Voltage protection by Blue Pill in time lapse rig
Sdack
Re: Voltage protection by Blue Pill in time lapse rig
Post by Sdack » Fri Nov 10, 2017 9:52 pm
I'll check out KMart then..
I'm hoping for good results from the LG high drain batteries I just ordered but I will need to swap in an alternate power pack when they are charging.
Now that I've got my Blue Pill actually working (at least programmable via ST-Link), I'm starting my hunt for sketches which will combine power monitoring and scheduling the powering on and off of the relays to supply my camera and Raspberry Pi set up.
I've been rather surprised at the level of complexity of the code I'm seeing in the example sketches. I'm more used to bash and python scripting which seems simpler somehow. Perhaps it's because several of the scripts I've looked at include hardware interfaces, like touchscreens for user input.
If anyone can point me towards a simple timing sketch to control switching on a schedule like the following.. I'd appreciate it
SHEDULE
Mon - Fr
8:30 - 4:30
switch on relay for X mins every X minutes
I'm looking for a sketch which will put the microprocessor in some kind of sleep mode inbetween scheduled events. From what I'm reading, this might require an external RTC, running on a coin cell battery.
Cheers and have a great weekend
Sdack
Post by RogerClark » Fri Nov 10, 2017 10:15 pm
I think you'll need to write some code which works how how long to sleep until the next wake time
It should not be too hard to write.
@ahull wrote a sunset / sunrise timer thingy to operate a camera, so perhaps you can look for his code, its on the forum or his github account
BTW.
Relays take a lot of current, I'm not sure how that works with a low power system.
But perhaps you only turn them on for a short time
You could potentially also use a FET instead of a relay, as they take virtually no switching current
Sdack
Post by Sdack » Sat Nov 11, 2017 12:00 am
Thanks Roger,
It was AHull's Sunset timer that got me started down this road. I just revisited his Hackaday page https://hackaday.io/project/2126-sunset ... controller and you are correct in that he uses dual mosfets as his switches.
I have looked through his code and it's a bit daunting. Lots of stuff in there for the Nokia display.
I guess my best and shortest route to a workable start would be to duplicate his system as close as possible and take it from there.
AliExpress, here I come again!
N
Post by ahull » Sat Nov 11, 2017 12:07 am
The STM32 version is here -> https://github.com/pingumacpenguin/STM32-Sunrise
It uses the ILI9341 display. Its been a while since I looked at the code though, and since I'm still fighting with the chaos of moving house, I have no clue where the prototype is... :D I did have it working with both relays, and Mosfets. For sunrise or sunset timelapses, the power used by a relay is not too bad, the camera only runs for about a half hour per day, and the camera itself is the major drain on the battery.
(c) Andrew Hull - 2015
STM32-Sunrise - Released under the GNU GENERAL PUBLIC LICENSE Version 3
Sunrise and sunset timer.
Adafruit Libraries released under their specific licenses Copyright (c) 2013 Adafruit Industries.  All rights reserved.
Honourable mention to https://stackoverflow.com/users/1678716/scottmrogowski Scott m Rogowski for the detailed sunrise calculation code posted here.
https://stackoverflow.com/questions/7064531/sunrise-sunset-times-in-c/9425781#9425781?newreg=23a1112cbf764135b2cc16a678d032de
I have plagerised this unashamedly, since it is neat, tidy and *almost* worked first time. A few enhancements allow both sunset and sunrise to be caluclated with the same function,
so I added a couple of wrapper functions to keep the code size down.
All other libraries are detailed with appopriate links in the code comments.
#include "Adafruit_ILI9341_STM.h"
#include "Adafruit_GFX_AS.h"
// Be sure to use the latest version of the SPI libraries see stm32duino.com - http://stm32duino.com/viewtopic.php?f=13&t=127
#include <SPI.h>
#define PORTRAIT 0
#define LANDSCAPE 1
// Define the orientation of the touch screen. Further
// information can be found in the UTouch library documentation.
#define TOUCH_SCREEN_AVAILABLE
#define TOUCH_ORIENTATION  LANDSCAPE
#if defined TOUCH_SCREEN_AVAILABLE
// UTouch Library
// http://www.rinkydinkelectronics.com/library.php?id=56
#include <UTouch.h>
// Initialize touchscreen
// Set the pins to the correct ones for your STM32F103 board
// STM32F103C8XX Pin numbers - chosen for ease of use on the "Red Pill" and "Blue Pill" board
// Touch Panel Pins
// T_CLK T_CS T_DIN T_DOUT T_IRQ
// PB12 PB13 PB14 PB15 PA8
// Example wire colours Brown,Red,Orange,Yellow,Violet
// --------             Brown,Red,Orange,White,Grey
UTouch  myTouch( PB12, PB13, PB14, PB15, PA8);
// RTC and NVRam initialisation
#include "RTClock.h"
RTClock rt (RTCSEL_LSE); // initialise
uint32 tt;
// Define the Base address of the RTC  registers (battery backed up CMOS Ram), so we can use them for config of touch screen and other calibration.
