RTC subseconds
jenspogo
RTC subseconds
Post by jenspogo »
Hey everybody :)
I'm using the STM32RTC.h lib on a Bluepill and would like to print data and timestamps into a .csv file.
I think rtc.getSubSeconds should give back milliseconds or am I wrong? I tried a small example and get back only zeros.
Does somebody know what I am doing wrong?
#include "STM32RTC.h"
/* Get the rtc object */
STM32RTC& rtc = STM32RTC::getInstance();
/* Change these values to set the current initial time */
const byte seconds = 30;
const byte minutes = 28;
const byte hours = 15;
/* Change these values to set the current initial date */
/* Monday 15th June 2015 */
const byte weekDay = 2;
const byte day = 19;
const byte month = 5;
const byte year = 20;
  // Select RTC clock source: LSI_CLOCK, LSE_CLOCK or HSE_CLOCK.
  // By default the LSI is selected as source.
  //rtc.setClockSource(STM32RTC::LSE_CLOCK);
  rtc.begin(); // initialize RTC 24H format
  // Set the time
  rtc.setHours(hours);
  rtc.setMinutes(minutes);
  rtc.setSeconds(seconds);
  // Set the date
  rtc.setWeekDay(weekDay);
  rtc.setDay(day);
  rtc.setMonth(month);
  rtc.setYear(year);
  // you can use also
  //rtc.setTime(hours, minutes, seconds);
  //rtc.setDate(weekDay, day, month, year);
  // Print date...
  print2digits(rtc.getDay());
  Serial.print(".");
  print2digits(rtc.getMonth());
  Serial.print(".");
  print2digits(rtc.getYear());
  Serial.print(" ");
  // ...and time
  print2digits(rtc.getHours());
  Serial.print(":");
  print2digits(rtc.getMinutes());
  Serial.print(":");
  print2digits(rtc.getSeconds());
  Serial.print(":");
  print2digits(rtc.getSubSeconds());
  Serial.println();
  delay(100);
void print2digits(int number) {
  if (number < 10) {
    Serial.print("0"); // print a 0 before if the number is < than 10
  Serial.print(number);
Result:
19.05.20 15:28:35:00
19.05.20 15:28:36:00
19.05.20 15:28:37:00
Answers: 92
Re: RTC subseconds
There is no issue.
STM32F1 does not support subseconds as it is not available like on other STM32 series.
jenspogo
Re: RTC subseconds
Post by jenspogo »
ok, thanks!
Are there any Ideas how to build a workaround? maybe with the millis(); function?
Answers: 92
Re: RTC subseconds
Well no idea.
I guess using millis() will not be precise due to the time needed for computation?
jenspogo
Re: RTC subseconds
Post by jenspogo »
Might be true.
I thought about a combination of the RTC and a Millie Counter only between the logging calls.
I will try it out and if the results are more or less acceptable, I will show it here.
