[Solved]Cant use Serial.print in setup()
feel
Post by feel »
Hi, i got issues when i try to use Serial.print func in setup(). Here the code i use
 Serial.print("Hello, World");
I use STM32F411CEU6 Board, thank you!
by fpiSTM » Fri Jul 09, 2021 4:51 pm
Try this as stated before:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB
And check that Serial is properly enumerated and you select the right COM port.
Re: Cant use Serial.print in setup()
Well with those information what did you expect ?
Which core?
Which target selected? generic? blackpill?...
Is it Hardware Serial or USB CDC ?
If Serial is the USB CDC then you have to wait after the begin.
While(!Serial){};
https://www.arduino.cc/reference/en/lan ... /ifserial/
feel
Post by feel »
i use this settings for my code
can you describe your issues?
what is the serial terminal/monitor that you are using?
did you try
Serial.println("hello world") instead?
did you manage to blink the led?
have you reviewed these links?
viewtopic.php?f=2&t=3
viewtopic.php?f=2&t=301
  while (!Serial) {
oh and in linux modemmanager can mess with usb-serial, but describe it more as we've no idea what is wrong.
if you are using linux and you suspect modemmanager could be causing it, check the faq in the wiki
https://github.com/stm32duino/wiki/wiki ... itor-fails
feel
Post by feel »
Thanks it worked! i just try to print something in setup() in my project but i found out its not working.
thank you for the support guys
feel wrote: Sat Jul 10, 2021 6:35 am Thanks it worked! i just try to print something in setup() in my project but i found out its not working.
Fine. The while was the solution?
feel
Post by feel »
Yeah the while was the solution, im still new to use this stm32duino so i'd need to learn much things
