I can use STM32l432kc as HID with arduino Ide?
Posted: Thu Sep 29, 2022 3:08 pm
by Iraton
I don't know if is the right category but for now i post here. I searched online if is possible to use this board like HID, I have not seen anything that denies it,but not even the opposite. I have tried with the arduino ide with no results, i have researched online and i found some project that use this board as an HID device, but i can't understand how. So now i have a doubt, i can use this board as HID device?
Re: I can use STM32l432kc as HID with arduino Ide?
Posted: Thu Sep 29, 2022 4:45 pm
by GonzoG
In Arduino IDE -> menu -> tools -> USB support -> HID (keyboard and mouse)
You use default keyboard.h and mouse.h libraries.
Posted: Thu Sep 29, 2022 5:44 pm
Yes you can use it as it has USB capabilities:
https://github.com/stm32duino/Arduino_C ... #L258-L263
Anyway you should ensure to have an USB port connected to PA11/PA12 and also check the system core clock config provide a 48MHz clock.
Posted: Thu Sep 29, 2022 6:33 pm
by Iraton
GonzoG wrote: ↑Thu Sep 29, 2022 4:45 pm
I did it, but it doesen't work, now i will try with the usb attached to the pin pa11-12
by Iraton
I saw that i can set this on the CubeMX, but ihow can do it in arduino ide?
Posted: Thu Sep 29, 2022 8:20 pm
by GonzoG
Iraton wrote: ↑Thu Sep 29, 2022 6:33 pm
USB port = usb physical port (socket) where you put cable in.
Arduino will use only USB on PA11/PA12 as HID/Serial.
Posted: Thu Sep 29, 2022 8:33 pm
by Iraton
GonzoG wrote: ↑Thu Sep 29, 2022 8:20 pm
Sorry I expressed myself badly, the question was about how to change the system core clock from 80Mhz (default) to 48Mhz
Posted: Thu Sep 29, 2022 8:45 pm
by GonzoG
Iraton wrote: ↑Thu Sep 29, 2022 8:33 pm
It's not main MCU speed.
Just check if standard
Serial output over USB works (USB support -> CDC (generic Serial supersede USART)). It this work, there is proper clock config.
Posted: Thu Sep 29, 2022 9:04 pm
by Iraton
Thanks u all, now it works perfectly, you saved me
