debugger not stopping at breakpoint, but 2 lines later
STM32_Newbbe
Post by STM32_Newbbe »
After I got debugging to work, I now sometimes have the issue that the program does not halt at the exact position I set a breakpoint, but one or two lines later.
Since I am fairly new to debugging the stm32(duino), I am not sure what can cause this behaviour.
I have a slightly modified Arduino Web Server example and I set a breakpoint in the W5100.cpp on line 285
phystatus = readPHYCFGR_W5500();
in function
W5100Linkstatus W5100Class::getLinkStatus()
	uint8_t phystatus;
	if (!init()) return UNKNOWN;
	switch (chip) {
	  case 52:
		SPI.beginTransaction(SPI_ETHERNET_SETTINGS);
		phystatus = readPSTATUS_W5200();
		SPI.endTransaction();
		if (phystatus & 0x20) return LINK_ON;
		return LINK_OFF;
	  case 55:
		if (phystatus & 0x01) return LINK_ON;
		return LINK_OFF;
	  default:
		return UNKNOWN;
the delay is a change I made
The debugger stops on line 287
This is a bit annoying since, I am hunting down a problem where I get incorrect LinkStatus when running normally, but the correct Linkstatus when debugging and stepping through the functions and statements.
And this is the exact location where I want to check what could possibly be the difference
Re: debugger not stopping at breakpoint, but 2 lines later
Ensure to disable optimisation.
-O0 instead of -Os
STM32_Newbbe
I had -Og (debug), but changing it to O0 makes the debugger halt on point :)
Thank you very much !!
Does this mean that with -Og, there is still some optimization going on, that is deemed safe, but nonetheless interferes with the debugger?
yes some optimization are done. So if you want exactly saw where you are you should enable assembler view.
STM32_Newbbe
thanks