// See http://stm32duino.com/viewtopic.php?f=15&t=132&hilit=rtc&start=40 for a more details about the RTC NVRam
// 10x 16 bit registers are available on the STM32F103CXXX more on the higher density device.
#define BKP_REG_BASE   (uint32_t *)(0x40006C00 +0x04)
// Defined for power and sleep functions pwr.h and scb.h
#include <libmaple/pwr.h>
#include <libmaple/scb.h>
// #define NVRam register names for the touch calibration values.
#define  TOUCH_CALIB_X 0
#define  TOUCH_CALIB_Y 1
#define  TOUCH_CALIB_Z 2
// Time library - https://github.com/PaulStoffregen/Time
#include "Time.h"
#define TZ    "UTC+1"
// End RTC and NVRam initialization
// SeralCommand -> https://github.com/kroimon/Arduino-SerialCommand.git
#include <SerialCommand.h>
/* For reference on STM32F103CXXX
variants/generic_stm32f103c/board/board.h:#define BOARD_NR_SPI              2
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI1_NSS_PIN        PA4
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI1_MOSI_PIN       PA7
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI1_MISO_PIN       PA6
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI1_SCK_PIN        PA5
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI2_NSS_PIN        PB12
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI2_MOSI_PIN       PB15
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI2_MISO_PIN       PB14
variants/generic_stm32f103c/board/board.h:#define BOARD_SPI2_SCK_PIN        PB13
// Additional  display specific signals (i.e. non SPI) for STM32F103C8T6 (Wire colour)
#define TFT_DC        PA0      //   (Green)
#define TFT_CS        PA1      //   (Orange)
#define TFT_RST       PA2      //   (Yellow)
// Hardware SPI1 on the STM32F103C8T6 *ALSO* needs to be connected and pins are as follows.
// SPI1_NSS  (PA4) (LQFP48 pin 14)    (n.c.)
// SPI1_SCK  (PA5) (LQFP48 pin 15)    (Brown)
// SPI1_MOSO (PA6) (LQFP48 pin 16)    (White)
// SPI1_MOSI (PA7) (LQFP48 pin 17)    (Grey)
#define TFT_LED        PA3     // Backlight
#define TEST_WAVE_PIN       PB0     // PWM 500 Hz
// Relay pins
#define RELAY_1 PC4
#define RELAY_2 PC5
// Create the lcd object
Adafruit_ILI9341_STM TFT = Adafruit_ILI9341_STM(TFT_CS, TFT_DC, TFT_RST); // Using hardware SPI
// LED - blinks on trigger events - leave this undefined if your board has no controllable LED
// define as PC13 on the "Red/Blue Pill" boards and PD2 on the "Yellow Pill R"
#define BOARD_LED PD2
// Display colours
#define BEAM1_COLOUR ILI9341_GREEN
#define BEAM2_COLOUR ILI9341_RED
#define GRATICULE_COLOUR 0x07FF
#define BEAM_OFF_COLOUR ILI9341_BLACK
#define CURSOR_COLOUR ILI9341_GREEN
// Screen dimensions
int16_t myWidth ;
int16_t myHeight ;
// Create Serial Command Object.
SerialCommand sCmd;
// Create USB serial port
USBSerial serial_debug;
// Sunrise stuff
#include <math.h>
#define PI 3.1415926
#define ZENITH -.83
#define Stirling_Latitude 56.138607900000000000
#define Stirling_Longitude -3.944080100000064700
// Lat long for your location
#define HERE_LATITUDE  56.1386079
#define HERE_LONGITUDE -3.9440801
int thisYear = 2015;
int thisMonth = 6;
int thisDay = 27;
int lastDay = 0;
int thisHour = 0;
int thisMinute = 0;
int thisSecond = 0;
float thisLat = HERE_LATITUDE;
float thisLong = HERE_LONGITUDE;
float thisLocalOffset = 0;
int thisDaylightSavings = 1;
// Digital clock variables
byte omm = 0;
//byte ss=0;
byte xcolon = 0;
  // Check time, and set a sensible time, if this board has no battery, or the time is unset
  tt = rt.getTime();
  // Check to see if we are close to the epoch, and if so, bad things must have happened to the RTC backup power domain.
  if ( tt < 1024 )
    // Set to a recent value - 29th June 2015 12:25 (just after mid day)
    rt.setTime(1435580711);
    // BOARD_LED blinks on events assuming you have an LED on your board. If not simply dont't define it at the start of the sketch.
