Arduino for programming STM32f103c8t6 board
Re: Arduino for programming STM32f103c8t6 board
Post by zmemw16 » Sun Dec 06, 2015 2:31 pm
all my dual voltage serial interface modules have the link in the 3v3 position with the 5v pin bent away.
not snipped off as i might one day have a need.
Post by RogerClark » Sun Dec 06, 2015 7:24 pm
bianchifan wrote:
armleo wrote:1.I found that i can use ARDUINO UNO as USB to TTL by connecting RESET..
But you should have an eye on VCC..and perhaps level shifters.
Good point about the need for level shifters.
From what i recall the UART pins are not supposed to be 5v tollerant, but i think I connected them to an Arduino Uno and got away without blowing them up.
There would only need to be a voltage divider into the RX pin on the STM32, and I suspect the tricknof putting a 10k resistor in series with the RX pin may also work, if you dont have the correct resistors to make a full voltage divider
Post by mrburnette » Mon Dec 07, 2015 4:03 am
RogerClark wrote: <...>
See: Level Shifting Heading
darth_llamah
Post by darth_llamah » Sat Dec 19, 2015 9:39 pm
RogerClark wrote:Good point about the need for level shifters.
...or get a *duino running at 3.3V (like Seeeduino) and level shifter won't be necessary
madias
Post by madias » Sat Dec 19, 2015 11:11 pm
some words about level shifting:
got 20 of them for 6USD (so 80 channels ;) ) so I'll never think about level shifting problems anymore:
http://www.aliexpress.com/item/20pcs-lo ... 11638.html
Ok, didn't try out high speed connections like SPI, but with I2c it works like a charm.
armleo
Post by armleo » Mon Dec 21, 2015 4:30 pm
I programmed my stm32 using my friend's USB to Serial.
Now i see that my arduino can't be used as USB to TTL (becuase of desoldered/not soldered PULL-HIGH resistor)!
Madis my Level shifter works on freq up to 18MHZ but i have only 4 of them. (if anybody needs i can give link to AliExpress)
Post by mrburnette » Tue Dec 22, 2015 3:20 am
madias wrote:some words about level shifting:
Yep, got a handfull myself in a recent shipment on a slowboat. Just never know when one (or 2, or 3...) willcome in handy.
Post by zmemw16 » Tue Dec 22, 2015 1:31 pm
i found these @0.77ukp eeks i only got 4, i know why though.
as now 0.55ukp, ... ... , 8off is max with free shipping.
http://www.aliexpress.com/item/3-3V-5V- ... 56568.html
they might handle spi speeds ~8MBps?
TI datasheet http://www.ti.com/lit/ds/symlink/txs0108e.pdf has
                        1.8     2.5    3.3   5.0  V
Push-pull driving       40      60    60    60 Mbps
Open-drain driving        2     2   2   2   Mbps
moc
Post by moc » Tue Dec 29, 2015 6:39 pm
Hello friends,
I have trouble getting my "blue pill" STM32 to work.
What I have done:
- I have a (working) Arduino Nano as a USB to serial adapter (with CH340G chipset):
RESET is connected to GND
RX is connected to TX (STM, PIN9) via a level shifter
TX is connected to RX (STM, PIN10) via a level shifter
Arduino GND is connected to the level shifter and then to the STM32 GND.
Boths microcontrollers are powered via USB cables. (Is this the problem)?
- I tried Arduino 1.6.3/4/5 and extracted the "Arduino_STM32_master.zip" to the .../hardware/ folder. The Cortex M3 package is installed via the IDE.
-I can upload sketches to the Arduino, the RX led flashes just the way it should and everything works. But when I try to flash to the STM32 (via Serial/COM3), it stops after compiling and tells me:
Failed to init device.
stm32flash 0.4
http://stm32flash.googlecode.com/
Using Parser : Raw BINARY
Interface serial_w32: 230400 8E1
The RX LED flashes just two times and so dim, that you can barely see it.
I know that I should buy a ST-LINK but I would like to start this project right know and don't wanna wait any longer!
Cheers for the help!
Post by mrburnette » Tue Dec 29, 2015 8:19 pm
@moc:
What I have done:
I understand this will work on an UNO; but, I have never heard of a Nano being used in this way. Did you test if by "looping" Send to Receive and use a terminal program on PC.
You only need one (1) level-shifter, from 5V send to 3.3V Receive.
3.3V Send can go directly to 5V Receive.
stm32flash 0.4
So, (IF) you got a "clean" compile... all libs and core files found for STM32... then the software should be OK.
I understand you are in a hurry to play, but when you go off and create a frankenstein bundle of wires and stuff, it really is difficult for us to help you. Do a serial loopback on Nano first.
