Marlin FW - Analogwrite for PWM control
happytoto
Post by happytoto »
Hello,
I am currently playing with my 3D printer to add some LED strip. In the Marlin FW, the RGBW leds are controlled with an Analogwrite function such as in the standard arduino example:
  // fade in from min to max in increments of 5 points:
  for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
    // sets the value (range from 0 to 255):
    analogWrite(ledPin, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(30);
  // fade out from max to min in increments of 5 points:
  for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
    delay(30);
Although this method kind of works, the brightness of the led strip is at max roughly 50% of the max possible (ie connected to +12V). I don't understand why fully (I don't have an oscilloscope to look at the output) but it is what it is.
I tried a small program based on the page
  TIM_TypeDef *Instance = (TIM_TypeDef *)pinmap_peripheral(digitalPinToPinName(ledPin), PinMap_PWM);
  uint32_t channel = STM_PIN_CHANNEL(pinmap_function(digitalPinToPinName(ledPin), PinMap_PWM));
  // Configure and start PWM
  // MyTim->setPWM(channel, pin, 5, 10, NULL, NULL); // No callback required, we can simplify the function call
  MyTim->setPWM(channel, ledPin, 5000, 10);
  delay(5000);
  for (;;){
    for (int fadeValue = 0 ; fadeValue <= 100; fadeValue += 2) {
      MyTim->setPWM(channel, ledPin, 10000, fadeValue);
      delay(100);
    for (int fadeValue = 100 ; fadeValue >= 0; fadeValue -= 2) {
      delay(100);
In that case, I am getting the full brightness at max.
Without rewriting the Marlin FW, what would you recommend to do?
Optimal solution: analogwrite directly using the PWM hardwaretimer of the STM32
Thank you for your feedback
BennehBoy
Re: Marlin FW - Analogwrite for PWM control
Post by BennehBoy »
Is this down to DAC resolution?
Answers: 91
Strange, as if the pin has PWM capability then the HardwareTimer is used.
Except if the pin has DAC capabilities then it preferred to the PWM.
happytoto
Post by happytoto »
Following the first feedback. in the simple arduino example, I added analogWriteResolution(4) and I then got the full brightness range. Tried with a resolution of 8 but didn't get the full brightness for fade value of 0-255. I am not quite sure why.
I am left to ponder what is the right resolution 8, 16 (SMT32 documentation) or 4, 12.
Is the 16 the better one to choose?
BennehBoy
Post by BennehBoy »
You'd need to set the fade range from 0-4093 to get full brightness with a 12bit resolution.
You got full brightness with 4 bit, because that has a range of 0-15, so as soon as the fade hit 15 you would be at full brightness.
The resolution just gives you finer increments...
happytoto
Post by happytoto »
After trial and error, I think there is a bug (feature?) somewhere.
If I set 12bit resolution, I get the max_brightness for 2^(res+4) or 65535. I am not quite sure why.
here is the simple code to test:
#include <math.h>
int ledPin = 29;    // LED connected to digital pin 29
int max_fade;
int step_i;
int delay_i;
int res;
  res = 12;
  max_fade = 1 << (res+4);
  step_i = max_fade / 10;
  delay_i = 1000;
  analogWriteResolution(res);
  pinMode(ledPin, OUTPUT);
  // nothing happens in setup
  for (int fadeValue = 0 ; fadeValue <= max_fade; fadeValue += step_i) {
    delay(delay_i);
  for (int fadeValue = max_fade ; fadeValue >= 0; fadeValue -= step_i) {
    delay(delay_i);
Answers: 91
Which board ? (mcu)?
happytoto
Post by happytoto »
Answers: 91
I've tested with a Nucleo F767 using pin PC9 (D29 on the REMRAM) with the same TIM3 CH4 and I see no issue without the +4, I've checked with a analyser.
Anyway your code never reach 100% due to the rounding of the computation ( /10) , the wrong max res value which should be (1<< res ) - 1
int ledPin = PC9;    // LED connected to digital pin 29
static int step_i = 5;
static int delay_i = 2;
static int res = 8;
static int max_fade = (1 << (res)) - 1;
    delay(delay_i);
    delay(delay_i);