    // TODO: make the board blink a morse code for the error.
    pinMode(RELAY_1, OUTPUT);
    pinMode(RELAY_2, OUTPUT);
#if defined BOARD_LED
    pinMode(BOARD_LED, OUTPUT);
    digitalWrite(BOARD_LED, HIGH);
    digitalWrite(RELAY_1, LOW);
    digitalWrite(RELAY_2, HIGH);
    digitalWrite(RELAY_1, HIGH);
    digitalWrite(RELAY_2, LOW);
  digitalWrite(BOARD_LED, LOW);
  serial_debug.begin();
  // Serial command setup
  // Setup callbacks for SerialCommand commands
  sCmd.addCommand("timestamp",   setCurrentTime);          // Set the current time based on a unix timestamp
  sCmd.addCommand("date",        serialCurrentTime);       // Show the current time from the RTC
  sCmd.addCommand("sleep",       sleepMode);               // Experimental - puts system to sleep
  //  sCmd.addCommand("touchcalibrate", touchCalibrate);       // Calibrate Touch Panel
  sCmd.setDefaultHandler(unrecognized);                    // Handler for command that isn't matched  (says "Unknown")
  sCmd.clearBuffer();
  // Backlight, use with caution, depending on your display, you may exceed the max current per pin if you use this method.
  // A safer option would be to add a suitable transistor capable of sinking or sourcing 100mA (the ILI9341 backlight on my display is quoted as drawing 80mA at full brightness)
  // Alternatively, connect the backlight to 3v3 for an always on, bright display.
  //pinMode(TFT_LED, OUTPUT);
  //analogWrite(TFT_LED, 127);
  // Setup Touch Screen
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_EXTREME);
  TFT.begin();
  // initialize the display
  clearTFT();
  TFT.setRotation(PORTRAIT);
  myHeight   = TFT.width() ;
  myWidth  = TFT.height();
  TFT.setTextColor(CURSOR_COLOUR, BEAM_OFF_COLOUR) ;
  //  touchCalibrate();
  TFT.setRotation(LANDSCAPE);
  clearTFT();
  //delay(5000) ;
  //clearTFT();
  // Setting the clock from the serial port is a matter of doing this in Linux...
  // NOW=$(date --date "+1hour" +"%s"); echo -e "\n\ntimestamp $NOW\n\n" >/dev/ttyACMx
  // where /dev/ttyACMx is the tty of the STM board. In my case /dev/ttyACM3
  // You can't do this if something else, for example tha arduino Serial Monitor, is attached to the port.
  sCmd.readSerial();     // Process serial commands
  // Show time, date, sunrise and sunset, rinse, repeat }:¬)
  tt = rt.getTime();
  thisYear = year(tt);
  thisMonth = month(tt);
  thisDay = day(tt);
  thisHour = hour(tt);
  thisMinute = minute(tt);
  thisSecond = second(tt);
  // drawRoundRect(uint16_tx0,uint16_ty0,uint16_tw,uint16_th,uint16_tradius,uint16_tcolor);
  TFT.drawRoundRect(8, 8, 160, 60, 5, 0xFBE0);
  TFT.drawRoundRect(6, 6, 164, 64, 5, 0xFBE0);
  TFT.setTextSize(1);
  TFT.setCursor(20, 20);
  showTime();
  TFT.setTextSize(3);
  if (lastDay != thisDay) {
    TFT.setCursor(10, 80);
    TFT.setTextColor(ILI9341_GREEN);
    showDate();
  lastDay = thisDay;
  TFT.setTextColor(thisMinute * (thisSecond + 1) * 65535);
  TFT.setCursor(10, 120);
  showSunrise();
  TFT.setTextColor(255 * thisHour * (thisSecond + 30) + 10);
  TFT.setCursor(10, 160);
  showSunset();
  //TFT.drawCentreString("12.34",60,91,7);
  // serialCurrentTime();
float calculateSunrise(int year, int month, int day, float lat, float lng, int localOffset, int daylightSavings ) {
  boolean rise = 1;
  return calculateSunriseSunset(year, month, day, lat, lng, localOffset, daylightSavings, rise) ;
float calculateSunset(int year, int month, int day, float lat, float lng, int localOffset, int daylightSavings ) {
  boolean rise = 0;
float calculateSunriseSunset(int year, int month, int day, float lat, float lng, int localOffset, int daylightSavings, boolean rise) {
  localOffset will be <0 for western hemisphere and >0 for eastern hemisphere
  daylightSavings should be 1 if it is in effect during the summer otherwise it should be 0
  //1. first calculate the day of the year
  float N1 = floor(275 * month / 9);
  float N2 = floor((month + 9) / 12);
  float N3 = (1 + floor((year - 4 * floor(year / 4) + 2) / 3));
  float N = N1 - (N2 * N3) + day - 30;
