Fast PWM on Nucleo-F030R8 with Arduino IDE
Ollie
Re: Fast PWM on Nucleo-F030R8 with Arduino IDE
Post by Ollie » Fri Aug 04, 2017 2:48 pm
For the developers who are using both Teensy and STM32duino boards, it would be nice if the two libraries would be compatible. In this case, the PWM frequency is already managed by Teensy library, and it would be nice if the support is added using the same syntax and functionality.
Post by Rick Kimball » Fri Aug 04, 2017 3:20 pm
Good idea @Ollie
analogWriteFrequency (pin, frequency)
analogWriteFrequency(4, 375000); // Teensy 3.0 pin 3 also changes to 375 kHz
Post by fpiSTM » Fri Aug 04, 2017 7:47 pm
If you have any API reference already available no problem ;)
I will check Teensy api.
Post by RogerClark » Fri Aug 04, 2017 9:27 pm
Sometimes another good place to look is the EPS8266 implementation.
Post by Rick Kimball » Fri Aug 04, 2017 9:54 pm
Seems that the esp8266 takes a global approach setting the frequency that affects all pwm output. That might be a hardware limitation
http://esp8266.github.io/Arduino/versio ... log-output
Post by RogerClark » Fri Aug 04, 2017 10:37 pm
I think we probably have a similar limitation,because I think the pins probably share timers.
Edit
Well, we have multiple timers but probably going for a global approach would lead to less confusion
timer2 /* PA0 */
timer2 /* PA1 */
timer2 /* PA2 */
timer2 /* PA3 */
timer3 /* PA6 */
timer3 /* PA7 */
timer1 /* PA8 */
timer1 /* PA9 */
timer1 /* PA10 */
timer1 /* PA11 */
timer3 /* PB0 */
timer3 /* PB1 */
timer4 /* PB6 */
timer4 /* PB7 */
timer4 /* PB8 */
timer4 /* PB9 */
Should not be too difficult to code as we already have
https://github.com/rogerclarkmelbourne/ ... #L103-L118
BTW.
I wonder whether the teensy really can run all its PWM pins at different rates?
Post by RogerClark » Sat Aug 05, 2017 4:22 am
I've investigated how we can add this in LibMaple
This example allows the period
#include <libmaple/rcc.h>
  pinMode(PA0,PWM);
  #define MAX_RELOAD ((1 << 16) - 1)
  uint32_t pwmFreqHz = 100000;
  uint32_t period_cyc = F_CPU / pwmFreqHz;
  uint16_t prescaler = (uint16)(period_cyc / MAX_RELOAD + 1);
  uint16_t overflow = (uint16)((period_cyc + (prescaler / 2)) / prescaler);
  timer_set_prescaler(&timer2, (uint16)(prescaler - 1));
  timer_set_reload(&timer2, overflow);
 // analogWriteResolution(8);
  int duty=128;// 0 - 255
  pwmWrite(PA0,(timer_get_reload(&timer2) * duty)/255);
  //analogWrite(PA0,1);
  while (1)
    Serial.print("prescaler: ");
    Serial.print(prescaler);
    Serial.print(" overflow: ");
    Serial.println(overflow);
One problem I can see is if anyone changes the frequency, the value that needs to be passed to pwmWrite would change, as the overflow value may no longer be 65535 (max unsigned 16 bit number)
So for maximum conpatibility I would need to change pwmWrite as well as analogWrite
However I'm tempted to leave pwmWrite alone and just modify analogWrite so that it reads the current overflow value using timer_get_reload()
And... I've also realised we don't currently support
analogWriteResolution()
This would not be that hard to implement, except we'd need a global to store this setting, so that analogWrite can determine the divisor value that is required.
Also...
In terms of whether we follow the teensy or ESP8266 API.
The ESP8266 API causes the least confusion, as we could initialise all the timers with the same prescaler and overflow at in the same function.
We could also implement the Teensy style API, e.g. its a different function signature, but if people tried to set 2 pins which use the same timer with different frequencies, they may not get what they expect
