Update Bluepill wiki data
michael_l
Re: Update Bluepill wiki data
Post by michael_l » Fri Dec 02, 2016 12:55 pm
zmemw16 wrote:and if i add the same disclaimer?
without opening a bag of worms isn't that in the gpl; v2 & v3
re 10K - just lack of reading or understanding on their part?
Well, I guess to me it is not clear what 'usb to work properly" means. But that's just me..
Post by zmemw16 » Fri Dec 02, 2016 1:03 pm
i was referring to the usage of 4k7 or 10k, not usb.
however in order for usb host system to re-enumerate the usb, experience suggests a better value to use would 1k5 or 1k8 in parallel with the 10k, the value for use with a 4k7 is left as an exercise for the reader.
i don't know what the usb specification says.
Post by Rick Kimball » Fri Dec 02, 2016 2:16 pm
zmemw16 wrote:i don't know what the usb specification says.
From the stm32f103c8 datasheet:
edogaldo
Post by edogaldo » Fri Dec 02, 2016 4:12 pm
testato wrote: Seems that all the F103C8 work on 128KB, for now nobody come here for tell that he have a board that do not work on 128KB
viewtopic.php?t=1323&start=20#p18962
Cheers, E.
testato
Post by testato » Fri Dec 02, 2016 6:36 pm
michael_l wrote: Well, I guess to me it is not clear what 'usb to work properly" means. But that's just me..
I agree with you, it is not clear, so i changed the wiki to this if @Roger agree
The USB standard require a 1.5k pullup resistor on D+, but this board is known to have a wrong value (R10 on the board). It ships with either a 10K resistor or a 4.7k resistor, but it should be replaced with a 1.5k resistor, or put an appropriate resistor value (e.g 1.8k) in between PA12 and 3.3V. It is also true that most of the board will also work with the wrong resistance, so it always pays to first try the smooth operation without changing anything.
Post by RogerClark » Fri Dec 02, 2016 7:39 pm
I think the point to note is that the correct value is 1.5k, but some PCs are tolerant of incorrect value
testato
Post by testato » Fri Dec 02, 2016 7:56 pm
ok, i changed the last line to :
It is also true that some PCs are tolerant of incorrect value so, before you change the resistance, you can try if it works in your case.
Post by RogerClark » Fri Dec 02, 2016 8:06 pm
sounds good
Post by Rick Kimball » Fri Dec 02, 2016 9:07 pm
While we are dusting and cleaning, I threw in a pinout picture and pdf link.
Post by RogerClark » Fri Dec 02, 2016 10:42 pm
Who is online