  //2. convert the longitude to hour value and calculate an approximate time
  float lngHour = lng / 15.0;
  float t = 0;
  if (rise ) {
    t = N + ((6 - lngHour) / 24);   //if rising time is desired:
  else
    t = N + ((18 - lngHour) / 24);   //if setting time is desired:
  //3. calculate the Sun's mean anomaly
  float M = (0.9856 * t) - 3.289;
  //4. calculate the Sun's true longitude
  float L = fmod(M + (1.916 * sin((PI / 180) * M)) + (0.020 * sin(2 * (PI / 180) * M)) + 282.634, 360.0);
  //5a. calculate the Sun's right ascension
  float RA = fmod(180 / PI * atan(0.91764 * tan((PI / 180) * L)), 360.0);
  //5b. right ascension value needs to be in the same quadrant as L
  float Lquadrant  = floor( L / 90) * 90;
  float RAquadrant = floor(RA / 90) * 90;
  RA = RA + (Lquadrant - RAquadrant);
  //5c. right ascension value needs to be converted into hours
  RA = RA / 15;
  //6. calculate the Sun's declination
  float sinDec = 0.39782 * sin((PI / 180) * L);
  float cosDec = cos(asin(sinDec));
  //7a. calculate the Sun's local hour angle
  float cosH = (sin((PI / 180) * ZENITH) - (sinDec * sin((PI / 180) * lat))) / (cosDec * cos((PI / 180) * lat));
  if (cosH >  1)
  the sun never rises on this location (on the specified date)
  if (cosH < -1)
  the sun never sets on this location (on the specified date)
  //7b. finish calculating H and convert into hours
  float H = 0;
  if (rise ) {
    //serial_debug.print("#sunrise");
    H = 360 - (180 / PI) * acos(cosH); //   if if rising time is desired:
    //serial_debug.println(H);
  else
    //serial_debug.print("# sunset ");
    H = (180 / PI) * acos(cosH); // if setting time is desired:
  //float H = (180/PI)*acos(cosH) // if setting time is desired:
  H = H / 15;
  //8. calculate local mean time of rising/setting
  float T = H + RA - (0.06571 * t) - 6.622;
  //9. adjust back to UTC
  float UT = fmod(T - lngHour, 24.0);
  //10. convert UT value to local time zone of latitude/longitude
  return UT + localOffset + daylightSavings;
void showSunrise() {
  float localT = calculateSunrise(thisYear, thisMonth, thisDay, thisLat, thisLong, thisLocalOffset, thisDaylightSavings);
  double hours;
  float minutes = modf(localT, &hours) * 60;
  TFT.print("Sunrise ");
  TFT.print(uint(hours));
  TFT.print(":");
  if (uint(minutes) < 10) {
    TFT.print("0");
  TFT.print(uint(minutes));
void showSunset() {
  float localT = calculateSunset(thisYear, thisMonth, thisDay, thisLat, thisLong, thisLocalOffset, thisDaylightSavings);
  double hours;
  float minutes = modf(24 + localT, &hours) * 60;
  TFT.print("Sunset ");
  TFT.print(uint(24 + localT));
  TFT.print(":");
    TFT.print("0");
void setCurrentTime() {
  char *arg;
  arg = sCmd.next();
  String thisArg = arg;
  serial_debug.print("# Time command [");
  serial_debug.print(thisArg.toInt() );
  serial_debug.println("]");
  setTime(thisArg.toInt());
  time_t tt = now();
  rt.setTime(tt);
  //serialCurrentTime();
void serialCurrentTime() {
  serial_debug.print("# Current time - ");
  if (hour(tt) < 10) {
    serial_debug.print("0");
  serial_debug.print(hour(tt));
  serial_debug.print(":");
  if (minute(tt) < 10) {
  serial_debug.print(minute(tt));
  if (second(tt) < 10) {
  serial_debug.print(second(tt));
  serial_debug.print(" ");
  serial_debug.print(day(tt));
  serial_debug.print("/");
  serial_debug.print(month(tt));
  serial_debug.print(year(tt));
  //serial_debug.println("("TZ")");
void unrecognized(const char *command) {
  serial_debug.print("# Unknown Command.[");
  serial_debug.print(command);
void clearTFT()
  TFT.fillScreen(BEAM_OFF_COLOUR);                // Blank the display
void showTime ()
  tt = rt.getTime();
  // Update digital time
  byte xpos = 14;
  byte ypos = 14;
  byte mm = minute(tt);
  byte hh = hour(tt);
  byte ss = second(tt);
  if (omm != mm) { // Only redraw every minute to minimise flicker
    TFT.setTextColor(ILI9341_BLACK, ILI9341_BLACK); // Set font colour to back to wipe image
    // Font 7 is to show a pseudo 7 segment display.
