0x40, 0x03, 0x00, 0x20, 0x38, 0xB5, 0x1D, 0x4B, 0x1D, 0x4D, 0x19, 0x68, 0x2D, 0x78, 0x0A, 0x79,
  0x22, 0xF0, 0x80, 0x04, 0xA3, 0x00, 0x03, 0xF1, 0x80, 0x40, 0x00, 0xF5, 0xB8, 0x40, 0x00, 0x68,
  0x12, 0xF0, 0x80, 0x0F, 0x14, 0xBF, 0x00, 0xF0, 0x30, 0x00, 0x00, 0xF4, 0x40, 0x50, 0xAC, 0x42,
  0x22, 0xD2, 0x4C, 0x88, 0x04, 0xBB, 0xF8, 0xB1, 0x89, 0x7A, 0xE9, 0xB1, 0x03, 0xF1, 0x80, 0x43,
  0x03, 0xF5, 0xB8, 0x43, 0x12, 0xF0, 0x80, 0x0F, 0x1A, 0x68, 0x07, 0xD0, 0x22, 0xF4, 0xE0, 0x42,
  0x22, 0xF0, 0x40, 0x02, 0x92, 0xB2, 0x82, 0xF0, 0x10, 0x02, 0x06, 0xE0, 0x22, 0xF4, 0x80, 0x42,
  0x22, 0xF0, 0x70, 0x02, 0x92, 0xB2, 0x82, 0xF4, 0x80, 0x52, 0x1A, 0x60, 0x05, 0x4B, 0x1B, 0x68,
  0x9B, 0x69, 0x98, 0x47, 0x00, 0x20, 0x38, 0xBD, 0x02, 0x20, 0x38, 0xBD, 0x44, 0x03, 0x00, 0x20,
  0x90, 0x00, 0x00, 0x20, 0x40, 0x03, 0x00, 0x20, 0x08, 0xB5, 0x06, 0x4B, 0x1B, 0x68, 0x5A, 0x7A,
  0x42, 0xF0, 0x20, 0x02, 0x5A, 0x72, 0x04, 0x4B, 0x1B, 0x68, 0xDB, 0x69, 0x98, 0x47, 0x00, 0x20,
  0x08, 0xBD, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20, 0x40, 0x03, 0x00, 0x20, 0x05, 0x4B, 0x1A, 0x68,
  0x53, 0x8A, 0x18, 0xB9, 0x89, 0x88, 0xCB, 0x1A, 0x13, 0x82, 0x70, 0x47, 0x08, 0x68, 0x18, 0x44,
  0x70, 0x47, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20, 0x08, 0xB5, 0x0B, 0x4B, 0x00, 0x20, 0x93, 0xF8,
  0x30, 0x10, 0xFF, 0xF7, 0x49, 0xFD, 0x09, 0x4B, 0x1B, 0x68, 0x18, 0x7A, 0x08, 0x28, 0x06, 0xD1,
  0x07, 0x4B, 0x4F, 0xF4, 0x80, 0x52, 0x1A, 0x80, 0x06, 0x4B, 0x10, 0x22, 0x1A, 0x80, 0xB0, 0xF1,
  0x09, 0x03, 0x58, 0x42, 0x58, 0x41, 0x08, 0xBD, 0x00, 0x00, 0x00, 0x20, 0x44, 0x03, 0x00, 0x20,
  0x12, 0x03, 0x00, 0x20, 0x14, 0x03, 0x00, 0x20, 0x73, 0xB5, 0x96, 0x4E, 0x96, 0x4B, 0x32, 0x68,
  0x96, 0x4D, 0x92, 0xB2, 0x13, 0x44, 0x5B, 0x00, 0x1A, 0x68, 0x2B, 0x68, 0x19, 0x7A, 0x09, 0x29,
  0x0F, 0xD0, 0x92, 0xB2, 0x52, 0x00, 0x02, 0xF1, 0x80, 0x42, 0x02, 0xF5, 0xC0, 0x42, 0x11, 0x78,
  0x19, 0x70, 0x51, 0x78, 0x59, 0x70, 0x91, 0x88, 0x59, 0x80, 0x11, 0x89, 0x99, 0x80, 0x92, 0x89,
  0xDA, 0x80, 0x01, 0x22, 0x1A, 0x72, 0xDA, 0x88, 0x5C, 0x78, 0x00, 0x2A, 0x61, 0xD1, 0x1A, 0x78,
  0x12, 0xF0, 0x7F, 0x02, 0x3A, 0xD1, 0x09, 0x2C, 0x02, 0xD1, 0xFF, 0xF7, 0xAB, 0xFE, 0x44, 0xE0,
  0x05, 0x2C, 0x0F, 0xD1, 0x93, 0xF9, 0x02, 0x20, 0x00, 0x2A, 0x01, 0xDA, 0x08, 0x23, 0x4D, 0xE0,
  0xDA, 0x78, 0x00, 0x2A, 0xFA, 0xD1, 0x9A, 0x88, 0x00, 0x2A, 0xF7, 0xD1, 0x9B, 0x7A, 0x00, 0x2B,
  0x37, 0xD0, 0xF3, 0xE7, 0x03, 0x2C, 0x13, 0xD1, 0x9A, 0x78, 0x01, 0x2A, 0x07, 0xD0, 0x78, 0x4B,
