Review: CZ mini STM32F103VET6 (infos, documents, BL…)
Re: Review: CZ mini STM32F103VET6 (infos, documents, BL…)
Post by Rick Kimball » Fri May 20, 2016 4:53 pm
No I just changed locally. This is a change to the Arduino IDE. I doubt they are going to change the IDE for boards they don't even support. In addition, I don't have any boards with that many Serial ports. I was just curious where it was hidden and I happened to be compiling the IDE when I read this post. You could probably get it to highlight without modifying the Arduino IDE by creating a new dummy library that just has a keyword.txt file containing Serial4, Serial5 keywords. Then you could just include that in any board that has lots of serial ports.
Post by RogerClark » Fri May 20, 2016 5:04 pm
OK
Post by Rick Kimball » Fri May 20, 2016 5:25 pm
This seems to work:
$ cat FatSerial/keywords.txt
# Syntax Coloring Map Servo
# Datatypes (KEYWORD1)
Serial4	KEYWORD1	Serial
Serial5	KEYWORD1	Serial
$ cat FatSerial/library.properties
name=FatSerial
version=1.0
author=Rick Kimball
maintainer=
sentence=Defines Serial4, Serial5
paragraph=This library only exists to get keyword highlighting on fat serial boards
category=Communications
url=http://www.arduino.cc/en/Reference/Serial
architectures=*
I also included an empty .c and .h file with the right name. See the attached zip file:
FatSerial.zip
(1.45 KiB) Downloaded 49 times
JBecker
Post by JBecker » Sat May 21, 2016 9:05 am
Perfect!
Thank you very much. It is just a small detail, but very 'nice to have'.
BR, Jörg.
Post by RogerClark » Sat May 21, 2016 1:33 pm
Rick
Can I add this to the repo?
Post by Rick Kimball » Sat May 21, 2016 1:51 pm
RogerClark wrote:Rick
Sure that would be great.
Post by RogerClark » Sat May 21, 2016 1:53 pm
Thanks Rick
I will see if I can do it this morning before heading over to Maker Faire
Manny
Post by Manny » Sat Jul 23, 2016 3:01 pm
madias wrote:
Todo:
Code example and libraries for SPI flash W25q16 and EEPROM 24C02
+1 Not managed to get any of them working which probably explains why I'm a plumber, any working examples would be greatly appreciated :mrgreen:
Manny
Post by Manny » Sat Jul 23, 2016 7:30 pm
Both compile with errors.
