Hello, trying to hack SPI1 working "bare metal"
tiger762
Post by tiger762 » Thu Feb 23, 2017 2:29 am
This is my function to initialize SPI. I've included the relevant page number from RM0008. Note the use of the "bit-band" to perform atomic bit setting/clearing (base address 0x42000000):
void InitializeSPI () {
*((volatile long *)(0x42000000 + (0x40021004 - 0x40000000)*32 + 13*4)) = 1; // RCC_APB2ENR.PPRE2[2] p.101 \
*((volatile long *)(0x42000000 + (0x40021004 - 0x40000000)*32 + 12*4)) = 0; // RCC_APB2ENR.PPRE2[1] p.101 |--- PCLK2 divided by 2
*((volatile long *)(0x42000000 + (0x40021004 - 0x40000000)*32 + 11*4)) = 0; // RCC_APB2ENR.PPRE2[0] p.101 /
*((volatile long *)(0x42000000 + (0x40021018 - 0x40000000)*32 + 12*4)) = 1; // RCC_APB2ENR.SPI1EN p.112
*((volatile long *)(0x42000000 + (0x40021018 - 0x40000000)*32 + 2*4)) = 1; // RCC_APB2ENR.IOPAEN p.112
*((volatile long *)(0x42000000 + (0x40021018 - 0x40000000)*32 + 0*4)) = 1; // RCC_APB2ENR.AFIOEN p.112
*((volatile long *)(0x42000000 + (0x4002100c - 0x40000000)*32 + 12*4)) = 1; // RCC_APB2RSTR.SPI1RST p.106
*((volatile long *)(0x42000000 + (0x4002100c - 0x40000000)*32 + 0*4)) = 1; // RCC_APB2RSTR.AFIORST p.105
*((volatile long *)(0x42000000 + (0x40013000 - 0x40000000)*32 + 2*4)) = 1; // SPI1_CR1.MSTR p.747
*((volatile long *)(0x42000000 + (0x40013000 - 0x40000000)*32 + 5*4)) = 1; // SPI1_CR1.BR[2] \
*((volatile long *)(0x42000000 + (0x40013000 - 0x40000000)*32 + 4*4)) = 1; // SPI1_CR1.BR[1] |--- 111 means FPCLK/256 p.746
*((volatile long *)(0x42000000 + (0x40013000 - 0x40000000)*32 + 3*4)) = 1; // SPI1_CR1.BR[0] /
*((volatile long *)(0x42000000 + (0x40013000 - 0x40000000)*32 + 6*4)) = 1; // SPI1_CR1.SPE p.746
SetMode (PA5, OUTPUT_ALT_PUSHPULL | MODE_OUTPUT_10MHZ); // p.166
SetMode (PA6, INPUT_FLOAT | MODE_INPUT); // p.166
SetMode (PA7, OUTPUT_ALT_PUSHPULL | MODE_OUTPUT_10MHZ); // p.166
and the ubiquitous 'write_spi' function:
UCHAR write_spi (UCHAR value) {
UCHAR ret;
SPI1_DR = value;
while (!(SPI1_RXNE));
ret = SPI1_DR;
return (ret);
Using a Saleae logic analyzer, I see CSN dropping low (for the benefit of the NRF24L01 I am trying to speak with) but SCLK never sends out a train of pulses.
Something in my RCC and/or GPIO config is missing a step. The reference manual (RM0008) is not 100% thorough on this point. Any help appreciated!
Re: Hello, trying to hack SPI1 working "bare metal"
Post by zmemw16 » Thu Feb 23, 2017 7:24 am
you don't seem to setup SCK PA4 as an output :?:
doesn't it istr default to being an input.
Post by stevestrong » Thu Feb 23, 2017 11:57 am
Is there any reason why not to use a "human readable" version of setting the registers?
For example:
spi_reg_map * regs = SPI1->regs;
regs->DR = 0x00FF;
while ( (regs->SR & SPI_SR_RXNE)==0 ) ;
Be careful by writing: if you have already data waiting to be read out, your reading at the end of the function will return that one instead of the last read one.
tiger762
Post by tiger762 » Thu Feb 23, 2017 12:45 pm
In my setup() is where I set up the CSN (PA4):
void setup (void) {
SetMode (PA4, MODE_OUTPUT_10MHZ | OUTPUT_PUSHPULL);
SetMode (PC13, MODE_OUTPUT_10MHZ | OUTPUT_OPENDRAIN);
InitializeUART ();
InitializeSPI ();
Console ("\r\nHello!!!\r\n");
Basically, I can't get SCLK to oscillate. I keep seeing reference to "attaching SPI1 to alternate pins PA5,PA6,PA7"
Either like this:
gpioInitStructure.Alternate = GPIO_AF5_SPI1;
or this one fellow who does it like this:
void InitialiseSPI(void)
SPI_InitTypeDef SPI_InitStruct;
// Connect SPI1 pins to SPI alternate function.
GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1);
GPIO_AF5_SPI1 is either 5 or 20 (4 tiems 5) or 0x00F00000
The stm32f103 does not have a GPIOx_AFR register, so I might be mixing metaphors here.
Setting up the USART1 "bare metal" was so much easier. It required a couple of GPIO setup and an RCC and that was that.
Post by stevestrong » Thu Feb 23, 2017 2:39 pm
I think this thread should be moved to http://www.stm32duino.com/viewforum.php?f=48, as it does not use the Arduino_STM32 repo.
Meanwhile you could check these lines of code, maybe helps.
tiger762
Post by tiger762 » Thu Feb 23, 2017 3:05 pm
Started off that way, before I realized the specs were insufficient and the Internet blurs the hardware distinction among the stm32 family. So I tried to remove any possible ambiguity. There are RCC and SPI register settings to be made. I'm left guessing which one(s) I am missing.
If the author(s) of RM0008 had been nice enough to include ALL necessary register settings, that would have been wonderful :(
stevestrong wrote:Is there any reason why not to use a "human readable" version of setting the registers?
For example:
regs->DR = 0x00FF;
Post by stevestrong » Thu Feb 23, 2017 3:22 pm
If you would really check the lines of code (and track the called function) I linked to my previous post, you could maybe solve your issue.
Post by RogerClark » Thu Feb 23, 2017 9:45 pm
I will log in as admin and move this thread ( to the STM core as suggested by @stevstrong
tiger762
Post by tiger762 » Thu Feb 23, 2017 10:26 pm
Actually, the answer was to include setting "SSM_ENABLE" (bit 9) and "INT_SLAVE_SEL" (bit 8) in SPI_CR1
Post by stevestrong » Fri Feb 24, 2017 8:06 am
Please mark it as SOLVED in the title if it is the case.
