Modbus Master and Slave on STM32F103 and UNO
tyro
Re: Modbus Master and Slave on STM32F103 and UNO
Post by tyro » Sun Jan 29, 2017 12:27 pm
messaf wrote:Hi guys!
I added a little library for working with STM32F103 (Library :: ModbusMaster Author :: Doc Walker), I hope he will not swear. :D
Everything is working very well now. I checked on two boards Arduino (slave) and Blue Pill Stm32F103 (master). Here are links to files:
ModbusMaster_STM32_RS-485
ModbusSlave_ArduinoUNO_RS-485
Great!!! I have just tested Master on Maple Mini. I had to replace "node.begin" from old style to new one and everything started to work. I didn't tester responses are cached well, but message Maple is sending from Serial1 is well formatted. You made really big job for people working with modbus protocol and switching to STM32 on Arduino IDE :)
Post by stevestrong » Sun Jan 29, 2017 3:42 pm
Can you tell us what exactly was the problem, how did you solve it?
messaf
Post by messaf » Mon Jan 30, 2017 2:54 am
stevestrong wrote:Can you tell us what exactly was the problem, how did you solve it?
The main problem was waiting for the end of transmission UART STM32 data. That is, in the standard library function Arduino Serial.flush () carries the expectation of the end of transmission and treatment of data send buffer. While the STM32 for the above function only cleared buffer, so data is transferred not in full (Serial.write ();). In ModbusMaster library has been added to the function "bool ModbusMaster :: waitWriteSerial (void)", which is as follows:
Modbus Wait Write Serial.
@param
@return
bool ModbusMaster::waitWriteSerial(void)
  if(_serialPort == STM32_USART1)
    usart_reg_map *regs = USART1->regs;
    while ( !(regs->SR & USART_SR_TC) ); // Wait for Transmission Complete to set
    return true;
  else if(_serialPort == STM32_USART2)
    usart_reg_map *regs = USART2->regs;
    return true;
  else if(_serialPort == STM32_USART3)
    usart_reg_map *regs = USART3->regs;
    return true;
  else return false;
As you can see from the code in the function there waiting solution for three interfaces UART (USART1 - USART3). Calling this function is carried out in the library functions (ModbusMaster) "uint8_t ModbusMaster :: ModbusMasterTransaction (uint8_t u8MBFunction)", it is a place where data is transmitted:
  // transmit request
  if (_preTransmission)
    _preTransmission();
  for (i = 0; i < u8ModbusADUSize; i++)
    _serial->write(u8ModbusADU[i]);
  waitWriteSerial(); // Wait for Transmission Complete to set  // Modified Egor Orlenok
  u8ModbusADUSize = 0;
  _serial->flush();
  delayMicroseconds(T3_5); // Modified Egor Orlenok
  if (_postTransmission)
    _postTransmission();
Also, if you notice in the code above is present there is a delay "delayMicroseconds (T3_5);", which forms the interval of "silence" of 3.5 characters at the current exchange rate. The value of the interval is initialized (calculated) based on the exchange rate in the transmitted Functions "void ModbusMaster :: begin (uint8_t slave, uint8_t serialPort, uint32_t baud)" argument "uint32_t baud":
void ModbusMaster::begin(uint8_t slave, uint8_t serialPort, uint32_t baud)
//  txBuffer = (uint16_t*) calloc(ku8MaxBufferSize, sizeof(uint16_t));
  _u8MBSlave = slave;
  _u8TransmitBufferIndex = 0;
  u16TransmitBufferLength = 0;
  _serialPort = serialPort;
  //----- Modified Egor Orlenok -----
  if (baud > 19200)
    T1_5 = 750;
    T3_5 = 1750;
  else
    T1_5 = 15000000UL/baud; // 1T * 1.5 = T1.5
    T3_5 = 35000000UL/baud; // 1T * 3.5 = T3.5
  switch(serialPort)
    case STM32_USART1: _serial = &Serial1; Serial1.begin(baud);    break;
    case STM32_USART2: _serial = &Serial2; Serial2.begin(baud);    break;
    case STM32_USART3: _serial = &Serial3; Serial3.begin(baud);    break;
  //----- End Modified ---------------
#if __MODBUSMASTER_DEBUG__
  pinMode(__RED_LED_A__, OUTPUT);
  pinMode(__GREEN_LED_B__, OUTPUT);
Another addition was made in "word.h" file. This alternative implementation functions "word ()", with the project for the assembly on the STM32 Arduino IDE compiler to issue the error described earlier in this topic. Supplement is as follows (an alternative function for the STM32) "MakeWord (uint8_t h, uint8_t l)":
And the place of the call to "ModbusMaster.cpp" file:
static inline uint16_t MakeWord(uint8_t h, uint8_t l)
  return (h << 8) | l;
static inline uint16_t MakeWord(uint8_t w)
  return w;
void ModbusMaster::send(uint8_t data)
  send(MakeWord(data));
          if (i < ku8MaxBufferSize)
            _u16ResponseBuffer[i] = MakeWord(u8ModbusADU[2 * i + 4], u8ModbusADU[2 * i + 3]);
            _u16ResponseBuffer[i] = MakeWord(0, u8ModbusADU[2 * i + 3]);
The source files of the original library (ModbusMaster - Author :: Doc Walker)
Files edited and examples I posted in the previous post:
messaf wrote: Here are links to files:
Post by stevestrong » Mon Jan 30, 2017 7:18 am
The best would be to share the code on github, rather than in a zip package.
messaf
Post by messaf » Tue Jan 31, 2017 2:26 am
stevestrong wrote:The best would be to share the code on github, rather than in a zip package.
Yes, of course it would be easy, but I'll do it later, as will be free time.
messaf
Post by messaf » Tue Jan 31, 2017 2:30 am
I am interested in this question (although it is not in this thread): How to configure Pligin Arduino for Eclipse that would use all the libraries for STM32 boards, many did not try to set up - I have nothing turns out ... Prompt please, or may have some sort of already ready manul on this topic?
Post by stevestrong » Tue Jan 31, 2017 8:07 am
messaf
Post by messaf » Tue Jan 31, 2017 10:53 am
stevestrong wrote:Here is a possibility: http://wiki.stm32duino.com/index.php?ti ... th_Eclipse
Thank you! :D
zouk199
Post by zouk199 » Tue Apr 25, 2017 9:07 am
hi sir
i am doing f103 with enc28j60 to become modbus tcp.
do u have any library for modbus tcp for stm32.
with regards
zouk
Post by stevestrong » Tue Apr 25, 2017 9:44 am
@zouk199,
stop multiple-posting, your issue will not be solved if you post in every possible thread.
If you have already Enc26 working on F103, then ModbusIP (link from your other post) should work out of the box.
Just try one of those examples.
