Install STM32duino on Raspbian?
All distros
Re: Install STM32duino on Raspbian?
Post by Rick Kimball » Tue Jun 27, 2017 3:15 pm
GianniDPC
Post by GianniDPC » Tue Jun 27, 2017 3:31 pm
Ok, almost there.. now I get an error after compilation, so I it can't upload to the board..
The error in the picture below is in dutch, but it translates to "Can't execute wrong executable file"
http://imgur.com/a/9hNlv
Post by Rick Kimball » Tue Jun 27, 2017 3:49 pm
You are failing because it is trying to run an intel executable on an arm processor. You need to replace the intel binaries with arm binaries. That means compiling the source and putting the exectuables in the right place.
... or
You change to the upload method to "Mass Storage" , recompile and copy the .bin file it creates in /tmp/arduino_build_xxxx/sketchname.ino.bin and copy it to NODE_R091RC disk.
GianniDPC
Post by GianniDPC » Tue Jun 27, 2017 4:11 pm
... or
Well https://github.com/rogerclarkmelbourne/ ... /pull/283 is a ARMv7 version, I tried this one now but it gives me the following error. It's says it can't find the shared libraries but they are in home/pi/Arduino/hardware/stm/tools/linux/stlink/st-flash/lib
/home/pi/Arduino/hardware/stm/tools/linux/stlink/st-flash: error while loading shared libraries: libstlink-shared.so.1: cannot open shared object file: No such file or directory
Post by Rick Kimball » Tue Jun 27, 2017 5:20 pm
Did you try recompiling and installing the massStorageCopy source and do a make install? The source is in the tools directory. That is a very simple program. All it does is find the mount point of the NUCELO-F091RC and copies the sketchname.bin file to it.
Post by ag123 » Tue Jun 27, 2017 6:07 pm
it would seem to me that there isn't any arm-none-gcc/g++ compiler tool chain on arm platform itself isn't it?
https://developer.arm.com/open-source/g ... /downloads
Post by Rick Kimball » Tue Jun 27, 2017 6:17 pm
Wouldn't that be ironic :)
ddrown
Post by ddrown » Tue Jun 27, 2017 9:08 pm
I don't see the libraries in #283, but if they're in .../stlink/st-flash/lib, try adding one line near the top of tools/rpi/stlink_upload:
#!/bin/bash
export LD_LIBRARY_PATH=$(dirname $0)/stlink/st-flash/lib/
$(dirname $0)/stlink/st-flash write "$4" 0x8000000
GianniDPC
Post by GianniDPC » Wed Jun 28, 2017 11:32 am
#!/bin/bash
I still get the same error. And yes the libraries are not included in the pull request, but I copied the ones from the linux folder.
Post by Rick Kimball » Wed Jun 28, 2017 12:13 pm
Which raspberry pi are you using?
Why haven't you tried the mass storage approach yet? It doesn't seem like you are using the debug features of the stlink. The whole idea of putting a mass storage device as the upload method on the nucleo boards was to make it simple to use with no extra drivers required.
