SPI1 and SPI2 speed
michael_l
SPI1 and SPI2 speed
Post by michael_l » Thu Oct 27, 2016 12:30 pm
What's the default speed for SPI1 and SPI2 ?
How can I change the speed of SPI2 to, say, 8MHZ ? Thanks.
Vassilis
Re: SPI1 and SPI2 speed
Post by Vassilis » Thu Oct 27, 2016 5:58 pm
The SPI1 works on APB2 (72 MHz). The maximum frequency that works the SPI1 is 72/2 =36 MHZ.
The SPI2 works on APB1 (36 MHz). The maximum frequency that works the SPI2 is 36/2 =18 MHZ.
You can use the setClockDivider(select_divider) function to reduce the SPI clock
The available dividers are:
SPI_CLOCK_DIV2
SPI_CLOCK_DIV4
SPI_CLOCK_DIV8
SPI_CLOCK_DIV16
SPI_CLOCK_DIV32
SPI_CLOCK_DIV64
SPI_CLOCK_DIV128
SPI_CLOCK_DIV256
Using the SPI1 at 4.5MHz:
SPI.setClockDivider(SPI_CLOCK_DIV16); // (72 MHz / 16 = 4.5MHz)
Using the SPI2 at 4.5MHz:
SPIClass SPI_2(2); //Create an instance of the SPI Class called SPI_2 that uses the 2nd SPI Port
SPI_2.setClockDivider(SPI_CLOCK_DIV8);  // (36 MHz / 8 = 4.5MHz)
I hope it helps!
Ollie
Post by Ollie » Thu Oct 27, 2016 11:17 pm
With those higher speeds, you should design the software structure properly for time critical applications. My recommendation is to use interrupts for the SPI address and command data and after that DMA for the bulk data transfer.
Cheers, Ollie
michael_l
Post by michael_l » Fri Oct 28, 2016 6:37 am
Thanks for help!
I'm also looking for examples on how to use SPISettings "correctly" for sharing the same bus between several devices.
EDIT: found something here http://www.dorkbotpdx.org/blog/paul/bet ... in_3_steps
So the idea here seems to be that transaction support is done into the library and library contains SPISettings.
ted
Post by ted » Mon Jan 01, 2018 1:34 am
It is possible to divide by 100 ?
Post by victor_pv » Mon Jan 01, 2018 8:03 pm
No. the dividers are the ones listed in Vasilis post. That's a hardware setting.
