Problem with IR Remote Control
robert94
Post by robert94 » Mon Nov 28, 2016 10:03 am
Has anyone worked with IR Remote Control??? :?:
I have a problem with it. :(
#include <IRremote.h>
int RECV_PIN = PA0;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
  delay(100);
problem: C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-master\IRremote.cpp:123:5: error: expected constructor, destructor, or type conversion before '(' token
ISR (TIMER_INTR_NAME)
someone please help me!!! :cry:
zoomx
Re: Problem with IR Remote Control
Post by zoomx » Mon Nov 28, 2016 5:44 pm
Unfortunately I never used IRremote with an STM32. I believe that this library uses timers so you have to adapt it to STM32 architecture.
Post by RogerClark » Mon Nov 28, 2016 10:39 pm
Guessing based on the file names in the output you posted, I think the library you are using is AVR only.
https://github.com/z3t0/Arduino-IRremote
Well, its supposed to work on Teensy as well, so Paul has probably added some Teensy specific stuff into it as well, but it doesnt support any Arduino ARM based boards.
Looking in the code for the word Teensy I can see there are some #ifdefs for stuff like __MK20DX128__ which I think is where the Teensy specific changes have been incorporated.
So you would need to go though the library and port it to ARM in general and STM32 in specific by adding in some more ifdefs and changing whatever is necessary
Or find a IR library that already works on ARM (e.g. Arduino Due or Zero) and modify that version to work with STM32
robert94
Post by robert94 » Fri Dec 02, 2016 8:54 am
RogerClark wrote:find a IR library that already works on ARM (e.g. Arduino Due or Zero) and modify that version to work with STM32
so i find library work with Arduino Due: https://github.com/enternoescape/Arduino-IRremote-Due
but still problem:
#include <IRremote2.h>
int RECV_PIN = 11;
problem is:
Arduino: 1.6.13 (Windows 7), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), Serial"
In file included from C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:20:0:
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp: In member function 'void IRsend::mark(int)':
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:262:31: error: 'TCCR2A' was not declared in this scope
 #define TIMER_ENABLE_PWM     (TCCR2A |= _BV(COM2B1))
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:283:3: note: in expansion of macro 'TIMER_ENABLE_PWM'
   TIMER_ENABLE_PWM; // Enable pin 3 PWM output
In file included from C:\Users\Robert\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\cores\maple/Arduino.h:30:0,
                 from C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.h:14,
                 from C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:19:
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:262:45: error: 'COM2B1' was not declared in this scope
C:\Users\Robert\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\cores\maple/wirish.h:99:25: note: in definition of macro '_BV'
 #define _BV(bit) (1 << (bit))
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp: In member function 'void IRsend::space(int)':
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:263:31: error: 'TCCR2A' was not declared in this scope
 #define TIMER_DISABLE_PWM    (TCCR2A &= ~(_BV(COM2B1)))
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:291:3: note: in expansion of macro 'TIMER_DISABLE_PWM'
   TIMER_DISABLE_PWM; // Disable pin 3 PWM output
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:263:47: error: 'COM2B1' was not declared in this scope
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp: In member function 'void IRsend::enableIROut(int)':
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:265:31: error: 'TIMSK2' was not declared in this scope
 #define TIMER_DISABLE_INTR   (TIMSK2 = 0)
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:312:3: note: in expansion of macro 'TIMER_DISABLE_INTR'
   TIMER_DISABLE_INTR; //Timer2 Overflow Interrupt
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:269:3: error: 'TCCR2A' was not declared in this scope
   TCCR2A = _BV(WGM20); \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:324:3: note: in expansion of macro 'TIMER_CONFIG_KHZ'
   TIMER_CONFIG_KHZ(khz);
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:269:16: error: 'WGM20' was not declared in this scope