  0x20, 0x46, 0x1B, 0x68, 0x5B, 0x69, 0x98, 0x47, 0x03, 0x28, 0x28, 0xD1, 0x35, 0xE0, 0x9A, 0x88,
  0x00, 0x2A, 0xF4, 0xD1, 0x5B, 0x7A, 0x98, 0x06, 0xF1, 0xD5, 0xFF, 0xF7, 0x6D, 0xFF, 0x1C, 0xE0,
  0x01, 0x2C, 0xEC, 0xD1, 0x9A, 0x78, 0x01, 0x2A, 0xE9, 0xD1, 0x9A, 0x88, 0x00, 0x2A, 0xE6, 0xD1,
  0x5B, 0x7A, 0x99, 0x06, 0xE3, 0xD5, 0xFF, 0xF7, 0xB5, 0xFE, 0x0E, 0xE0, 0x01, 0x2A, 0x04, 0xD1,
  0x0B, 0x2C, 0xDC, 0xD1, 0xFF, 0xF7, 0x8A, 0xFE, 0x07, 0xE0, 0x02, 0x2A, 0xD7, 0xD1, 0x01, 0x2C,
  0xF1, 0xD0, 0x03, 0x2C, 0xD3, 0xD1, 0xFF, 0xF7, 0x0D, 0xFF, 0x10, 0xB1, 0xCF, 0xE7, 0x00, 0x28,
  0xBC, 0xD1, 0x32, 0x68, 0x5F, 0x4B, 0x92, 0xB2, 0x13, 0x44, 0x5B, 0x00, 0x00, 0x22, 0x1A, 0x60,
  0x5D, 0x4B, 0x30, 0x22, 0x1A, 0x80, 0x06, 0x23, 0x00, 0xE0, 0x09, 0x23, 0x2A, 0x68, 0x13, 0x72,
  0xD4, 0xE0, 0x06, 0x2C, 0x18, 0xD1, 0x1A, 0x78, 0x52, 0x06, 0x7C, 0xD1, 0xDA, 0x78, 0x54, 0x4B,
  0x01, 0x2A, 0x02, 0xD1, 0x1B, 0x68, 0xDB, 0x69, 0x6C, 0xE0, 0x02, 0x2A, 0x02, 0xD1, 0x1B, 0x68,
  0x1B, 0x6A, 0x67, 0xE0, 0x03, 0x2A, 0x02, 0xD1, 0x1B, 0x68, 0x5B, 0x6A, 0x62, 0xE0, 0x21, 0x2A,
  0x69, 0xD1, 0x1B, 0x68, 0x9B, 0x6A, 0x5D, 0xE0, 0x00, 0x2C, 0x3C, 0xD1, 0x59, 0x88, 0x00, 0x29,
  0x61, 0xD1, 0x5A, 0x68, 0x22, 0xF0, 0xFF, 0x02, 0xB2, 0xF5, 0x00, 0x3F, 0x5B, 0xD1, 0x1A, 0x78,
  0x12, 0xF0, 0x7F, 0x02, 0x04, 0xD1, 0x9B, 0x88, 0x00, 0x2B, 0x00, 0xF0, 0xAB, 0x80, 0x52, 0xE0,
  0x01, 0x2A, 0x0C, 0xD1, 0x3E, 0x4A, 0x18, 0x79, 0x12, 0x68, 0x92, 0x69, 0x90, 0x47, 0x00, 0x28,
  0x49, 0xD1, 0x2B, 0x68, 0x9B, 0x7A, 0x00, 0x2B, 0x40, 0xF0, 0x9C, 0x80, 0x43, 0xE0, 0x02, 0x2A,
  0x41, 0xD1, 0x1B, 0x79, 0x39, 0x48, 0x03, 0xF0, 0x0F, 0x01, 0x8A, 0x00, 0x02, 0xF1, 0x80, 0x42,
  0x02, 0xF5, 0xB8, 0x42, 0x12, 0x68, 0x00, 0x78, 0x13, 0xF0, 0x80, 0x0F, 0x14, 0xBF, 0x02, 0xF0,
  0x30, 0x02, 0x02, 0xF4, 0x40, 0x52, 0x81, 0x42, 0x2D, 0xD2, 0x13, 0xF0, 0x70, 0x0F, 0x2A, 0xD1,
  0x00, 0x2A, 0x7F, 0xD1, 0x27, 0xE0, 0x08, 0x2C, 0x03, 0xD1, 0x1B, 0x78, 0x5B, 0x06, 0x7B, 0xD0,
  0x21, 0xE0, 0x0A, 0x2C, 0x1F, 0xD1, 0x1A, 0x78, 0x02, 0xF0, 0x7F, 0x02, 0x01, 0x2A, 0x1A, 0xD1,
  0x9A, 0x7A, 0xC2, 0xB1, 0x59, 0x88, 0xB1, 0xB9, 0x5A, 0x68, 0x22, 0xF0, 0xFF, 0x02, 0xB2, 0xF5,
  0x80, 0x3F, 0x10, 0xD1, 0x1E, 0x4A, 0x18, 0x79, 0x12, 0x68, 0x92, 0x69, 0x90, 0x47, 0x00, 0x28,
  0x64, 0xD0, 0x08, 0xE0, 0x3B, 0xB1, 0x2A, 0x68, 0x00, 0x24, 0x54, 0x82, 0x93, 0x61, 0x20, 0x46,
  0x98, 0x47, 0x20, 0x46, 0x0A, 0xE0, 0x16, 0x4B, 0x1A, 0x68, 0x2B, 0x68, 0x12, 0x69, 0x58, 0x78,
