Black pill startup glitch
arpruss
Post by arpruss » Sat Oct 07, 2017 1:28 pm
When my Black Pill is powered up, it glitches on at least PA7. As far as I can tell, instead of the pin starting high-Z, it is briefly is pulled towards ground. This happens before the user code starts running.
I haven't caught it on a scope, but when the pin is interfaced with my elliptical exercise machine's rotation detector and the stm32 is powered up, the elliptical beeps as if motion started. Any thoughts?
Re: Black pill startup glitch
Post by mrburnette » Sat Oct 07, 2017 2:31 pm
Post by RogerClark » Sat Oct 07, 2017 9:43 pm
Thanks Ray?
Thats good to know...
Sounds like a bug in the silicon related to those pins being used for JTAG programming
Post by zmemw16 » Sun Oct 08, 2017 1:02 am
one of my daft questions, would setting them as analogues and later on initialising as gpio solve the issue ?
in CubeMX you can tell to set all gpio(??) as analogues for power saving.
i'd be inclined to set all possible pins as analogue just before sleeping and re-initialise them on wake up.
srp
arpruss
Post by arpruss » Sun Oct 08, 2017 2:51 am
1. The discussion on particle.io says to use analog pins. But PA7 is analog-enabled.
2. Is PA7 one of the JTAG pins? I can't find a list of the JTAG pins in the datasheet?
3. Online information suggests JTAG pins are pulled up. But what I seem to be finding is a weak downward pull.
Post by RogerClark » Sun Oct 08, 2017 3:34 am
I thought someone dug out some details about full JTAG and posted it on the forum, but in the F103C8 data sheet, I can't find anything that suggests PA7 is a JTAG pin, I can only find the SWD PINS
e.g.
PA13 JTMS/SWDIO
But nothing for PA7
Post by zmemw16 » Sun Oct 08, 2017 5:12 am
i was actually thinking of making at least pa0-pa7 analogue. maybe also any others capable of being made analogue.
<edit> quick CubeMX play, 103c8 any debug is mainly pa13-pa15, also pb3.
pa0 is the wake-up pin. maybe needs handling differently ?
a 103v uses additional pins from pc & pe ports.
</edit>
i once had a unit to test with analogue inputs, they all had a cap across the inputs, one channel being driven gave the rest a 300mV leakage. all the various caps were effectively an ac potential divider.
that took a while to suss.
