Serial work only after disconnect/reconnect USB !??? (solved)
ManX84
Post by ManX84 »
Hello all, we are here for a new STM32duino mysteries!
First my configuration : ST32 core version 2.6.0
uC: STM32F103C8 (generic)
USB Support : "None"
USART Support : "Enable generic serial"
Upload Methode : "STM32CubeProgrammer (Serial)"
IDE : Arduino 2 (for a simple situation every body could test)
Well I wrote this ultra simple code (could not be more simple, this is the first thing I learned to my son !) :
  while(!Serial);
  Serial.setRx(PA10); // using pin name
  Serial.setTx(PA9);
  Serial.println("STM32Duino Forum !!!");
  delay(200);
First problem : at the end of upload program I open a serial monitor (any, Serial Monitor from IDE, or a Putty), then reset the STM32F103 ... nothing append ! It work ONLY if I disconnect/Connect the cable!
Second problem : By default Serial would use usart 1, not ?? so why if I remove pin assignment (SetRx and SetTx) it is not working (even after disconnect/connect)
All this serial stuff, who normally must work from scratch as simple as push a button look very "special" on STM32 !!!!!!
(I spent 4 hours before found I need to connect / unconnect, and I didnt told you all the story, it was a pity!)
So after all of that, Is ther somebody here who could clarify STM32duino serial ??? (Or am I the only one struggling with such a simple thing?)
Thanks Guys !
Exposing your opinion is good, exposing your code is better! :mrgreen:
ManX84
Re: Serial work only after disconnect/reconnect USB !???
Post by ManX84 »
Same with Arduino IDE 1.8.19
select:
"USB Support ( CDC generic 'Serial' supercede u(s)art ) " from the menu to get usb-serial, i.e. Serial.println("hello"); goes to your serial monitor.
https://github.com/stm32duino/Arduino_C ... wareserial
The STM32 MCU's have several U(S)ART peripherals. By convenience, the U(S)ARTx number is used to define the Serialxinstance:
Serial1 for USART1
Serial2 for USART2
Serial3 for USART3
Serial4 for UART4
so your uart would be Serial1, Serial2 etc.
otherwise do it as like the example given
//                      RX    TX
HardwareSerial Serial1(PA10, PA9);
  Serial1.begin(115200);
  Serial1.println("Hello World!");
Simply do while(!Serial); after the begin
ManX84
Post by ManX84 »
@fpiSTM : no this not working
ManX84
Post by ManX84 »
@ag123 :
  // Serial.setRx(PA10); // using pin name
  // Serial.setTx(PA9);
  // Serial.begin(115200);
  while(!Serial1);
  Serial1.println("STM32Duino Forum !!!");
  delay(200);
This code work, BUT only after connect/unconnect USB.
BUT this clarify the compilator setting to use multiple usuart. This is nice.
I think my problem come from STM32CubeProgrammer who not release the port ..
it is call by this script :
C:\...\AppData\Local\arduino15\packages\STMicroelectronics\tools\STM32Tools\2.2.1\stm32CubeProg.sh
is there an alternative cli tools that I could use ?
Some doc about HardwareSerial:
Default Serial instance of the generic:
https://github.com/stm32duino/Arduino_C ... #L140-L145
So it uses PA2/PA3 which uses USART2. This means default Serial instance is mapped to Serial2.
You can redefine those pins using the build_opt.h:
https://github.com/stm32duino/Arduino_C ... uild_opt.h
With:
-DPIN_SERIAL_RX=PA10 -DPIN_SERIAL_TX=PA9 -DSERIAL_UART_INSTANCE=1
About CubeProgrammer, it should be released and the board reset. Maybe your board does not properly reset, hardware issue?
ManX84
Post by ManX84 »
@fpiSTM:
Yes, this is an hard issue !
Why ? because when I started to work with this board I modified the stm32CubeProg.sh like it command RTS and DTR line (on my board RESET condition is achieved with RTS = 1 and DTR = 0, Boot mode is with RTS = 1 and DTR = 0 ). But I didn't release correctly these lines and after STMCubeProgrammer finish the job, RTS and DTR was not in the right levels !
All done, thanks guys for your hep and clarify some points !
Re: Serial work only after disconnect/reconnect USB !??? (solved)
why not use usb-serial?
select:
no conflicts, it gets its own virtual com: port
more commonly, I'd use usb-serial
Then use Serial1, ..., i.e. uart for other things e.g. to connect to other devices that use a uart for comms.
And you can easily connect Serial to Serial1 by passing data between them,
  Serial.begin(); // this is for usb (CDC) serial
  //while(!Serial1); //if you don't need to wait for connection this can be skipped
  if(Serial.available()) {
    Serial1.write(Serial.read());
  if(Serial1.available()) {
    Serial.write(Serial1.read());
to improve performance, you can use buffer etc and write a full block of data passing data between them.
usb (CDC) -serial is a *feature* of stm32 mcus that have usb, and it is faster than some usb-uart dongles which may limit speeds at 115200 and or that some usb-uart dongles works badly and gives lots of issues. in some tests i get about 1 Mbps with usb (CDC) serial, though your mileage may vary as usb bandwidth (12 Mbps) is multiplexed by the host, the more devices and hubs there are, the bandwidth becomes divided by N devices at least. And usb (CDC) serial doesn't care about 'baud' rates, it is 12 mbps full usb speeds.