  0x90, 0x47, 0x03, 0x28, 0x02, 0xD1, 0x11, 0x4B, 0x1B, 0x68, 0x05, 0xE0, 0x2B, 0x68, 0x4F, 0xF6,
  0xFF, 0x71, 0x1A, 0x8A, 0x8A, 0x42, 0x01, 0xD1, 0x09, 0x22, 0x03, 0xE0, 0x02, 0x28, 0x00, 0xD0,
  0x12, 0xB9, 0x08, 0x22, 0x1A, 0x72, 0x39, 0xE0, 0x93, 0xF9, 0x00, 0x10, 0x00, 0x29, 0x2F, 0xDA,
  0xD9, 0x88, 0x01, 0x91, 0x01, 0x98, 0x82, 0x42, 0x05, 0x48, 0x11, 0xD9, 0x01, 0x9A, 0x1A, 0x82,
  0x1F, 0xE0, 0x00, 0xBF, 0x50, 0x5C, 0x00, 0x40, 0x04, 0x30, 0x00, 0x20, 0x44, 0x03, 0x00, 0x20,
  0x1C, 0x03, 0x00, 0x20, 0x02, 0x30, 0x00, 0x20, 0x14, 0x03, 0x00, 0x20, 0x90, 0x00, 0x00, 0x20,
  0x8A, 0x42, 0x0E, 0xD2, 0x01, 0x68, 0x91, 0xF8, 0x30, 0x10, 0x8A, 0x42, 0x01, 0xD2, 0x00, 0x21,
  0x05, 0xE0, 0x92, 0xFB, 0xF1, 0xF4, 0x01, 0xFB, 0x14, 0x22, 0x12, 0xB9, 0x01, 0x21, 0x0C, 0x4A,
  0x11, 0x70, 0x02, 0x68, 0x92, 0xF8, 0x30, 0x20, 0x9A, 0x82, 0xFF, 0xF7, 0x2F, 0xFD, 0x05, 0xE0,
  0x03, 0x22, 0x1A, 0x72, 0x07, 0x4B, 0x4F, 0xF4, 0x40, 0x52, 0x1A, 0x80, 0xFF, 0xF7, 0x84, 0xFE,
  0x02, 0xB0, 0x70, 0xBD, 0x04, 0x4B, 0x9E, 0xE7, 0x04, 0x4B, 0x9C, 0xE7, 0x04, 0x4B, 0x9A, 0xE7,
  0x64, 0x0B, 0x00, 0x20, 0x12, 0x03, 0x00, 0x20, 0x9D, 0x10, 0x00, 0x08, 0x55, 0x10, 0x00, 0x08,
  0x79, 0x10, 0x00, 0x08, 0xF8, 0xB5, 0x2B, 0x4D, 0x2C, 0x68, 0x23, 0x7A, 0x03, 0x2B, 0x01, 0xD0,
  0x05, 0x2B, 0x41, 0xD1, 0xA3, 0x69, 0x22, 0x8A, 0xAB, 0xB1, 0xA2, 0xB1, 0xA6, 0x8A, 0x96, 0x42,
  0x28, 0xBF, 0x16, 0x46, 0x30, 0x46, 0x98, 0x47, 0x23, 0x8A, 0x07, 0x46, 0x9B, 0x1B, 0x23, 0x82,
  0x63, 0x8A, 0x00, 0x20, 0x33, 0x44, 0x63, 0x82, 0xFF, 0xF7, 0x8A, 0xFB, 0x32, 0x46, 0x01, 0x46,
  0x38, 0x46, 0x00, 0xF0, 0xA5, 0xF8, 0x23, 0x8A, 0x53, 0xB1, 0x1B, 0x4B, 0x00, 0x20, 0x4F, 0xF4,
  0x40, 0x52, 0x01, 0x46, 0x1A, 0x80, 0xFF, 0xF7, 0x89, 0xFB, 0x18, 0x4B, 0x30, 0x22, 0x1A, 0x80,
  0x23, 0x8A, 0xA2, 0x8A, 0x9A, 0x42, 0x02, 0xD8, 0x2B, 0x68, 0x03, 0x22, 0x02, 0xE0, 0x1B, 0xB1,
  0x2B, 0x68, 0x05, 0x22, 0x1A, 0x72, 0x0C, 0xE0, 0x2A, 0x68, 0x06, 0x21, 0x11, 0x72, 0x10, 0x4A,
  0x11, 0x68, 0x10, 0x4A, 0x89, 0xB2, 0x0A, 0x44, 0x52, 0x00, 0x13, 0x60, 0x0B, 0x4B, 0x30, 0x22,
  0x1A, 0x80, 0x2B, 0x68, 0x1B, 0x7A, 0x06, 0xE0, 0x07, 0x2B, 0x03, 0xD1, 0x0A, 0x4B, 0x1B, 0x68,
  0xDB, 0x68, 0x98, 0x47, 0x08, 0x23, 0x2A, 0x68, 0x13, 0x72, 0xBD, 0xE8, 0xF8, 0x40, 0xFF, 0xF7,
  0x1B, 0xBE, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20, 0x12, 0x03, 0x00, 0x20, 0x14, 0x03, 0x00, 0x20,
  0x50, 0x5C, 0x00, 0x40, 0x02, 0x30, 0x00, 0x20, 0x1C, 0x03, 0x00, 0x20, 0x30, 0xB5, 0x0B, 0x4B,
