Timer setup
ted
Timer setup
Post by ted » Sat Dec 23, 2017 2:03 am
Hi
Timers AVR to ARM
The program below is from arduino uno - timers setup, how to set up the timers in stm32f103 with the same functionality ?
 // Set up timer 1.
  // Prescaler = 1, phase correct PWM mode, TOP = ICR1A
    TCCR1A = (1 << COM1A1) | (1 << WGM11);
    TCCR1B = (1 << WGM12) | (1 << WGM13) | (1 << CS10);    // CTC mode, prescaler = 1
    TCCR1C = 0;
    OCR1AH = (TIMER1_TOP/2 >> 8);
    OCR1AL = (TIMER1_TOP/2 & 0xFF);
    ICR1H = (TIMER1_TOP >> 8);
    ICR1L = (TIMER1_TOP & 0xFF);
    TCNT1H = 0;
    TCNT1L = 0;
    TIFR1 = 0x07;      // clear any pending interrupt
    TIMSK1 = (1 << TOIE1);
    // Set up timer 0
    // Clock source = T0, fast PWM mode, TOP (OCR0A) = 7, PWM output on OC0B
    TCCR0A = (1 << COM0B1) | (1 << WGM01) | (1 << WGM00);
    TCCR0B = (1 << CS00) | (1 << CS01) | (1 << CS02) | (1 << WGM02);
    OCR0A = 7;
    OCR0B = 3;
    TCNT0 = 0;
    sei();
Re: Timer setup
Post by ag123 » Sat Dec 23, 2017 4:56 am
i think the 'old' timer examples from the original leaflabs documents still works
http://docs.leaflabs.com/docs.leaflabs.com/index.html
http://docs.leaflabs.com/static.leaflab ... dwaretimer
Re: Timer setup
Post by stevestrong » Sat Dec 23, 2017 9:00 am
And what exactly should be the "same functionality"?
Re: Timer setup
Post by dannyf » Sun Dec 24, 2017 8:00 pm
you want to figure out what the code was doing on the avr. in the case of timer1, it sets up a user specified top, phase correct pwm on ch a, ...
you then want to pick a timer to replicate that on the stm32. a 16-bit timer would be my choice. from there, pick the top via the period register; pick a up/down counter to be "phase correct", and then ....
Re: Timer setup
Post by mrburnette » Wed Dec 27, 2017 5:32 pm
The old libmaple docs had a section on timers:
http://docs.leaflabs.com/static.leaflab ... imers.html
May be helpful.
Use this query in Google for more info:
STM32F103  Arduino timers
And then there is the big ol' reference manual and a few application notes such as AN4776. <<< PDF warning
