I2C hardwire library communication between 2 (two) stm32 maple mini
Re: I2C hardwire library communication between 2 (two) stm32 maple mini
Post by mrburnette » Sat Dec 10, 2016 3:06 pm
konczakp wrote:<...>I used to work with i2c communication protocol on arduino using wire library but I cannot get this working on maple and hardwire. (I'm using hardwire library because wire library was not working with BMP085).<...>
Strange... Worked last year:
https://www.hackster.io/rayburne/oled-t ... -10-b81b28
 Using Display: http://www.ebay.com/itm/301504841805
 Compiled Arduino GUI 1.7.0 on 2015-04-04 by M. Ray Burnette - PUBLIC DOMAIN excepting libs: see Licenses.h
    Sketch uses 28,456 bytes (26%) of program storage space. Maximum is 108,000 bytes.
    Global variables use 5,816 bytes of dynamic memory.
#include <SPI.h>
#include <Streaming.h>
#include ".\Adafruit_GFX.h"
#include ".\Adafruit_SSD1306.h"
#include ".\BMP085.h" // #include "I2Cdev.h" is pulled in also
// These pin #'s are for Maple Mini
//     __Signal__Maple_//__OLED 128x64___
#define OLED_CS   14   //   ---   x Not Connected
#define OLED_DC   22   //   D/C   pin# 6
#define OLED_RST  21   //   RST   pin# 5
#define OLED_MOSI 20   //   SDA   pin# 4
#define OLED_CLK  19   //   SCL   pin# 3
Adafruit_SSD1306 OLED(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RST, OLED_CS);  // OLED object
BMP085 barometer;                                                        // barometer object
int hPa10, Fah10;                                    // used for Nokia LCD integer to character - faux decimal place
int localCorrect = 3400;                             //  +/- hPa*100 to correct for local altitude: 100X delta:  3400== Briscoe Field, Ga
float temperature;
float pressure;                                      // How many hPa in 1 mm Hg? The answer is 1.3332239
float inHg;
float mmhg_conversion= 3386.388140071641;            // convert hPa to inches Hg
float altitude;
int32_t lastMicros;
byte error, address        = 77;                     // I2C address specific to BMP180
unsigned long TimeMarker;
unsigned long PlotTime;                              // trigger point to store Barometric reading
const unsigned long GraphResponsemS = 540000 ;       // 9 minutes per array element,  9*80 = 720 minutes = 12 hours total
boolean Imperial = false;
void setup()   {
  pinMode (17, OUTPUT); digitalWrite(17, LOW);       // BMP180 "Gnd"
  pinMode (18, OUTPUT); digitalWrite(18, HIGH);      // BMP180 "Vcc"
  OLED.begin(SSD1306_SWITCHCAPVCC);                  // generate OLED HV on module!
  OLED.display();                                    // Splash screen == all blanks or Logo if present
  OLED.clearDisplay();                               // Clear the buffer, blank screen
  OLED.setTextColor(WHITE);                          // defaults to BLACK background
  // OLED.setCursor(0,16);                           // top-left of Blue Pixels (15 is blank-line separator)
  // OLED.setTextSize(1);                            // 21 char/line (fills 1st & 2nd lines in yellow) 8 lines Max
  // OLED.setTextSize(2);                            // 10 char/line (fills 1st line in yellow)        4 lines Max
  // OLED.setTextSize(3);                            //  7 char/line (overflows 1st yellow into Blue)
  OLED.setCursor(0, 0);
  OLED.print("Ver.150403");                          // .print writes into SRAM buffer
  OLED.display();                                    // .display() sends buffer to OLED
  Wire.begin();
  barometer.initialize();                            // I2C Stuff for barometer
  Wire.beginTransmission(address);                   // <       ditto       >
  error = Wire.endTransmission();
  if(barometer.testConnection())
    OLED.println("I2C: OK");
  } else {
    OLED.println("IC2: Fail");
    for(;; ) {;}                                     // Error with infinite loop
  OLED.println("");
  OLED.println(" by: Ray Burnette");
  OLED.print("  Barometric Pres. &   Temperature");
  OLED.display();
  // Y = 15 is the Blank Line between yellow / blue
martinayotte
Post by martinayotte » Sat Dec 10, 2016 3:11 pm
konczakp wrote:because when I use i2c hardwire scanner example it is only showing me my BMP085 and nothing else.
Of course, as I said earlier "But it seems that Slave isn't very implemented on STM32.", so your code is not acting as a Slave ...
konczakp
Post by konczakp » Sat Dec 10, 2016 6:40 pm
#include <HardWire.h>
HardWire HWire(1, I2C_FAST_MODE); // I2c1
  HWire.begin(4);
  while(1 < HWire.available()) // loop through all but the last
    char c = HWire.read(); // receive byte as a character
    Serial.print(c);         // print the character
  int x = HWire.read();    // receive byte as an integer
  Serial.println(x);         // print the integer
What else than this is needed ? Because the above is not acting as a slave :/
