Extended Code Size while migrating from Arduino ProMini board to STM32 Maple-Mini board.
Re: Extended Code Size while migrating from Arduino ProMini board to STM32 Maple-Mini board.
Post by Rick Kimball » Mon Oct 24, 2016 9:28 pm
RogerClark wrote: Initialisation of variables in global scope is always problematic, because the order in which things are setup is not defined in the C specification.
Actually using static variables in functions is a way of controlling the order of initialization.
https://isocpp.org/wiki/faq/ctors#static-init-order
https://isocpp.org/wiki/faq/ctors#stati ... -first-use
$ cat check_order.cpp
/* vim: set tabstop=4 shiftwidth=4 autoindent
#include <stdio.h>
#include <stdint.h>
int callme1() {
    fputs("in callme1\n",stderr);
    return 1;
void XYZ() {
    fputs("in XYZ\n",stderr);
void ABC() {
    static int foobar = callme1();
    fputs("in ABC\n",stderr);
int main(void)
    fputs("in main\n",stderr);
    XYZ();
    ABC();
$ make check_order
g++     check_order.cpp   -o check_order
$ ./check_order
in main
in XYZ
in callme1
in ABC
if the variable had been a global static variable, then yes the ctor would have been called by the c startup code in some random order.
Post by RogerClark » Mon Oct 24, 2016 9:49 pm
Rick
My mistake
I thought that code was in global scope
I'll update my post.
I shouldnt post before my first cup of coffee in the morning ;-)
Post by RogerClark » Mon Oct 24, 2016 9:57 pm
Rick
Any idea when the compiler would actually assign the variable that is calling millis() ?
Is this when the function is first called, or as part of global init.
If its global init, then calling millis() is going to be problematic - and probably pointless as its always going to be zero
Post by Rick Kimball » Tue Oct 25, 2016 12:17 am
It falls under the first use rule I posted above
umerocks
Post by umerocks » Wed Oct 26, 2016 4:02 pm
Looking at the code again, perhaps the code is just an example rather than the real code, as the variable names seem strange.
i.e not real names of things.
Yes Roger, you are right, its just an example code that i mentioned and the variable names are for an example aswel.
Post by RogerClark » Wed Oct 26, 2016 8:11 pm
Ok.
Thanks.
