Designing a new board around existing firmware-F407 vs F417
Xnke
Post by Xnke »
As the title explains, I am working on a hardware-port to use existing stocks of STM32F417ZGT6 micros, when the original firmware/coding was for an STM32F407VGT6. I'm pretty green on the STM32, I have built one rather complicated project that works, and now I am picking up an old project that has come back around from when I was interested in it previously.
I found the F417ZGT6's on Ebay, still in packaging from Mouser and Digikey, for less than a buck each. I figure no one else bid because they were searching for F407? Either way, they appear to be genuine and I have a small handful.
Given that both the F407ZGT6 and the F417ZGT6 LQFP-144 devices share the same pinout, I would imagine they would substitute readily, with no hardware and only minor software changes?
If this is the case then the next task will be figuring out the existing pin map vs the new pin map, like when I moved from ATmega2560 to 2561 devices, right?
Re: Designing a new board around existing firmware-F407 vs F417
There is not so much difference btw F407V vs F417Z:
14c14
<  * Automatically generated from STM32F407V(E-G)Tx.xml, STM32F417V(E-G)Tx.xml
>  * Automatically generated from STM32F407Z(E-G)Tx.xml, STM32F417Z(E-G)Tx.xml
75a76,83
>   {PF_3,      ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 9, 0)}, // ADC3_IN9
>   {PF_4,      ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 14, 0)}, // ADC3_IN14
>   {PF_5,      ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 15, 0)}, // ADC3_IN15
>   {PF_6,      ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 4, 0)}, // ADC3_IN4
>   {PF_7,      ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 5, 0)}, // ADC3_IN5
>   {PF_8,      ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 6, 0)}, // ADC3_IN6
>   {PF_9,      ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 7, 0)}, // ADC3_IN7
>   {PF_10,     ADC3, STM_PIN_DATA_EXT(STM_MODE_ANALOG, GPIO_NOPULL, 0, 8, 0)}, // ADC3_IN8
97a106
>   {PF_0,  I2C2, STM_PIN_DATA(STM_MODE_AF_OD, GPIO_NOPULL, GPIO_AF4_I2C2)},
107a117
>   {PF_1,  I2C2, STM_PIN_DATA(STM_MODE_AF_OD, GPIO_NOPULL, GPIO_AF4_I2C2)},
183a194,197
>   {PF_6,       TIM10, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF3_TIM10, 1, 0)}, // TIM10_CH1
>   {PF_7,       TIM11, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF3_TIM11, 1, 0)}, // TIM11_CH1
>   {PF_8,       TIM13, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF9_TIM13, 1, 0)}, // TIM13_CH1
>   {PF_9,       TIM14, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF9_TIM14, 1, 0)}, // TIM14_CH1
202a217
>   {PG_14,      USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
219a235
>   {PG_9,       USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
230a247,248
>   {PG_8,  USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
>   {PG_12, USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
241a260,261
>   {PG_13, USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
>   {PG_15, USART6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF8_USART6)},
344a365,368
>   {PG_8,      ETH, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF11_ETH)}, // ETH_PPS_OUT
>   {PG_11,     ETH, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF11_ETH)}, // ETH_TX_EN
>   {PG_13,     ETH, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF11_ETH)}, // ETH_TXD0
>   {PG_14,     ETH, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF11_ETH)}, // ETH_TXD1
Mainly one more ADC, I2C and USART instance. So I guess it is safe and easy to move
Xnke
Post by Xnke »
That's what I was thinking-I am glad to see your confirmation.
Thanks a lot!
saigenku
Post by saigenku »
From https://www.st.com/en/microcontrollers- ... 7-417.html
"The STM32F417 also integrates a crypto/hash processor providing hardware acceleration for AES 128, 192, 256, Triple DES, and hash (MD5, SHA-1)"