    // Font 7 only contains characters [space] 0 1 2 3 4 5 6 7 8 9 : .
    TFT.drawString("88:88", xpos, ypos, 7); // Overwrite the text to clear it
    TFT.setTextColor(0xFBE0, ILI9341_BLACK); // Orange
    omm = minute(tt);
    if (hh < 10) xpos += TFT.drawChar('0', xpos, ypos, 7);
    xpos += TFT.drawNumber(hh, xpos, ypos, 7);
    xcolon = xpos;
    xpos += TFT.drawChar(':', xpos, ypos, 7);
    if (mm < 10) xpos += TFT.drawChar('0', xpos, ypos, 7);
    TFT.drawNumber(mm, xpos, ypos, 7);
  if (ss % 2) { // Flash the colon
    TFT.setTextColor(0x39C4, ILI9341_BLACK);
    //delay(500);
    xpos += TFT.drawChar(':', xcolon, ypos, 7);
    //delay(500);
    relayOneOff();
    relayTwoOn();
  else {
    uint32 colour = ILI9341_GREEN;
    //uint32 colour = 0x39C4;
    // Erase the text with a rectangle
    //TFT.fillRect (0, 48, 160, 20, ILI9341_BLACK);
    TFT.setTextColor(colour);
    //TFT.drawRightString("Colour", 75, 64, 4); // Right justified string drawing to x position 75
    //String scolour = String(colour, HEX);
    //scolour.toUpperCase();
    //char buffer[20];
    //scolour.toCharArray(buffer, 20);
    //TFT.drawString(buffer, 82, 64, 4);
    relayOneOn();
    relayTwoOff();
void showDate ()
  // Show RTC Time.
  tt = rt.getTime();
  TFT.print(day(tt));
  TFT.print("-");
  TFT.print(month(tt));
  TFT.print("-");
  TFT.print(year(tt));
// STM32F103XXXX sleep mode
void sleepMode()
  serial_debug.println("# Nighty night!");
  // Set PDDS and LPDS bits for standby mode, and set Clear WUF flag (required per datasheet):
  PWR_BASE->CR |= PWR_CR_CWUF;
  PWR_BASE->CR |= PWR_CR_PDDS;
  // set sleepdeep in the system control register
  SCB_BASE->SCR |= SCB_SCR_SLEEPDEEP;
  // Now go into stop mode, wake up on interrupt
  // disableClocks();
  asm("wfi");
void relayOneOn()
void relayOneOff()
void relayTwoOn()
void relayTwoOff()
Sdack
Post by Sdack » Sat Nov 11, 2017 12:23 am
Thanks heaps Andy,
To be honest the learning curve is a lot steeper than I'd imagined. Every step of the way there's a component I've only vaguely heard of and never used, along with the various derivative devices and languages etc.
I really appreciate the help.
Sdack
Post by RogerClark » Sat Nov 11, 2017 1:20 am
Andy
Thanks for posting
I'm currently building a LoRa (wireless) beacon, so that code may come in handy to get the beacon to come on every 15 secs and give a pulse
Cheers
Roger
Sdack
Post by Sdack » Sat Nov 11, 2017 7:31 am
Would that be this touch screen?
https://www.adafruit.com/product/1651
I Googled and found a link to it via Roger Clarke's GitHub page
https://github.com/rogerclarkmelbourne/ ... LI9341_STM
s
Post by ahull » Sun Nov 12, 2017 12:05 am
The one I used was just the cheapest I could find on ebay. The original listing is long gone, but there are a lot of similar items.
Try searching ebay for "SPI ILI9341 240x320"
This one looks like it is probably the same.
https://www.ebay.co.uk/itm/240x320-2-4- ... SwstxVZ8f3
