exit status 1 'Wire' does not name a type
dennyjim
Post by dennyjim » Tue Feb 06, 2018 1:56 pm
Can someone please help point me in the right direction
I get this error form the Wire library when i try to run YMFC-32_Flight_Controller_ver-1a
YMFC-32_Flight_Controller_ver-1a:19: error: 'Wire' does not name a type
 Wire.h(2, I2C_FAST_MODE);          //Initiate I2C port 2 at 400kHz.
C:\Users\Jim\Documents\Arduino\YMFC-32_Flight_Controller_ver-1a\YMFC-32_Flight_Controller_ver-1a.ino: In function 'void setup()':
YMFC-32_Flight_Controller_ver-1a:119: error: 'HWire' was not declared in this scope
   HWire.begin();                                                //Start the I2C as master
C:\Users\Jim\Documents\Arduino\YMFC-32_Flight_Controller_ver-1a\gyro_setup.ino: In function 'void gyro_setup()':
gyro_setup:5: error: 'HWire' was not declared in this scope
   HWire.beginTransmission(gyro_address);                        //Start communication with the MPU-6050.
C:\Users\Jim\Documents\Arduino\YMFC-32_Flight_Controller_ver-1a\read_gyro_data.ino: In function 'void gyro_signalen()':
read_gyro_data:5: error: 'HWire' was not declared in this scope
   HWire.beginTransmission(gyro_address);                       //Start communication with the gyro.
Using library Wire in folder: C:\Users\Jim\Documents\Arduino\hardware\Arduino_STM32\STM32F1\libraries\Wire (legacy)
exit status 1
Re: exit status 1 'Wire' does not name a type
Post by stevestrong » Tue Feb 06, 2018 2:00 pm
Please attach or point to some source code/sketch.
I think you have to use now TwoWire instead of HWire or Wire.
Post by mrburnette » Tue Feb 06, 2018 4:52 pm
The proper syntax is shown here:
viewtopic.php?f=51&t=3175#p40798
