STM32F091RC I2C not working
GianniDPC
Post by GianniDPC » Thu Jun 22, 2017 10:16 am
Hello,
I'm using an Arduino sketch to read a TC74 temperature sensor, But the outcome is not as expected it does not detect the sensor that is connected to PB8 (SCL) en PB9 (SDA).
I tried other arduino sketches that simple make use of the GPIO pins and such and those work fine. But I can't seem to get I2C working. I looked into the source code that I linked below and it is indeed using PB8 and PB9 for I2C.
How can I solve this? Or is this a known bug or something.
My sketch:
// TC74A0
#define address B1001000
#define baudrate 9600
byte val = 0;
    Wire.begin();
    Serial.begin(baudrate);
    Serial.print("temperature in Celsius: ");
    int temperature;
    Wire.beginTransmission(address);
    Wire.write(val);
    Wire.requestFrom(address, 1);
      if (Wire.available()) {
      temperature = Wire.read();
      Serial.println(temperature);
      else {
      Serial.println("---");
    delay(2000);
https://github.com/stm32duino/Arduino_C ... 32f0/twi.c
GianniDPC
Re: STM32F091RC I2C not working
Post by GianniDPC » Thu Jun 22, 2017 2:05 pm
Nvm. I fixed it.
By anyone wondering how, I used 2 4K7 pull-up resistors as in the image below. I didn't need them when I wrote a similair program in STM32Cube though, I guess STM32duino doesn't use the internal pull-ups.
Post by stevestrong » Thu Jun 22, 2017 2:11 pm
The STM32 internal pull-up resistors are very weak (30..50k), so a working I2c always need extra pull-ups.