  0x1C, 0x78, 0x00, 0x23, 0xA3, 0x42, 0x0C, 0xD2, 0x03, 0xF1, 0x80, 0x52, 0x02, 0xF5, 0xB8, 0x52,
  0x91, 0x00, 0x0D, 0x68, 0x48, 0xF6, 0x8F, 0x72, 0x2A, 0x40, 0x1A, 0x43, 0x0A, 0x60, 0x01, 0x33,
  0xF0, 0xE7, 0x03, 0x4B, 0x40, 0xF0, 0x80, 0x00, 0x18, 0x60, 0x30, 0xBD, 0x90, 0x00, 0x00, 0x20,
  0x4C, 0x5C, 0x00, 0x40, 0x10, 0xB5, 0x13, 0x4C, 0x23, 0x68, 0x1A, 0x7A, 0x02, 0x2A, 0x01, 0xD0,
  0x04, 0x2A, 0x04, 0xD1, 0xFF, 0xF7, 0x8A, 0xFC, 0x23, 0x68, 0x1B, 0x7A, 0x13, 0xE0, 0x06, 0x2A,
  0x10, 0xD1, 0x5A, 0x78, 0x05, 0x2A, 0x09, 0xD1, 0x1A, 0x78, 0x52, 0x06, 0x06, 0xD1, 0x98, 0x78,
  0xFF, 0xF7, 0xCC, 0xFF, 0x08, 0x4B, 0x1B, 0x68, 0x1B, 0x6A, 0x98, 0x47, 0x07, 0x4B, 0x1B, 0x68,
  0x9B, 0x68, 0x98, 0x47, 0x08, 0x23, 0x22, 0x68, 0x13, 0x72, 0xBD, 0xE8, 0x10, 0x40, 0xFF, 0xF7,
  0xCB, 0xBD, 0x00, 0xBF, 0x44, 0x03, 0x00, 0x20, 0x40, 0x03, 0x00, 0x20, 0x1C, 0x03, 0x00, 0x20,
  0x30, 0xB5, 0x01, 0xF1, 0x00, 0x51, 0x01, 0x32, 0x01, 0xF5, 0x40, 0x51, 0x52, 0x10, 0x49, 0x00,
  0x00, 0x23, 0x93, 0x42, 0x00, 0xF1, 0x02, 0x00, 0x09, 0xD0, 0x10, 0xF8, 0x01, 0x5C, 0x10, 0xF8,
  0x02, 0x4C, 0x44, 0xEA, 0x05, 0x24, 0x21, 0xF8, 0x23, 0x40, 0x01, 0x33, 0xF1, 0xE7, 0x30, 0xBD,
  0x10, 0xB5, 0x01, 0xF1, 0x00, 0x51, 0x01, 0x32, 0x01, 0xF5, 0x40, 0x51, 0x52, 0x10, 0x49, 0x00,
  0x00, 0x23, 0x93, 0x42, 0x05, 0xD0, 0x51, 0xF8, 0x23, 0x40, 0x20, 0xF8, 0x13, 0x40, 0x01, 0x33,
  0xF7, 0xE7, 0x10, 0xBD, 0xD5, 0x04, 0x00, 0x08, 0xFD, 0x01, 0x00, 0x08, 0xBB, 0x01, 0x00, 0x08,
  0xBD, 0x01, 0x00, 0x08, 0xA5, 0x02, 0x00, 0x08, 0x49, 0x03, 0x00, 0x08, 0xBF, 0x01, 0x00, 0x08,
  0x05, 0x03, 0x00, 0x08, 0x11, 0x03, 0x00, 0x08, 0x1D, 0x03, 0x00, 0x08, 0x3D, 0x03, 0x00, 0x08,
  0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0xB9, 0x01, 0x00, 0x08, 0xB9, 0x01, 0x00, 0x08,
  0xB9, 0x01, 0x00, 0x08, 0xB9, 0x01, 0x00, 0x08, 0xB9, 0x01, 0x00, 0x08, 0xB9, 0x01, 0x00, 0x08,
  0xC9, 0x01, 0x00, 0x08, 0xCD, 0x01, 0x00, 0x08, 0xE5, 0x01, 0x00, 0x08, 0xE7, 0x01, 0x00, 0x08,
  0xE9, 0x01, 0x00, 0x08, 0xEB, 0x01, 0x00, 0x08, 0xED, 0x01, 0x00, 0x08, 0xEF, 0x01, 0x00, 0x08,
  0xF1, 0x01, 0x00, 0x08, 0x01, 0x01, 0x00, 0x00, 0xE8, 0x00, 0x00, 0x20, 0x04, 0x00, 0x00, 0x00,
  0x32, 0x01, 0x00, 0x20, 0x12, 0x00, 0x00, 0x00, 0x4C, 0x01, 0x00, 0x20, 0x14, 0x00, 0x00, 0x00,
  0x19, 0x01, 0x00, 0x20, 0x10, 0x00, 0x00, 0x00, 0x60, 0x01, 0x00, 0x20, 0x8E, 0x00, 0x00, 0x00,
  0xEE, 0x01, 0x00, 0x20, 0x84, 0x00, 0x00, 0x00, 0x72, 0x02, 0x00, 0x20, 0x84, 0x00, 0x00, 0x00,
