Red Pill or Blue Pill?
Re: Red Pill or Blue Pill?
Post by stevestrong » Sat Apr 08, 2017 8:48 am
Check the soldering of the USB connectors.
Also, you should first erase the whole flash and then burn the STM32duino bootloader.
It should work after these steps.
X-death
Post by X-death » Sat Apr 08, 2017 8:27 pm
STM32duino bootloader seems to works but when it's load my program usb failed.
Post by stevestrong » Sat Apr 08, 2017 8:55 pm
Which method do you use to upload?
Usb serial should work if you use srm32duino bootloader method.
X-death
Post by X-death » Sat Apr 15, 2017 10:28 am
When the bootlaoder is active i can use it for upload my own bin , it's works fine.
But when it's switch onto my own program the USB HID don't works...
SukkoPera
Post by SukkoPera » Sat Apr 15, 2017 11:21 pm
Got myself a couple of Black Pills, I can confirm that https://raw.githubusercontent.com/roger ... 0_pb12.bin works nicely.
I have noticed that the CDC Serial does not wait for connection like it does on the Leonardo though, if I do the usual:
 while (!Serial)
The program just goes on as if Serial was actually open, but it isn't. Is this normal? Does it happen with other STM32 boards too?
Post by Pito » Sun Apr 16, 2017 6:19 am
Try
while(!Serial.available());
or
while (!Serial) { SysCall::yield()};
with SdFat lib.
Post by stevestrong » Sun Apr 16, 2017 9:18 am
For the USB serial we have:
while ( !Serial.isConnected() ) ;
SukkoPera
Post by SukkoPera » Sun Apr 16, 2017 5:44 pm
@Pito: Those are different things
@stevestrong: That works fine, thanks! But then this is a deviation from the Arduino API, why?
Post by victor_pv » Sun Apr 16, 2017 11:34 pm
SukkoPera wrote:@Pito: Those are different things
The arduino API changes all the time, I bet when leaflabs added that function to libmaple there was no equivalent in the arduino API.
You can add the function to the corresponding file and submit a PR to Roger's repo, so it's available going forward.
Post by stevestrong » Mon Apr 17, 2017 7:34 am
I have not seen any platform on which while ( !Serial ) ; actually works as expected (wait till serial connection is established).
