[SOLVED] SB9 ST-LINK RESET
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Fri Nov 17, 2017 8:46 am
Hi friends I have a question, when you feed the circuit by the + 5v pin it does not start.
After feeding with 5v, if I connect the usb starts and the program runs, if I remove the usb it stops again.
I have seen that the "SB9 ST-LINK RESET" bridge must be removed when it is powered with 5v.
Can someone tell me if this is correct?
And when removing this bridge I can continue programming from the usb?
a greeting
Fran
Last edited by FRANCISCOGIMENO on Mon Nov 20, 2017 11:00 am, edited 1 time in total.
FRANCISCOGIMENO
Re: SB9 ST-LINK RESET
Post by FRANCISCOGIMENO » Mon Nov 20, 2017 10:56 am
Hello friends, after several tests, confirm that if the module is used
With external current supply (+ 5V) that bridge (sb9) must be removed.
a greeting