  0x12, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x40, 0xAF, 0x1E, 0x03, 0x00, 0x01, 0x02, 0x01, 0x02,
  0x03, 0x01, 0x00, 0x00, 0x29, 0x01, 0x00, 0x20, 0x09, 0x00, 0x00, 0x00, 0x04, 0x03, 0x09, 0x04,
  0x09, 0x02, 0x2D, 0x00, 0x01, 0x01, 0x00, 0x80, 0x32, 0x09, 0x04, 0x00, 0x00, 0x00, 0xFE, 0x01,
  0x02, 0x04, 0x09, 0x04, 0x00, 0x01, 0x00, 0xFE, 0x01, 0x02, 0x05, 0x09, 0x04, 0x00, 0x02, 0x00,
  0xFE, 0x01, 0x02, 0x06, 0x09, 0x21, 0x03, 0xFF, 0x00, 0x00, 0x08, 0x10, 0x01, 0x10, 0x03, 0x4C,
  0x00, 0x4C, 0x00, 0x4D, 0x00, 0x20, 0x00, 0x30, 0x00, 0x30, 0x00, 0x33, 0x00, 0x09, 0x21, 0x03,
  0xFF, 0x00, 0x00, 0x08, 0x10, 0x01, 0x12, 0x03, 0x4C, 0x00, 0x65, 0x00, 0x61, 0x00, 0x66, 0x00,
  0x4C, 0x00, 0x61, 0x00, 0x62, 0x00, 0x73, 0x00, 0xCC, 0x00, 0x00, 0x20, 0x12, 0x00, 0x00, 0x00,
  0x14, 0x03, 0x4D, 0x00, 0x61, 0x00, 0x70, 0x00, 0x6C, 0x00, 0x65, 0x00, 0x20, 0x00, 0x30, 0x00,
  0x30, 0x00, 0x33, 0x00, 0x8E, 0x03, 0x42, 0x00, 0x6F, 0x00, 0x6F, 0x00, 0x74, 0x00, 0x6C, 0x00,
  0x6F, 0x00, 0x61, 0x00, 0x64, 0x00, 0x65, 0x00, 0x72, 0x00, 0x20, 0x00, 0x32, 0x00, 0x2E, 0x00,
  0x30, 0x00, 0x2E, 0x00, 0x72, 0x00, 0x63, 0x00, 0x31, 0x00, 0x20, 0x00, 0x45, 0x00, 0x52, 0x00,
  0x52, 0x00, 0x4F, 0x00, 0x52, 0x00, 0x2E, 0x00, 0x20, 0x00, 0x55, 0x00, 0x70, 0x00, 0x6C, 0x00,
  0x6F, 0x00, 0x61, 0x00, 0x64, 0x00, 0x20, 0x00, 0x74, 0x00, 0x6F, 0x00, 0x20, 0x00, 0x52, 0x00,
  0x41, 0x00, 0x4D, 0x00, 0x20, 0x00, 0x69, 0x00, 0x73, 0x00, 0x20, 0x00, 0x6E, 0x00, 0x6F, 0x00,
  0x74, 0x00, 0x20, 0x00, 0x73, 0x00, 0x75, 0x00, 0x70, 0x00, 0x70, 0x00, 0x6F, 0x00, 0x72, 0x00,
  0x74, 0x00, 0x65, 0x00, 0x64, 0x00, 0x2E, 0x00, 0x20, 0x00, 0x28, 0x00, 0x4D, 0x00, 0x61, 0x00,
  0x70, 0x00, 0x6C, 0x00, 0x65, 0x00, 0x2D, 0x00, 0x6D, 0x00, 0x69, 0x00, 0x6E, 0x00, 0x69, 0x00,
  0x29, 0x00, 0x84, 0x03, 0x42, 0x00, 0x6F, 0x00, 0x6F, 0x00, 0x74, 0x00, 0x6C, 0x00, 0x6F, 0x00,
  0x61, 0x00, 0x64, 0x00, 0x65, 0x00, 0x72, 0x00, 0x20, 0x00, 0x32, 0x00, 0x2E, 0x00, 0x30, 0x00,
  0x2E, 0x00, 0x72, 0x00, 0x63, 0x00, 0x31, 0x00, 0x20, 0x00, 0x55, 0x00, 0x70, 0x00, 0x6C, 0x00,
  0x6F, 0x00, 0x61, 0x00, 0x64, 0x00, 0x20, 0x00, 0x74, 0x00, 0x6F, 0x00, 0x20, 0x00, 0x46, 0x00,
  0x6C, 0x00, 0x61, 0x00, 0x73, 0x00, 0x68, 0x00, 0x20, 0x00, 0x61, 0x00, 0x64, 0x00, 0x64, 0x00,
  0x72, 0x00, 0x65, 0x00, 0x73, 0x00, 0x73, 0x00, 0x20, 0x00, 0x30, 0x00, 0x78, 0x00, 0x38, 0x00,
  0x30, 0x00, 0x30, 0x00, 0x35, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x20, 0x00, 0x28, 0x00,
