Interrupts in HAL core for STM32F1 broken or daft programmer??
mailhouse
Postby mailhouse » Tue Nov 01, 2016 12:42 am
board is nucleo stm32f103rb, arduino.cc ide 1.6.12
any time i try to set an IRQ, the board crashes. comment out the IRQ assignment and it runs like a champ, albeit without interrupts. any help is appreciated.
if the NVIC_EnableIRQ is after the TIM_CR1_CEN, then it hangs on the NVIC assignment. as below, it hangs on the TIM_CR1_CEN.
what am i not getting?
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect.
  Serial.println("Setting up TIM2");
  RCC->APB1ENR |= RCC_APB1ENR_TIM2EN;
  TIM2->SR = 0;   // Clear status register flags
  TIM2->PSC = 2000; // Set prescaler
  TIM2->ARR = 36000;  // set auto-reload register
  TIM2->DIER = TIM_DIER_UIE;  // update interrupt
  Serial.println("Enabling TIM2 IRQ");
  NVIC_SetPriority(TIM2_IRQn, 0);
  //NVIC_EnableIRQ(TIM2_IRQn);
  Serial.println("Enabling TIM2");
  TIM2->CR1 |= TIM_CR1_CEN;  // set control register 1 enable flag
  Serial.println(TIM2->SR, BIN);
  Serial.println("TIM2 setup complete");
  pinMode(13, OUTPUT);
    //Serial.println(TIM2->CNT);
    if (TIM2->CNT == 35000)
    digitalWrite(13, HIGH);
    if (TIM2->CNT == 36000)
    digitalWrite(13, LOW);
void TM2_IRQHandler(void)
if(TIM2->SR & TIM_SR_UIF) // if UIF flag is set
  TIM2->SR &= ~TIM_SR_UIF; // clear UIF flag
  Serial.println("TM3 Interrupt");
using the HAL library calls has the same effect.
#ifdef __cplusplus
extern "C"
TIM_HandleTypeDef s_TimerInstance = {
    .Instance = TIM2
void InitializeTimer()
    __TIM2_CLK_ENABLE();
    s_TimerInstance.Init.Prescaler = 36000;
    s_TimerInstance.Init.Period = 2000;
    s_TimerInstance.Init.CounterMode = TIM_COUNTERMODE_UP;
    s_TimerInstance.Init.RepetitionCounter = 0;
    s_TimerInstance.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
    HAL_NVIC_SetPriority(TIM2_IRQn, 0, 0);
    //HAL_NVIC_EnableIRQ(TIM2_IRQn);
    HAL_TIM_Base_Init(&s_TimerInstance);
    HAL_TIM_Base_Start_IT(&s_TimerInstance);
void InitializeLED()
    __GPIOA_CLK_ENABLE();
    GPIO_InitTypeDef GPIO_InitStructure;
    GPIO_InitStructure.Pin = GPIO_PIN_5;
    GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStructure.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
  while (!Serial) {
    HAL_Init();
    Serial.print("HAL Version 0x");
    Serial.println(HAL_GetHalVersion(), HEX);
    Serial.print("Device ID ");
    Serial.println(HAL_GetDEVID());
    InitializeLED();
    InitializeTimer();
        int timerValue = __HAL_TIM_GET_COUNTER(&s_TimerInstance);
        if (timerValue == 1950)
            HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET);
        if (timerValue == 2000)
            HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET);
        //Serial.println(timerValue);
        if (__HAL_TIM_GET_FLAG(&s_TimerInstance, TIM_FLAG_UPDATE) != RESET)
            __HAL_TIM_CLEAR_IT(&s_TimerInstance, TIM_IT_UPDATE);
            HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_5);
            //Serial.println("Update event");
Re: Interrupts in HAL core for STM32F1 broken or daft programmer??
Postby RogerClark » Tue Nov 01, 2016 2:13 am
Which core are you using, the one in the stm32duino github account ?
mailhouse
Postby mailhouse » Tue Nov 01, 2016 2:22 am
yes the github ones STM32F1 and STM32L4. should i be using something else?
Postby RogerClark » Tue Nov 01, 2016 2:43 am
Thats the new official STM core, which has been designed by STM for use with the Nucleo board.
We also have the old repo / core based on the original Leaflabs LibMaple code.
This also has support for the Nucleo F103RB bit not the L476 nucleo etc
But the LibMaple based repo does not use HAL, its a clean room implementation by Leaflabs because of licence restrictions when they wrote it in 2012
Anyway, if there is a bug in the Official STM core, you really need to log it as a bug in GitHub, or possibly post to one of the threads on this forum dedicated to that core.
This is the best thread to post to
viewtopic.php?f=48&t=1413&start=50
Because its monitored by Wi6Labs who actually wrote the code for STM
Postby RogerClark » Tue Nov 01, 2016 2:44 am
Actually, if you don't have a github account, I will log the issue for you and reference this thread
mailhouse
Postby mailhouse » Tue Nov 01, 2016 1:54 pm
before i go reporting bugs, can someone else repeat the behavior?
Postby RogerClark » Tue Nov 01, 2016 7:39 pm
Is it possible it is a bug in your code?
Does the same code compiled and run in another enviromment than the Arduino core and Arduino IDE?
mailhouse
Postby mailhouse » Tue Nov 01, 2016 11:17 pm
its entirely possible. im very new to stm32, and new to 32bit mcu in general. its why im asking here first.
Postby RogerClark » Tue Nov 01, 2016 11:38 pm
mailhouse wrote:its entirely possible. im very new to stm32, and new to 32bit mcu in general. its why im asking here first.
I don't think there are that many members of the forum that use the HAL, as until fairly recently the only Arduino STM core we had was the one written by Leaflabs (LibMaple) , which doesn't use the HAL.
You could try posting to STM's own official forum, which has lots of HAL users and one of them may be able to help.
Effectively what is missing from the STM Arduino core is Hardware Timer support.
We have this in LibMaple, as an internal implementation, but what the STM core needs is something like the AVR Arduino "Timer1" etc
http://playground.arduino.cc/Code/Timer1
But as this is not an internal Arduino library, I don't think it would be on STM's To Do list, as AFIK they only intend to support internal Arduino libraries
danieleff
Postby danieleff » Wed Nov 02, 2016 6:03 am
There is timer interrupt in timer.c, for example:
void blink(timer_id_e timer, uint32_t counter) {
  digitalWrite(13, !digitalRead(PB1));
  TimerPulseInit(TIM2_E, 36000, 1000, blink);
It is not exactly what you want, but check out that code.
Return to “STM Nucleo boards”
Who is online
