I made this sketch to sound a melody on a pin using a timer and an array of frequencies and periods...
HardwareTimer Timer(4);
uint8_t Pin = PB9;
bool Enabled;
long lastStart;
long Freq;
long lastFreq;
long lastConfig;
int lastCounter;
long Dura;
int counter;
uint32_t DutyCyc;
uint32_t PeriodCyc;
uint16_t Prescaler;
uint16_t Overflow;
int pista1[20][2] = {
{850 , 300 },
{0 , 50 },
{450 , 100},
int pista2[20][2] = {
{500 , 500 },
{0 , 50 },
{500 , 500},
{0 , 50 },
{0 , 50},
{0 ,50 },
{0 , 50},
int len = 20;
pinMode(Pin, PWM);
pwmWrite(Pin,0);
//delay(2000);
SoundArray(pista1);
if (millis()>=10000 & millis()<=10010) {Enabled=true;}
if (millis()>=20000 & millis()<=20010) {Enabled=true;}
void SoundArray(int (&image)[20][2]){
if (Enabled) {
long Freq = image[counter][0];
long Dura = image[counter][1];
if (Freq != lastFreq) {
if (Freq>0) {
if (Freq != lastConfig) {
ConfigTimer(Freq);
lastConfig=Freq;
Play();
} else {Mute();}
lastFreq=Freq;
lastStart=millis();
if (millis()>= (lastStart+Dura)) {
counter++;
if (counter==len) {Mute(); Enabled=false; counter=0;}
void ConfigTimer (long Freq) {
Timer.pause();
PeriodCyc = (1000000/Freq) * (F_CPU/1000000.0);
#define MAX_RELOAD ((1 << 16) - 1)
Prescaler = (PeriodCyc / MAX_RELOAD) + 1.0;
Timer.setPrescaleFactor(Prescaler);
Overflow = (PeriodCyc + (Prescaler / 2.0)) / Prescaler;
Timer.setOverflow(Overflow);
DutyCyc = Overflow/2;
Timer.refresh();
Timer.resume();
void Play() {
pwmWrite(Pin,DutyCyc);
void Mute() {
pwmWrite(Pin,0);
as a sketch it works... so I decided to make a library...
h file...
#ifndef BuzzerT_h
#define BuzzerT_h
#include "Arduino.h"
class BuzzerT{
private:
public:
{850 , 300 },
{0 , 50 },
{450 , 100 },
{200 , 1500 },
{0 , 50 },
{700 , 500 },
{0 , 50 },
{134 , 50 },
{0 , 50 },
{150 , 50 },
uint8_t Enabled;
HardwareTimer *TIMER;
int *image[20][2] ={};
uint8_t Pin;
unsigned long lastStart;
int Freq;
int Dura;
int lastFreq;
int lastConfig;
uint8_t counter;
uint8_t lastCounter;
uint32_t DutyCyc;
uint32_t PeriodCyc;
uint16_t Prescaler;
uint16_t Overflow;
BuzzerT(uint8_t Pin, int (&image)[20][2], uint8_t Enabled);
void SoundArray();
void ConfigTimer(int Freq);
void Mute();
void Play();
cpp file:
#include "BuzzerT.h"
BuzzerT::BuzzerT(uint8_t Pin, int (&image)[20][2], uint8_t Enabled) {
this->Pin = Pin;
this->Enabled = Enabled;
this->image[20][2] = &image[20][2];//<<-------- not working!
pinMode(Pin, PWM);
TIMER = new HardwareTimer(4);
Mute();
void BuzzerT::SoundArray(){
//Serial.print("Enabled "); Serial.println(String(Enabled));
if (Enabled) {
Freq = (int)image[counter][0];
Serial.print("Freq ");Serial.println(String(Freq));
Dura = (int)image[counter][1];
Serial.print("Dura ");Serial.println(String(Dura));
if (Freq>0) {
ConfigTimer(Freq);
lastConfig=Freq;
Play();
} else {Mute();}
lastFreq=Freq;
lastStart=millis();
counter++;Serial.println(String(counter));
if (counter==20) {Mute(); Enabled=false; counter=0;}
void BuzzerT::ConfigTimer(int Freq){
TIMER->pause();
PeriodCyc = (1000000/Freq) * (F_CPU/1000000.0);// ciclos por us del STM32
#define MAX_RELOAD ((1 << 16) - 1)//timer 16 bits resolution
TIMER->setPrescaleFactor(Prescaler);
TIMER->setOverflow(Overflow);
TIMER->refresh();
TIMER->resume();
void BuzzerT::Mute(){pwmWrite(Pin,0 );}
void BuzzerT::Play(){pwmWrite(Pin,DutyCyc);}
the problem is that the pointer to the array inside the library I want to use for each sound is not getting the data correctly, so I think the problem is in this line:
this->Pin = Pin;
pinMode(Pin, PWM);
Mute();
https://mega.nz/file/4Oxn2aoB#Nf-Vfqid2 ... GJ0BO4F1Yc
Help please!