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:270:3: error: 'TCCR2B' was not declared in this scope
   TCCR2B = _BV(WGM22) | _BV(CS20); \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:270:16: error: 'WGM22' was not declared in this scope
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:270:29: error: 'CS20' was not declared in this scope
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:271:3: error: 'OCR2A' was not declared in this scope
   OCR2A = pwmval; \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:272:3: error: 'OCR2B' was not declared in this scope
   OCR2B = pwmval / 3; \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp: In member function 'void IRrecv::enableIRIn()':
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:341:9: error: 'cli' was not declared in this scope
     cli();
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:284:3: error: 'TCCR2A' was not declared in this scope
   TCCR2A = _BV(WGM21); \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:347:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL'
   TIMER_CONFIG_NORMAL();
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:284:16: error: 'WGM21' was not declared in this scope
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:285:3: error: 'TCCR2B' was not declared in this scope
   TCCR2B = _BV(CS21); \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:285:16: error: 'CS21' was not declared in this scope
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:286:3: error: 'OCR2A' was not declared in this scope
   OCR2A = TIMER_COUNT_TOP / 8; \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:287:3: error: 'TCNT2' was not declared in this scope
   TCNT2 = 0; \
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:264:31: error: 'TIMSK2' was not declared in this scope
 #define TIMER_ENABLE_INTR    (TIMSK2 = _BV(OCIE2A))
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:350:3: note: in expansion of macro 'TIMER_ENABLE_INTR'
   TIMER_ENABLE_INTR;
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremoteInt2.h:264:44: error: 'OCIE2A' was not declared in this scope
   TIMER_ENABLE_INTR;
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:355:7: error: 'sei' was not declared in this scope
   sei();  // enable interrupts
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp: At global scope:
C:\Users\Robert\Documents\Arduino\libraries\Arduino-IRremote-Due-master\IRremote2.cpp:384:4: error: expected constructor, destructor, or type conversion before '(' token
 ISR(TIMER_INTR_NAME)
exit status 1
Error compiling for board Generic STM32F103C series.
so what i have to do???
help me RogerClark :cry:
zoomx
Post by zoomx » Mon Dec 05, 2016 5:33 pm
Start from here
http://www.stm32duino.com/viewtopic.php ... =10#p12597
and go on.
It is not a solution, unfortunately, just some links.
I believe that maybe the solution found for tone can be used here.
Edit: some other links
https://www.youtube.com/watch?v=Ow5NHWXY4D0 and code here https://vk.com/akoe_ru?w=wall-51756903_860%2Fall
for STMf103x
Application note AN3174 by ST
http://www.st.com/content/ccc/resource/ ... 267896.pdf
These for F4 family
https://github.com/MatejGomboc/IRremote-STM32
http://www.playembedded.org/blog/it/201 ... e-chibios/ This is in italian.
http://www.playembedded.org/blog/en/201 ... g-chibios/ the same in english
If you want to use cube-mx
http://www.st.com/content/st_com/en/pro ... emote.html
41300895
Post by 41300895 » Wed Feb 01, 2017 7:32 am
Does anyone has the IR remote arduino library compatible with stm32f103?
If yes, please share, thanks alot
Dimdim
Post by Dimdim » Sat Mar 04, 2017 6:36 pm
Check out the IR code section of HiFiDuino's code: https://hifiduino.wordpress.com/code/
It works just fine on the STM32duino with any remote that uses the NEC protocol.
Post by RogerClark » Sat Mar 04, 2017 8:49 pm
Dimdim wrote:Check out the IR code section of HiFiDuino's code: https://hifiduino.wordpress.com/code/
Thanks for posting. I recall a few people have been building IR projects recently.
rexnanet
Post by rexnanet » Tue Apr 11, 2017 9:49 am
I found one that seems to be working ok.
https://github.com/karawin/irmp-master
https://www.youtube.com/watch?v=R5umRl1Z8jc
Haven't tested it but on the video it's working on the BluePill :)
EDIT: The author already announced it here : http://www.stm32duino.com/viewtopic.php ... e&start=30
