[SOLVED] STM32F103CBT6 BOOT Problem
Nawfal
Re: STM32F103CBT6 BOOT Problem
Post by Nawfal » Tue Aug 29, 2017 3:44 pm
Rick Kimball wrote:
Tue Aug 29, 2017 3:43 pm
You said you loaded the blinky sketch. You didn't say if it works. Have you seen it work?
Yes, it's working fine.....the timing also works fine
Post by Rick Kimball » Tue Aug 29, 2017 3:48 pm
Do you leave the stlink connected when you power off and on? Or are you disconnecting the stlink device?
Nawfal
Post by Nawfal » Tue Aug 29, 2017 3:49 pm
I leave it connected. I tried removing it before and after the power cycle and It's giving the same results
Post by Rick Kimball » Tue Aug 29, 2017 3:51 pm
Do you leave the stlink powered on?
Have you tried disconnecting the stlink?
What is the voltage of your VDD when you measure it with a meter?
Nawfal
Post by Nawfal » Tue Aug 29, 2017 3:53 pm
What is the voltage of your VCC when you measure it with a meter?
The voltage is 3.28V
And yes, I tried disconnecting the ST-Link without succes so far
Post by Rick Kimball » Tue Aug 29, 2017 3:54 pm
Why does your schematic show SWD connected to LMS 3v3?
-------- ... never mind ... that is not SWD but the target voltage.
Nawfal
Post by Nawfal » Tue Aug 29, 2017 3:56 pm
It is the output from a voltage regulator
Post by Rick Kimball » Tue Aug 29, 2017 3:58 pm
Do you know how to use arm-none-eabi-gdb .. maybe it is booting up but encountering some other error before it is able to run the loop() function
You might start up st-util and put a breakpoint on the reset routine and step through
Nawfal
Post by Nawfal » Tue Aug 29, 2017 3:58 pm
Do I need to use a bootloader though I am using the ST-LINK???
Nawfal
Post by Nawfal » Tue Aug 29, 2017 3:59 pm
No, do you have some link where I can look at??
