"WAVGAT" black pill pull up resistor
arpruss
Post by arpruss » Wed Jan 24, 2018 2:21 am
Does anybody know if these "WAVGAT" black pills which have the same pinout as the blue pills also share the blue pill's wrong D+ pullup resistor?
arpruss
Re: "WAVGAT" black pill pull up resistor
Post by arpruss » Thu Feb 15, 2018 10:59 pm
Well, there was only one way to find out. I ordered it. Alas, R10 is 10K. It's basically just a recolored blue pill. :-(
Post by ahull » Fri Feb 16, 2018 12:30 am
On the plus side, the delivery was reasonably quick, and they look well made, and very cheap. :D I might order a couple.
arpruss
Post by arpruss » Fri Feb 16, 2018 5:53 am
Unless you need the few extra pins that this unit has, I'd order the more standard black pills, as they have the right resistor in place, are well made and cost a few cents less.
Post by zmemw16 » Fri Feb 16, 2018 2:09 pm
about 10% if my maths is correct. £1.50 ==> £1.37
