Two STM32 Nucleo G071RB boards communicate via I2C issue.
nathankuo0821
Post by nathankuo0821 »
Hello everyone,
I have two identical STM32 Nucleo G071RB boards. I want to establish communication between them using I2C, with Board one acting as the I2C master and Board two as the I2C slave. The current issue is that the I2C scanner sample code successfully detects the passive sensor when configured as an I2C master. However, whenconfigured as an I2C slave, it cannot be detected by the I2C master. Below is my code.
I2C master
#include <Arduino.h>
#define I2C1_SCL PB8
#define I2C1_SDA PB9
  Wire.setSDA(I2C1_SDA);
  Wire.setSCL(I2C1_SCL);
  Wire.begin();
  byte error, address;
  int nDevices;
  nDevices = 0;
  for (address = 1; address < 127; address++)
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
      nDevices++;
    else if (error == 4)
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
  if (nDevices == 0)
    Serial.println("No I2C devices found");
  else
    Serial.println("done");
  delay(2000); // wait 5 seconds for next scan
I2C Slave
#define I2C_ADDR 0x40
void slaveWrite()
  Wire.write("hello\n"); // respond with message of 6 bytes
                          // as expected by master
void slaveRead(int howMany)
  while (1 < Wire.available()) // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print(c);       // print the character
  int x = Wire.read(); // receive byte as an integer
  Serial.println(x); // print the integer
  Wire.begin(I2C_ADDR );
  Wire.onRequest(slaveWrite); // register event
  Wire.onReceive(slaveRead);  // register event
by fpiSTM » Tue Dec 19, 2023 8:14 am
Do you have pullup in each i2c lines?
Re: Two STM32 Nucleo G071RB boards communicate via I2C issue.
nathankuo0821
Thank you for your advice. It is now working.