  0x4D, 0x00, 0x61, 0x00, 0x70, 0x00, 0x6C, 0x00, 0x65, 0x00, 0x2D, 0x00, 0x6D, 0x00, 0x69, 0x00,
  0x6E, 0x00, 0x69, 0x00, 0x29, 0x00, 0x84, 0x03, 0x42, 0x00, 0x6F, 0x00, 0x6F, 0x00, 0x74, 0x00,
  0x6C, 0x00, 0x6F, 0x00, 0x61, 0x00, 0x64, 0x00, 0x65, 0x00, 0x72, 0x00, 0x20, 0x00, 0x32, 0x00,
  0x2E, 0x00, 0x30, 0x00, 0x2E, 0x00, 0x72, 0x00, 0x63, 0x00, 0x31, 0x00, 0x20, 0x00, 0x55, 0x00,
  0x70, 0x00, 0x6C, 0x00, 0x6F, 0x00, 0x61, 0x00, 0x64, 0x00, 0x20, 0x00, 0x74, 0x00, 0x6F, 0x00,
  0x20, 0x00, 0x46, 0x00, 0x6C, 0x00, 0x61, 0x00, 0x73, 0x00, 0x68, 0x00, 0x20, 0x00, 0x61, 0x00,
  0x64, 0x00, 0x64, 0x00, 0x72, 0x00, 0x65, 0x00, 0x73, 0x00, 0x73, 0x00, 0x20, 0x00, 0x30, 0x00,
  0x78, 0x00, 0x38, 0x00, 0x30, 0x00, 0x30, 0x00, 0x32, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00,
  0x20, 0x00, 0x28, 0x00, 0x4D, 0x00, 0x61, 0x00, 0x70, 0x00, 0x6C, 0x00, 0x65, 0x00, 0x2D, 0x00,
  0x6D, 0x00, 0x69, 0x00, 0x6E, 0x00, 0x69, 0x00, 0x29, 0x00, 0x00, 0x00, 0xEC, 0x00, 0x00, 0x20,
  0x2D, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x20, 0x00, 0x0C, 0x00, 0x20
#define BOARD_LED_PIN 33
typedef struct {
  volatile uint32 CR;
  volatile uint32 CFGR;
  volatile uint32 CIR;
  volatile uint32 APB2RSTR;
  volatile uint32 APB1RSTR;
  volatile uint32 AHBENR;
  volatile uint32 APB2ENR;
  volatile uint32 APB1ENR;
  volatile uint32 BDCR;
  volatile uint32 CSR;
} RCC_RegStruct;
typedef enum { RESET = 0, SET   = !RESET } FlagStatus, ITStatus;
typedef enum { DISABLE = 0, ENABLE  = !DISABLE} FunctionalState;
typedef enum { ERROR = 0, SUCCESS  = !ERROR} ErrorStatus;
#define BOOTLOADER_FLASH   ((uint32)0x08000000)
#define PAGE_SIZE          1024
#define SET_REG(addr,val) do { *(volatile uint32*)(addr)=val; } while(0)
#define GET_REG(addr)     (*(volatile uint32*)(addr))
#define RCC   ((uint32)0x40021000)
#define FLASH ((uint32)0x40022000)
#define RCC_CR      RCC
#define RCC_CFGR    (RCC + 0x04)
#define RCC_CIR     (RCC + 0x08)
#define RCC_AHBENR  (RCC + 0x14)
#define RCC_APB2ENR (RCC + 0x18)
#define RCC_APB1ENR (RCC + 0x1C)
#define FLASH_ACR     (FLASH + 0x00)
#define FLASH_KEYR    (FLASH + 0x04)
#define FLASH_OPTKEYR (FLASH + 0x08)
#define FLASH_SR      (FLASH + 0x0C)
#define FLASH_CR      (FLASH + 0x10)
#define FLASH_AR      (FLASH + 0x14)
#define FLASH_OBR     (FLASH + 0x1C)
#define FLASH_WRPR    (FLASH + 0x20)
#define FLASH_KEY1     0x45670123
#define FLASH_KEY2     0xCDEF89AB
#define FLASH_RDPRT    0x00A5
#define FLASH_SR_BSY   0x01
