Changing Timer1 frequency will effect UART ?
DrBanana
Post by DrBanana » Sat Jan 14, 2017 6:17 am
I have to modify the frequency of timer1, but the same timer is being used for UART(PA9, PA10). So if I change the frequency, will it effect the UART somehow ?
Re: Changing Timer1 frequency will effect UART ?
Post by victor_pv » Sun Jan 15, 2017 7:25 am
DrBanana wrote:I have to modify the frequency of timer1, but the same timer is being used for UART(PA9, PA10). So if I change the frequency, will it effect the UART somehow ?
I may be wrong, but I dont think Timer1 is related in any way to the USART. To confirm I just had a quick check at the reference manual and didn't see anything indicating they are related.
Could you point to the document you have seen saying that?
DrBanana
Post by DrBanana » Sun Jan 15, 2017 12:02 pm
As the pin out shown in the following post
http://www.stm32duino.com/viewtopic.php?t=1501#p19477
The PA9 and PA10, has TIM1_CH2 and TIM1_CH3 attached, so I thought Timer1 is being used with UART ?
Post by Pito » Sun Jan 15, 2017 1:36 pm
That is for PWM, isn't it?
DrBanana
Post by DrBanana » Sun Jan 15, 2017 3:46 pm
so UART has its own timer other than tim1 ?
Post by ahull » Sun Jan 15, 2017 3:59 pm
DrBanana wrote:so UART has its own timer other than tim1 ?
The peripheral clocks are, so far as I recall not directly related to the timers. They do however depend on the system clock and its divider.
Full details here -> http://www.st.com/content/ccc/resource/ ... 171190.pdf
Clock tree page 92 to Page 125 or thereabouts.
USART details from page 791
Software serial is described in detail in its own thread on this forum.
Post by victor_pv » Sun Jan 15, 2017 4:29 pm
DrBanana wrote:As the pin out shown in the following post
Most of the ports have several possible functions, so that port can be configured as PA9 OR as UART pin OR as TIM_CH2, and so on. that is what those tables mean. So let's say in your sketch you need the USART, then you configure the port for that (the library does it for you), if you wanted to use them for Timer input or output, then the corresponding library can configure them for that function.
