Programming Nucleo F302R8
Boian Mitov
Post by Boian Mitov » Sun Jul 09, 2017 9:09 pm
Hello everyone,
I am trying to program Blink on Nucleo F302R8.
It seems to upload successfully:
STM32 ST-LINK CLI v2.1.0
STM32 ST-LINK Command Line Interface
ST-LINK SN : 066EFF495056805087162434
ST-LINK Firmware version : V2J22M5
Connected via SWD.
SWD Frequency = 1800K.
Connection mode : Normal.
Device ID:0x439
Device flash Size : 64 Kbytes
Device family :STM32F301x4-x6-x8/F302x4-x6-x8/F318xx
Loading file...
Flash Programming:
File : C:\Users\mitov\AppData\Local\Temp\arduino_build_554753\Blink.ino.bin
Address : 0x08000000
Flash memory programming...
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
0%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 100%
Flash memory programmed in 0s and 469ms.
Programming Complete.
MCU Reset.
Application started.
However there is no blinking :-( . I tried PA5, D13 and 13 as LED pins. None of them works :-(
Any suggestions?
I used the only available option from the menu - STM Nucleo F103B (STLink).
Re: Programming Nucleo F302R8
Post by victor_pv » Mon Jul 10, 2017 1:58 am
That's the wrong option for programing and F302, the F1 and F3 series are not exactly the same.
Try selecting another F3 board better.
Boian Mitov
Post by Boian Mitov » Mon Jul 10, 2017 6:10 pm
I installed the latest support from teh board manager:
https://github.com/stm32duino/wiki/wiki/Boards-Manager
Using:
And installing:
STM32 Cores
The closest board I see seems to be :
Nucleo-64 / F303RE
I upload using the STLink.
It still does not work with it :-(
Sketch uses 10456 bytes (1%) of program storage space. Maximum is 524288 bytes.
Global variables use 3072 bytes (4%) of dynamic memory, leaving 62464 bytes for local variables. Maximum is 65536 bytes.
C:\Users\mitov\AppData\Local\Arduino15\packages\STM32\tools\STM32Tools\2017.5.12/tools/win/stlink_upload.bat COM12 {upload.altID} {upload.usbID} C:\Users\mitov\AppData\Local\Temp\arduino_build_585240/Blink.ino.bin
Connected via SWD.
Device ID:0x439
Loading file...
Flash Programming:
File : C:\Users\mitov\AppData\Local\Temp\arduino_build_585240\Blink.ino.bin
Flash memory programmed in 0s and 657ms.
MCU Reset.
What is strange on the USB Port now it shows it as :
COM12(Nucleo F103RB)
It could be because before I uploaded code generated for the F103RB.
What should I do?
Boian Mitov
Post by Boian Mitov » Mon Jul 10, 2017 6:12 pm
This is how the Arduino IR reports the board now:
BN: Nucleo F103RB
VID: 0483
PID: 374B
SN: 066EFF495056805087162434
Post by victor_pv » Tue Jul 11, 2017 4:02 am
You are using the official STM core, so you may want to post here, that's the forum for that core:
http://www.stm32duino.com/viewforum.php?f=48
About seeing the 103rb serial, it could be that or it could be the virtual serial port from the stlink in that board.
vargham
Post by vargham » Tue Jul 11, 2017 5:24 am
> The closest board I see seems to be: Nucleo-64 / F303RE
The MCU must be exactly the same.
Boian Mitov
Post by Boian Mitov » Tue Jul 11, 2017 9:25 pm
As you can see from my post the F303RE fails :-( .
I may have damaged the firmware on the board. How to update the Firmware?
vargham
Post by vargham » Wed Jul 12, 2017 3:50 am
I don't think. There are two MCUs on the board. The target: STM32F302, and the debugger: STM32F103. The debugger has its own firmware. You can alway upload new firmware to the target MCU. Try to connect with ST-Link utility to check debugger. http://www.st.com/en/embedded-software/ ... nk004.html
The fastest and easiest way to check your board:
Register at https://developer.mbed.org
Add Nucleo F302 to your boards https://developer.mbed.org/platforms/ST-Nucleo-F302R8/.
Import Nucleo blink led to online compiler https://developer.mbed.org/teams/ST/cod ... 0/main.cpp.
Compile, and upload the bin to the board. You can use the USB mass storage mode or ST-Link Utility.
Or, here is the compiled blinky for you:
Nucleo_blink_led_NUCLEO_F302R8.bin.txt
(21.2 KiB) Downloaded 24 times
You have to remove .txt from the end.