#define FLASH_CR_PER   0x02
#define FLASH_CR_PG    0x01
#define FLASH_CR_START 0x40
#define pRCC ((RCC_RegStruct *) RCC)
bool flashErasePage(uint32 pageAddr) {
  uint32 rwmVal = GET_REG(FLASH_CR);
  rwmVal = FLASH_CR_PER;
  SET_REG(FLASH_CR, rwmVal);
  while (GET_REG(FLASH_SR) & FLASH_SR_BSY) {}
  SET_REG(FLASH_AR, pageAddr);
  SET_REG(FLASH_CR, FLASH_CR_START | FLASH_CR_PER);
  /* todo: verify the page was erased */
  rwmVal = 0x00;
  return true;
bool flashErasePages(uint32 pageAddr, uint16 n) {
  while (n-- > 0) {
    if (!flashErasePage(pageAddr + 0x400 * n)) {
      return false;
  return true;
bool flashWriteWord(uint32 addr, uint32 word) {
  volatile uint16 *flashAddr = (volatile uint16 *)addr;
  volatile uint32 lhWord = (volatile uint32)word & 0x0000FFFF;
  volatile uint32 hhWord = ((volatile uint32)word & 0xFFFF0000) >> 16;
  SET_REG(FLASH_CR, FLASH_CR_PG);
  /* apparently we need not write to FLASH_AR and can
     simply do a native write of a half word */
  *(flashAddr + 0x01) = (volatile uint16)hhWord;
  *(flashAddr) = (volatile uint16)lhWord;
  rwmVal &= 0xFFFFFFFE;
  /* verify the write */
  if (*(volatile uint32 *)addr != word) {
    return false;
  return true;
void flashLock() {
  /* take down the HSI oscillator? it may be in use elsewhere */
  /* ensure all FPEC functions disabled and lock the FPEC */
  SET_REG(FLASH_CR, 0x00000080);
void flashUnlock() {
  /* unlock the flash */
  SET_REG(FLASH_KEYR, FLASH_KEY1);
  SET_REG(FLASH_KEYR, FLASH_KEY2);
/* Minimum_Source*/
void setupFLASH() {
  /* configure the HSI oscillator */
  if ((pRCC->CR & 0x01) == 0x00) {
    uint32 rwmVal = pRCC->CR;
    rwmVal |= 0x01;
    pRCC->CR = rwmVal;
  /* wait for it to come on */
  while ((pRCC->CR & 0x02) == 0x00) {}
bool writeChunk(uint32 *ptr, int size, const char *data)
  flashErasePage((uint32)(ptr));
  for (int i = 0; i < size; i = i + 4) {
    if (!flashWriteWord((uint32)(ptr++), *((uint32 *)(data + i)))) {
      return false;
  return true;
bool isNewBootloaderAlreadyInstalled()
  char *existingBootloader = (char *) BOOTLOADER_FLASH;
  int bootloaderSize=sizeof(maple_mini_boot20);
  for(int i=0;i<bootloaderSize;i++)
    if (  maple_mini_boot20[i]!= *(existingBootloader+i))
      return false;
  return true;
  char * bootloader = const_cast<char *>(maple_mini_boot20);
  int n = 0;
  bool alreadyInstalled = isNewBootloaderAlreadyInstalled();
  pinMode(BOARD_LED_PIN, OUTPUT);
  // Wait for the user to open the serial window.
