the right bootloader for this blue pill
joedodo2
Post by joedodo2 » Sat Feb 03, 2018 5:50 pm
I got this version of blue pill. so far I have burned the generic_boot20_pc13.bin (the about 20kb one) to it and in windows, the system found it as Maple Serial. In one sketch, I tried using Serial.println("abc"); it actually shows that in the serial monitor in windows. However, I can't make the led flash. I have tried the example from a standard arduino example set and also the stm32 example set, still no blinking led. So doesn't that mean the usb is not working? Do I need to solder the resistant? Or I used the wrong bootloader 2.0?
BTW, when I uploading a sketch using usb, it shows as this:
maple_loader v0.1
Found it!
Found Runtime: [0x1eaf:0x0003] devnum=1, cfg=0, intf=0, alt=2, name="STM32duino bootloader v1.0 Upload to Flash 0x8002000"
Setting Configuration 1...
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0400
bytes_per_hash=260
Done!
error resetting after download: usb_reset: could not reset device, win error: no connection。
Picked up _JAVA_OPTIONS: -Djava.net.preferIPv4Stack=true
Re: the right bootloader for this blue pill
Post by stevestrong » Sat Feb 03, 2018 6:01 pm
The LED may be soldered wrongly.
You can still check the PC13 pin whether it toggles or not.
Post by RogerClark » Sat Feb 03, 2018 8:57 pm
Ignore the error message at the end of the upload
It’s either a bug in dfu-util or the java thing which called dfu-util
It has uploaded
If the board does not go back to showing Maple Seial after upload , then the resistor will need to be changed.
If the LED is not flashing, then eitehr you have not loaded the PC13 version of the bootloader or the LED etc is defective
joedodo2
Post by joedodo2 » Sun Feb 04, 2018 4:24 am
Thanks Roger, after the uploading, I heard the usb unplug and plug sound from my windows and it is back shown as Maple Serial. But I tried the following sketch, there is no output from pin PA4. I measured it with a multi-meter it shows only 0.2V or so.
I checked all the ohter pins as well, and didn't find any pin outputs this pulse. In the bootloader master folder, there are "binaries" and "bootloader_only_binaries", folders. from which one should I choose bin?
pinMode(14, OUTPUT);
digitalWrite(14, HIGH); // turn the LED on (HIGH is the voltage level)
delay(10000); // wait for a second
digitalWrite(14, LOW); // turn the LED off by making the voltage LOW
delay(5000); // wait for a second
Post by mrburnette » Sun Feb 04, 2018 4:56 am
From the documentation here:
http://wiki.stm32duino.com/index.php?title=Blue_Pill
The LED for the "blue pill" is PC13
Do not use pin numbers .... it will make you crazy. Pin numbers is likely the most stupid thing Arduino.cc implemented.
I have more tips here: http://stm32duino.com/viewtopic.php?f=2&t=3111
joedodo2
Post by joedodo2 » Sun Feb 04, 2018 5:21 am
Oh, my.... I was testing again and again, I used pc13 and it complained and I thought okay, then I used the number ....
Some session should be added in the wiki, so people from arduino will know the right way. Thanks. @Roger
I guess one advantage of the numbers is that one can easily scan or output from/to a lot pins using loop. otherwise, one need to have an array or something similar and then map elements.
Post by mrburnette » Sun Feb 04, 2018 5:30 am
The information is in the WiKi and/or in the core documentation .. . While the forum accepts new users, the forum has no full-time moderators like Arduino.cc
https://github.com/rogerclarkmelbourne/ ... stallation
Windows
Copy the Arduino_STM32 folder to My Documents/Arduino/hardware (Note: if the hardware folder doesn't exist you will need to create it).
If using Maple or Maple mini, you need to install drivers for the Serial and DFU (upload devices). Please open a cmd window (run as administrator), navigate to the folder: /drivers/win/ and run: install_drivers.bat. Note: This doesn't actually install drivers. Windows comes pre-installed with a compatible Serial USB driver and a DFU (upload) driver. However the built in drivers need to be associated with the USB ID of the Maple serial and DFU devices. The batch file and wdi-simple.exe do the clever stuff to convince Windows 7 or newer, that it should use its drivers with the Maple serial and DFU devices.
Re-start the Arduino IDE, and select the appropriate board from the "Tools" -> "Board menu", and select the appropriate Com port for your Maple mini or serial upload device. Note: If you do not see a Maple Serial com device, this is probably because the Maple mini has not been loaded with the blink sketch. So upload a the Maple mini blink sketch from examples\Digital\Blink and the Maple serial device should now be available on the Port menu.
The STM32DUINO core is not like Arduino.cc
The core files "mimick" Arduino only from the point-of-view that the ArduinoIDE (unmodified) can compile-build-upload to some STM32 devices - not all devices are supported.
To further complicate life, the forum also has an Official Core for Nucleo Boards. Eventually, that section may make the stm32duino core obsolete.
Global Moderator, part-time
joedodo2
Post by joedodo2 » Sun Feb 04, 2018 7:34 am
Thanks very much.
Post by Pito » Sun Feb 04, 2018 10:57 am
I would recommend to create a simple sketch which will show you all works fine after the bootloader has been flashed in.
For example this one:
// Basic test for BluePill and friends
#define LED PC13
     delay(5000);                    // Wait till the USB Serial will be available at the PC side
     Serial.begin(115200);           // Start the Serial
     pinMode(LED, OUTPUT);           // Set LED pin to the output mode
     Serial.println(" Hello World !");
     digitalWrite(LED, HIGH);
     delay(1000);                    // Wait for a second
     digitalWrite(LED, LOW);
When it prints out and blinks then your BPill works fine most probably. When not, tell us what the problem is exactly..
Post by mrburnette » Sun Feb 04, 2018 2:02 pm
Thank you, Pito;
Many ArduinoIDE users fail to realize that the IDE pulls together all of the examples in the core into a nice, neat pick-list.
So, what would be very helpful is if we the extended members would run through these examples looking for improvements and also to validate after Roger makes a major merge from a pull-request.
