[SOLVED] stm32f303 - warning: changing start of section .text by 8 bytes
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Wed Nov 08, 2017 12:49 pm
Hello after installing everything when I compiled a program
I get this. and when I compiled it using as a destination in arduino nano, nothing came out. Does anyone know what this is?
ld.exe: warning: changing start of section .text by 8 bytes
ld.exe: warning: changing start of section .bss by 4 bytes
Program size: 34.932 bytes (used 53% of a 65.536 byte maximum) (1,31 secs)
Minimum Memory Usage: 6844 bytes (56% of a 12288 byte maximum)
Uploading 'PROG' to 'Nucleo-32' using 'COM11'
STM32 ST-LINK CLI v3.0.0.0
STM32 ST-LINK Command Line Interface
ST-LINK SN : 0676FF323535474B43033459
The upload process has finished.
ST-LINK Firmware version : V2J29M18
Connected via SWD.
SWD Frequency = 4000K.
Target voltage = 3.3 V.
Connection mode : Normal.
Device ID:0x438
Device flash Size : 64 Kbytes
Device family :STM32F303x4-x6-x8/F328xx/F334xx
Loading file...
Flash Programming:
File : E:\PROG.ino.bin
Address : 0x08000000
Memory programming...
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
0%ÛÛÛÛÛÛÛÛÛÛÛÛÛ 27%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 54%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 82%ÛÛÛÛÛÛÛÛÛ 100%
Memory programmed in 3s and 463ms.
Programming Complete.
MCU Reset.
run application to exit
Application started.
Thanks and best regards.
Last edited by FRANCISCOGIMENO on Thu Nov 09, 2017 9:03 am, edited 1 time in total.
Re: stm32f303 - warning: changing start of section .text by 8 bytes
Post by fpiSTM » Wed Nov 08, 2017 1:08 pm
it's only a warning. I will correct all those one.
it only warn us about a misalignment of a section in the linker script but it is corrected by the linker.
To avoid this warning, correction is to add ALIGN(x) in the impacted section. Ex for the:
Replace:
  .text :
by
  .text ALIGN(8):
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Wed Nov 08, 2017 1:34 pm
Thanks for your response, but what is the file that is changed?
Thank you very much.
Fran
Post by fpiSTM » Wed Nov 08, 2017 2:04 pm
the file is in the variant: ldscript.ld
https://github.com/stm32duino/Arduino_C ... ipt.ld#L61
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Wed Nov 08, 2017 5:07 pm
Hello, that I have changed it and the message of 8 and it does not appear. But this continues to appear:
Program size: 34.940 bytes (used 53% of a 65.536 byte maximum) (73,10 secs)
:shock:
Post by fpiSTM » Wed Nov 08, 2017 5:41 pm
You have corrected only the .text section. But you have to do it also for the .bss. with align(4). ;)
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Wed Nov 08, 2017 5:48 pm
But is it in the same file?
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Wed Nov 08, 2017 6:02 pm
I have already found it and I have changed it but when I compile
It gives me this error:
Compiling 'prog' for 'Nucleo-32'
ld.exe: address 0x100011e4 of ....prog.ino.elf section .bss is not within region RAM
ld.exe: ...prog.ino.elf section ._user_heap_stack will not fit in region RAM
Error linking for board Nucleo-32
ld.exe: address 0x100011e4 of ...prog.ino.elf section .bss is not within region RAM
Build failed for project 'prog'
ld.exe: region RAM overflowed by -268441624 bytes
collect2.exe*: error: ld returned 1 exit status
I left it as it was.
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Wed Nov 08, 2017 6:09 pm
in that section it is different than in the text
/* Uninitialized data section */
. = ALIGN(4);
.bss : <------------------------------------------------------------------------------I have changed this by: .bss ALIGN(4):
/* This is used by the startup in order to initialize the .bss secion */
_sbss = .; /* define a global symbol at bss start */
__bss_start__ = _sbss;
*(.bss)
*(.bss*)
*(COMMON)
. = ALIGN(4);
_ebss = .; /* define a global symbol at bss end */
__bss_end__ = _ebss;
} >RAM
/* User_heap_stack section, used to check that there is enough RAM left */
._user_heap_stack :
. = ALIGN(8);
PROVIDE ( end = . );
PROVIDE ( _end = . );
. = . + _Min_Heap_Size;
. = . + _Min_Stack_Size;
. = ALIGN(8);
} >RAM
/* Remove information from the standard libraries */
/DISCARD/ :
libc.a ( * )
libm.a ( * )
libgcc.a ( * )
.ARM.attributes 0 : { *(.ARM.attributes) }
Post by fpiSTM » Wed Nov 08, 2017 7:23 pm
Which board you used?
Which sketch?