  while (!(Serial.isConnected() && (Serial.getDTR() )))
    digitalWrite(BOARD_LED_PIN, !digitalRead(BOARD_LED_PIN));
    delay(1000); // Slow blink
  if (alreadyInstalled)
    Serial.print("Congratulations. You have already updated to this version of the bootloader");
    while(1);
  digitalWrite(BOARD_LED_PIN, LOW);
  Serial.println ("**************************************************************************************************");
  Serial.println ("*** This sketch will update the bootloader in the Maple Mini to the STM32duino bootloader     ****");
  Serial.println ("*** With this you can use up to 120KB of Flash and 20KB of RAM for a Sketch                   ****");
  Serial.println ("*** Uploading is also considerably faster on OSX (and possibly faster on Linux)               ****");
  Serial.println ("***        ****");
  Serial.println ("***                      Only use with Maple mini boards                                      ****");
  Serial.println ("*** WARNING. If the update fails your Maple mini may not have a functional bootloder.         ****");
  Serial.println ("***                            YOU UPDATE AT YOUR OWN RISK                                    ****");
  Serial.println ("***                         To confirm and proceed, enter Y                                   ****");
  while (Serial.read() != 'Y')
    delay(1);
  n = sizeof(maple_mini_boot20);
  setupFLASH();
  flashUnlock();
  int success = 1;
  int pages = n/PAGE_SIZE;
  int currentPage=1;
  for (int i = 0; i < n; i += PAGE_SIZE)
    int size = 0;
    uint32* chunk = (uint32 *)(BOOTLOADER_FLASH + i);
    size = n - i;
    if (size > PAGE_SIZE)
      size = PAGE_SIZE;
    if (!writeChunk(chunk, size, &bootloader[i]))
      Serial.println ();
      Serial.println ("WARNING, Update Failed!! The sketch will restart in 3 seconds and you can try to flash again");
      delay (3000);
      success = 0;
      break;
    Serial.print("Writing flash page ");Serial.print(currentPage++);Serial.print(" of ");Serial.println(pages+1);
  if (success)
    flashLock();
    Serial.println ();
    Serial.println ("Update completed successfully. - Please test by uploading a different sketch");
    while (1) {
      delay(500);
      digitalWrite(BOARD_LED_PIN, HIGH);
      delay(500);
void loop(){}
Edit.
I've just updated the code a bit, so it verifies if the version of the bootloader it had installed is the version in the sketch.
If so, it displays a message and stops.
