Red Pill or Blue Pill?
stanleyseow
Re: Red Pill or Blue Pill?
Post by stanleyseow » Sun Sep 24, 2017 3:10 pm
The red pill and blue pill use the same pinouts. You shouldn't have to do anything. They are completely interchangeable.
Thanks .. I just notice that they are the same pinout, so for the Blue Pill, I will have to do the "R10" operation like before ??
Stanley
9W2SVT / N5SVT
Post by Rick Kimball » Sun Sep 24, 2017 3:57 pm
If you are asking do you have to worry about the PA12 pullup resistor with the red pill board, then no. The red pill boards I have ordered all had the proper 1k5 resistor. Just try it. I'm guessing it will just work.
stanleyseow
Post by stanleyseow » Tue Oct 31, 2017 4:25 pm
We are able to order like 30 pcs of red pill from taobao easily ...
Here is the picture of the red pill with my version of MMDVM HAT ...
ImageSVT MMDVM HAT by stanley_seow, on Flickr
Stanley
9W2SVT / N5SVT
visinet
Post by visinet » Sat Nov 11, 2017 11:29 pm
Can you please post link to where you got them? I cant find the red pill on Taobao for the life of me.
Thanks a bunch
Post by RogerClark » Sun Nov 12, 2017 9:02 am
I'm not sure why you would want a Red Pill, apart from the colour.
AFIK they are functionally equivalent to the Blue Pill
A better option now seems to be the Robot Dyn version which has a black coloured PCB, and has the correct USB pullup resistor (unlike the Blue and Red pill which both have the incorrect resistor resulting in USB connection issues for some people)
Post by Rick Kimball » Sun Nov 12, 2017 9:56 am
roger the pull up on the red pills are fine.
Post by RogerClark » Sun Nov 12, 2017 10:48 am
Thanks...
All my red pills have broken USB connectors, so I am still not sure if they are worth buying unless they now use a stronger usb connector
Post by Pito » Sun Nov 12, 2017 11:53 am
There are BluePills with 2 pads- or 4 pads-style microusb sockets.
I've been ordering only the 4 pads ones.
The 4 pads ones come in two variants:
1. soldered to the pcb - sometimes not well enough
2. weakly soldered, the mechanical connection to the pcb done by pressing the fins into the mounting holes and soldered with a tiny amount of solder.
As the microusb connectors create a much bigger insertion force on the socket (in comparison with mini usb used in MM) the 4 pads in both 1. and 2. need to be resoldered with a large blob of tin such the pads and the adjacent body (the walls) of the socket are covered by the tin.
That improves the mechanical and electrical durability.
Sun Nov 12 13-07-03.jpg (56.58 KiB) Viewed 220 times
Sun Nov 12 13-06-18.jpg (58.9 KiB) Viewed 220 times
Sun Nov 12 13-17-51.jpg (46.28 KiB) Viewed 213 times
Post by Rick Kimball » Sun Nov 12, 2017 2:33 pm
That is exactly the problem. It also the reason I penned this redpill vs bluepill post in the first place. I have 5 red pills with perfectly good pullup and usb connectors that have snapped off : (
Post by RogerClark » Sun Nov 12, 2017 7:01 pm
@Pito
I do the same thing... Solder the BluePill through holes on the connector to make it stronger
