Bluepill: max. voltage on 5V pin?
Re: Bluepill: max. voltage on 5V pin?
Post by ag123 » Sat Dec 16, 2017 3:08 am
well you could get a Baite MM clone instead of BP
https://www.aliexpress.com/store/produc ... 46722.html
https://www.ebay.com/sch/i.html?_nkw=st ... i&_sacat=0
that uses AMS1117 with a max 15V given in the spec and accordingly it can deliver up to 1A downstream
http://www.advanced-monolithic.com/pdf/ds1117.pdf
but i'd think sinking 12v to 5v, there'd be a lot of waste heat, it would run hot as well given the high voltage drop and you'd still need to find a way to do some heat sink
BennehBoy
Post by BennehBoy » Sun Dec 17, 2017 11:30 am
One of my Baite clones emitted magic smoke when its owner inadvertently connected it directly to a 12+V automotive feed. It's now eking out a lonely existence at a landfill somewhere so I'm unable to check the regulator markings.
https://github.com/BennehBoy
Post by ag123 » Mon Dec 18, 2017 3:27 pm
uh oh, thanks for posting that, it's probably pretty good warning ;)
my guess is to feed off 12v, it would probably be better, safer, more efficient to feed off a low cost step down buck converter
https://en.wikipedia.org/wiki/Buck_converter
https://www.ebay.com/sch/i.html?_nkw=bu ... r&_sacat=0
pretty much an overkill as a buck converter typically supply much higher currents downstream, but when loads is light it could consume much less as well and possibly run cool, the capacitors could be smaller too
Post by mrburnette » Mon Dec 18, 2017 3:31 pm
Spew Alert to others ... do not drink coffee while reading the above ... :lol:
Post by zmemw16 » Mon Dec 18, 2017 7:23 pm
best post of 2017 ?
should there be a competition ? new thread?
srp
