DFU ubuntu 17.04
All distros
rsc
DFU ubuntu 17.04
Post by rsc » Tue Oct 10, 2017 9:41 pm
Hi, I read the mayority of post and I not solution my problem, sometimes upload and sometimes not, what I do wrong?
I flash the bootloader on flash demonstrator(windows) I work on ubuntu 17.04 64 bit, dfu-util 0,8 installed,
Re: DFU ubuntu 17.04
Post by RogerClark » Tue Oct 10, 2017 11:26 pm
Did you run the install.sh to set the udev rules ?
rsc
Post by rsc » Wed Oct 11, 2017 1:41 am
yes
ATTRS{idProduct}=="1001", ATTRS{idVendor}=="0110", MODE="664", GROUP="dialout"
ATTRS{idProduct}=="1002", ATTRS{idVendor}=="0110", MODE="664", GROUP="dialout"
ATTRS{idProduct}=="0003", ATTRS{idVendor}=="1eaf", MODE="664", GROUP="dialout" SYMLINK+="maple", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idProduct}=="0004", ATTRS{idVendor}=="1eaf", MODE="664", GROUP="dialout" SYMLINK+="maple", ENV{ID_MM_DEVICE_IGNORE}="1"
Post by RogerClark » Wed Oct 11, 2017 3:08 am
Did you select the serial device ?
Is the serial device appearing at all ?
Note. If you downloaded the bootloader from a few months ago, it did not originally enumerate as a serial device before you uploaded your first sketch
This is because the bootloader is only the DFU device, and the Serial (or other USB e.g. HID ) devices are created as part of the sketch, as part of the core (even if you don't call Serial.begin())
But a lot of people found this confusing, so I updated the bootloader to contain a dummy sketch that does some Serial.print()'s
Hence, if you have just installed the bootloader, and open the Serial Monitor, you should see it spitting out messages
If you don't see that, you have not selected the correct Serial port, or the bootloader is not working correctly
rsc
Post by rsc » Wed Oct 11, 2017 4:58 am
using stm32flash to upload bootloader(on linux) and then open serial monitor:
but when I try to upload "blink" I get the same error as shown in first image
rsc
Post by rsc » Wed Oct 11, 2017 5:19 am
when i press reset button and immediately upload sketch and then reset again, it run, but i don't understand why, BOOT0 and BOOT1 are low
Post by RogerClark » Wed Oct 11, 2017 6:21 am
Boot0 and Boot1 are used to upload the bootloader using a USB to Serial adaptor.
Once the USB bootloader is installed, Boot0 and 1 need to be set back to low to prevent the MCU entering its internal Serial bootloader
What appears to be happening in your case is that the IDE is not sending the signal to the sketch to tell it to reboot into the bootloader, ready for upload.
However I'm not a linux user so someone else will need to help you debug what you are doing wrong
Ahmad
Post by Ahmad » Sat Oct 14, 2017 6:31 pm
Do you set serial port permission ?
https://www.arduino.cc/en/Guide/Linux#toc6
rsc
Post by rsc » Sun Oct 15, 2017 12:52 am
I set permission, now reset the board but not upload
Post by RogerClark » Sun Oct 15, 2017 7:14 am
Turn on verbose logging for compile and upload and post the output here, otherwise we have no idea what your system is doing
