[SOLVED] stmf303 Blink led because so much memory used?
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Thu Nov 09, 2017 8:13 am
Hello friends, after compiling for the stmf303 the led example to see how the resources go. I see this:
Sketch uses 10504 bytes (16%).
Var Global 2936 bytes (23%)
I already know that the boot occupies, but you can eliminate some of the core that was not used.?
I have searched but I do not see anything that tells you clearly if you can or not.
a greeting
Fran
Last edited by FRANCISCOGIMENO on Fri Nov 10, 2017 6:13 pm, edited 1 time in total.
Re: stmf303 Blink led because so much memory used?
Post by fpiSTM » Thu Nov 09, 2017 8:24 am
So with Arduino IDE it is ok but not with VSmicro ?
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Thu Nov 09, 2017 9:06 am
I do not understand the question. :shock:
Post by fpiSTM » Thu Nov 09, 2017 9:22 am
Which build environment you use?
Official Arduino IDE ? other ?
About the clean the build already removed unused function.
But there are several pre-instanciate instance (Serial, I2C, SPI,...)
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Thu Nov 09, 2017 9:46 am
I use visual micro.
But when using the debug function does not work with this board.
After compiling blink led in visual micro ide:
Program size: 10.404 bytes (used 16% of a 65.536 byte maximum) (65,80 secs)
Minimum Memory Usage: 2328 bytes (19% of a 12288 byte maximum)
After compiling blink led ide arduino:
Post by fpiSTM » Thu Nov 09, 2017 10:13 am
Ok so you use VSMicro.
What is exactly your request ?
Decrease the size of the binary and the RAM consumption ?
The small difference btw the 2 results probably came from different built options (-Ox, gcc version,...) I do not use VSMicro, so I don't know how this is configured.
One option to decrease the size is to remove some instances preinstanciate I think. And also disable some HAL feature (ex for blink I2C, SPI, PWM , DAC, ADC are not required)
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Thu Nov 09, 2017 10:17 am
Visual micro gives these options, are the image in the attachment
What id do you use?
Post by fpiSTM » Thu Nov 09, 2017 11:06 am
by default -OS.
It seems VSMicro uses well the boards.txt and platform.txt of the core.
As I said I do not know the VSMicro.
To have a little gain, for blink sketch you can set the Option 2 to No serial this will remove the Serial instance
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Thu Nov 09, 2017 11:19 am
What ide do you use?
Post by fpiSTM » Thu Nov 09, 2017 12:44 pm
