[SOLVED] AnalogRead problem
DrBanana
Post by DrBanana » Thu Oct 26, 2017 8:31 am
I have a voltage divider connected to PA4 pin of STM32F103RE
Voltages on PA4 oscillate from 2.0 to 2.6 volts, but the analogRead on PA4 going way off.
Here is the code
	pinMode(PA4, INPUT_ANALOG);
	int analogValue = analogRead(PA4);
	Serial.println(analogValue);
Here the Serial out
521
4095
3483
918
2403
3180
0
1206
3875
4095
0
1171
4004
1967
850
3390
3543
0
1380
3989
2048
381
3011
2564
113
2184
3091
1525
709
4062
1661
843
2703
3016
0
Re: AnalogRead problem
Post by Pito » Thu Oct 26, 2017 8:36 am
What are the resistor's values ?
DrBanana
Post by DrBanana » Thu Oct 26, 2017 8:48 am
12 VCC(+-2) - 10k + 1.5K - GND
Post by ahull » Thu Oct 26, 2017 9:49 am
If Vin is between 10 and 14 volts, Vout should be between 1.3 and 1.8V approx.
http://www.calculatoredge.com/electroni ... divide.htm
How do you get 2.0 to 2.6V ? I'm not sure I understand your circuit.
DrBanana
Post by DrBanana » Thu Oct 26, 2017 9:56 am
Could be, I saw the waves in oscilloscope, nothings goes above 3v and was around 2v. The voltage divider seems not the problem, but the analog values changing are. Voltage doesn't go 0 at voltage divider while analogRead returns it.
Post by Pito » Thu Oct 26, 2017 10:53 am
Divider's input voltage:
Input Voltage.JPG (67.52 KiB) Viewed 330 times
Divider's output voltage:
Post by Pito » Thu Oct 26, 2017 10:58 am
Double-check the GND wiring, it seems your GND is floating (some breadboards do not have a continual GND rail handy).
DrBanana
Post by DrBanana » Thu Oct 26, 2017 11:47 am
the wiring is good, hardware seems all good. I think the problem is in reading analog.
Post by zmemw16 » Thu Oct 26, 2017 4:19 pm
try with just an AA battery to PA4 and ground ?
then maybe AA+ to 1k/2k to gnd, pa4 to junction of the R's
that should demonstrate or eliminate an analogue read problem, barring a bad crimp in the wires :D
Post by ahull » Thu Oct 26, 2017 10:16 pm
.. also try the analog read on some different pins (perhaps PA0, PA1 or PB0) to see if the problem is perhaps just a dodgy solder joint on the pin in question.
