How to change the clock speed of STM32L476RG nucleo board?
SHARANYA
Post by SHARANYA » Sat Nov 25, 2017 6:46 pm
Hi experts
I was just wondering about the speed of the stm32l476rg nucleo board!
For say,the arduino uno operates on 16Mhz.What is the clock speed of the stm32l476 in the Arduino environment?
Re: What is the speed of STM32L476RG nucleo board?
Post by zmemw16 » Sat Nov 25, 2017 7:14 pm
http://www.st.com/en/evaluation-tools/n ... 476rg.html
user manual is UM1724. Crystal i noticed is 8MHz if it's fitted :!: brief glance suggested not as there's a detailed paragraph about it's required characteristics.
obtain CubeMX, also the F7 libraries(there's an update menu for doing this in CubeMX), probably need to acquire ARM tools compiler gcc 6.x.x
have a play in the configuration window, change the hse clock value and see what happens.
you will need to register in order to download the CubeMX package and click to accept license.
scanning the datasheet suggests 80MHz, highest frency in the current consumption table, i think lowest was 100KHz, maybe even 32kHz
Post by fpiSTM » Sat Nov 25, 2017 7:16 pm
Thanks the HSI (16MHz), it could operate up to 80MHz.
SHARANYA
Post by SHARANYA » Sat Nov 25, 2017 7:47 pm
I used to program the stm32l476 using hal and cube mx before so I have an idea.But how to define the clock speed in the arduino environment?
Also is there a way to know what the current speed the cpu is operating on?
Post by fpiSTM » Sat Nov 25, 2017 8:07 pm
Which Arduino core you used?
If it is this one: https://github.com/stm32duino/Arduino_Core_STM32
You could redefine the void SystemClock_Config(void) in the sketch.
extern "C" void SystemClock_Config(void) {...}
To know the cpu speed, you could use this global variable:
SystemCoreClock
SHARANYA
Post by SHARANYA » Sat Nov 25, 2017 10:07 pm
Can you please give an code example.I am not very fluent in the arduino thing!
I tried like this below in the arduino:
  #define F_CPU 80000000
  SystemCoreClockUpdate();
  pinMode(13,OUTPUT);
  digitalWrite(13,HIGH);
  digitalWrite(13,LOW);
But it is not changing anything in the scope!!
SHARANYA
Re: How to change the clock speed of STM32L476RG nucleo board?
Post by SHARANYA » Sun Nov 26, 2017 10:52 am
Ok.....now i am able to get the current CPU core clock speed by writting this small piece of code.
extern uint32_t SystemCoreClock;
Serial.println(SystemCoreClock);
Also i was toggling pin-D13 by writting digitalWrite high/low and hooked up a scope to that pin.But I could only get a frequency of about 400khz(Instead the cpu is running at 80MHz).Why it is so slow?Is there a way to make it fast by directly accessing the GPIO registers?
Post by stevestrong » Sun Nov 26, 2017 12:14 pm
Search the forum for fast GPIO access.
For example: viewtopic.php?f=18&t=2888
SHARANYA
Post by SHARANYA » Sun Nov 26, 2017 1:22 pm
I tried this code below.But i'm getting the speed of 2.72MHz max.The off time is much more longer than on time.Why is this happening?
  pinMode(13,OUTPUT);
GPIOA->BSRR = (1<<5);
GPIOA->BRR = (1<<5);
Post by Pito » Sun Nov 26, 2017 1:44 pm
Here
viewtopic.php?f=18&t=2888&p=37578#p37593
you may see a for-loop takes 417ns with toggling 1/0 (BRR/BSRR registers) at 72MHz, that is 2.39MHz toggling freq..
In order to maximize your io pin frequency you must "unroll the loop".
The max frequency you may see on your oscope is F_CPU/6 (you need 6clocks to toggle once), provided your unrolled loop is large enough.. :)
EDIT: F_CPU/6 with F103, with F476 it may differ (art accelerator).
